Need right angle-right angle power cord - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 12-05-2006, 01:39 PM - Thread Starter
bobsolo's Avatar
I have mounted my LCD to the wall and the TV came with a 6' power cord with a right angle 3-pin Shroud Female connector on one end and a straight 3-prong Grounded Plug Male connector on the other. (same as this one).
I've searched and searched, but have been unable to find an equivalent cord with right angle 3-pin Shroud Female and right angled 3-prong Grounded Plug Male. Has anyone see or heard of this?
Thanks in advance.
PSN: bobsolo1999
DVD Collection
bobsolo is offline
post #2 of 28 Old 12-06-2006, 01:36 PM
trekguy's Avatar
Is this what you are looking for? It is the second item on the page.
http://www.accessories4less.com/cgi-...y/ACPowerCords
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #3 of 28 Old 12-06-2006, 02:12 PM
DougRuss's Avatar
Good Find............I think that's what he's looking for ?
Yamaha RX-V479
Cambridge Audio " Azur-650c
Rega RP-1 Turntable
YAQIN MS-12B Pre-amp
GemTune BL-02 EL34*2 Hi-end Tube Amplifier
Monitor "Bronze 5" Speakers
DougRuss is offline
post #4 of 28 Old 12-07-2006, 03:08 PM
Glen B's Avatar
You can find right-angle plugs at Home Depot and electrical suppliers. Just cut off the straight plug and replace it with a right-angle plug. That is what I do.
Glen
Glen B is offline
post #5 of 28 Old 12-19-2006, 01:53 PM
mgelon's Avatar
I am looking for a right-angle cord that plugs into a DVD (2 pin figure-8 style polorized) so I can fit it in a narrow cabinet. Anyone come across any of these anywhere? I can get the component and optical right angles but haven't been able to find the power cords.
mgelon is offline
post #6 of 28 Old 12-19-2006, 05:01 PM
R_Willis's Avatar
Not seen a cord with a right angle plug on both ends, however they may make one.
Here is a single ended right plug cord:
http://www.milestek.com/search.asp?l...=1&skw=3920172
R_Willis is offline
post #7 of 28 Old 12-20-2006, 10:34 PM
mgelon's Avatar
I don't need the three prong bigger plug, I am looking for the two prong figure 8 plug that is typical in smaller A/V components.
mgelon is offline
post #8 of 28 Old 12-21-2006, 10:40 AM
Rupert's Avatar
Hard to find. The connector is called a "IEC-60320-C7 Right Angle"
Pics on this site about half way down, not sure if you can order from them:
http://www.yung-li.com.tw/EN/product...connectors.htm
This company also may have the cable you want:
http://www.quail.com
Rupert is offline
post #9 of 28 Old 01-11-2007, 11:35 AM - Thread Starter
bobsolo's Avatar
Got completely sidetracked with the holidays. That's exactly what I was looking for. Thanks for the help.
PSN: bobsolo1999
DVD Collection
bobsolo is offline
post #10 of 28 Old 01-11-2007, 05:54 PM
trekguy's Avatar
You are very welcome sir.
-Bertrand Russell
trekguy is offline
post #11 of 28 Old 09-05-2007, 12:33 PM
bwhitmore's Avatar
dude, i've been looking for this all day online
i want to replace the power cable on my projector
not sure why i didnt look here first
thanks!
bwhitmore is offline
post #12 of 28 Old 09-06-2007, 10:16 AM
trekguy's Avatar
You are welcome. Repay the favor forward if you will.
-Bertrand Russell
trekguy is offline
post #13 of 28 Old 11-08-2007, 12:36 PM
pliSkiNAKE's Avatar
That is the cable I am looking for as well but I need 15 cables and at $22 a pop (or $15 in bulk) that is PRICY. Anyone else find another website? I have been googling and calling companies for the past hour or so looking for someone else.
pliSkiNAKE is offline
post #14 of 28 Old 11-08-2007, 12:44 PM
bwhitmore's Avatar
pliSkiNAKE,
what about this?...
http://www.*******.com/cable/p/P7CR-SR06.html
i actually bought one of these for my projector, but then went ahead and got the Tributaries cable mentioned above as it was much thicker and higher (perceived ) quality
not a bad price, but no where near as thick as the Tributaries cable
but if you need alot of them the price is right!
HTH,
brad
post #15 of 28 Old 11-09-2007, 08:05 AM
pliSkiNAKE's Avatar
No, they have to have right angles on both sides. I am needing to attach them to Hobart scales. If it is a straight plug it will crush the cable. The scales are 50 pounds or so. I got a pretty good price quote from Quail.com though. Hope that works for me.
post #16 of 28 Old 11-12-2007, 09:14 AM
timtlm's Avatar
This is what you are looking for. It's available on the same site. It is 12ft, but only 3.75 each. Sorry, I couldn't post it as a link because this is my first post. Just copy and paste the text between the brackets.
[a]http://www.*******.com/cable/p/P7CR-RR12.html[/a]
UPDATE link for the 6ft version of the cable:
[a]http://www.*******.com/cable/p/P7CR-RR06.html[/a]
timtlm is offline
post #17 of 28 Old 07-12-2008, 12:43 AM
powercords's Avatar
can you send me the pic for reference?
powercords is offline
post #18 of 28 Old 07-12-2008, 12:44 AM
powercords's Avatar
I believe that I can help you.
I worked for the power cords factory.
and you can find more info on it.
post #19 of 28 Old 09-04-2008, 02:33 AM
kornbln's Avatar
anyone know where I can buy some of those Yung-Li cables in small quantities? I've never seen them anywhere. Stuff like this:
kornbln is offline
post #20 of 28 Old 12-01-2008, 11:38 PM
powercords's Avatar
some people asked me some power cords,but all are don't know the demension.
I hope that you can learn more about it when you need it
you can browse our company's tech for it.
http://www.cnpowercords.com
post #21 of 28 Old 01-07-2009, 05:37 PM
Thksnow's Avatar
Although there are some good suggestions here, since my Plasma is wall mounted, I had an AC outlet installed in the upper right hand corner of the wall space behind the TV. Thus I'd like to have a 3 ft power cord with right-hand plugs on both ends. The shortest one I've found is 6 ft in the above post.
Does anyone know where I can find one of these?
Thksnow is offline
post #22 of 28 Old 01-09-2009, 09:20 AM
mcevoyit's Avatar
Google Americord and look up power cords. They offer less expensive ones.
mcevoyit is offline
post #23 of 28 Old 01-09-2009, 02:13 PM
Thksnow's Avatar
Thanks, but I've looked there already. The only one they sell with the right-angle plugs on both ends is 9 feet long.
Anyone else have any other suggestions?
Thksnow is offline
post #24 of 28 Old 03-02-2009, 09:26 AM
ViperGTS's Avatar
This place has 1.5 ft and 3 ft double right angle cords.
ViperGTS is offline
post #25 of 28 Old 03-02-2009, 12:32 PM
ViperGTS's Avatar
I found another place that has them, quail.com. Their price is $6.40 each, but the minimum order charge was $50. So, compared to accessories4less.com you'd be spending more, but then you'd have 6 power cards.
ViperGTS is offline
post #26 of 28 Old 01-14-2010, 09:36 AM
myxylene's Avatar
Found a 9 footer with R/A at both ends at Americord (800) 647-6231
for $6.04 plus shipping. Enter item # 1081 in the search field.
SKU is 4212825.000.1081
With more TV's being mounted on the wall with very little clearance, I hope this helps!!
myxylene is offline
post #27 of 28 Old 06-07-2010, 12:47 PM
myrosen's Avatar
myrosen is offline
post #28 of 28 Old 06-07-2010, 12:49 PM
myrosen's Avatar
myrosen is offline
Reply Tweaks and Do-It-Yourself
