are hdmi, component cables, etc all ok for in-wall installation? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-01-2007, 02:28 AM - Thread Starter
juxtafras's Avatar
i'm going to wire an unfinished home theater room in the next week and i've learned on this site that the brand doesn't matter and that monoprice is a great place to find reasonably priced cables that won't sound different. i'll also make sure to install "in-wall" rated speaker wiring for its insulation properties.
does these statements sound accurate?
do the other video cables (hdmi, component, composite, svideo, vga, coaxial cable) need to be rated for in-wall use or are they all for in-wall use by default?
thanks for the help!
juxtafras is offline
post #2 of 5 Old 01-01-2007, 03:50 PM
kevcoleman's Avatar
You need to make sure those other cables are also rated for in wall installation
kevcoleman is offline
post #3 of 5 Old 01-04-2007, 03:03 PM
ejunior2's Avatar
Monoprice does have some CL2 rated HMDI cables in 25' to 100' lengths.
http://www.monoprice.com/products/pr...ormat=2&style=
Unfortunaly, I haven't found anything shorter like what I need though. Say in the 3' - 6' range.
Erik
ejunior2 is offline
post #4 of 5 Old 01-05-2007, 11:48 AM
ejunior2's Avatar
OK - I did find some CL2 rated HDMI cables at Blue Jeans in the shorter lengths.
http://www.bluejeanscable.com/store/dvi/index.htm
Now to find some S-Video+2RCA CL2 rated cables. Anyone?
Erik
ejunior2 is offline
post #5 of 5 Old 01-05-2007, 01:56 PM
sport06's Avatar
If you ever take the time to read the NEC and the UL Wire and Cable Marking Guide, you will find out that CL2 and CL3 cables are General Purpose cables.
There is nothing special about them.
They are allowed to be installed anywhere except in a riser, duct, or return air plenum.
Since residential construction does not have risers or plenums, as long are you arent installing through your ventilation ducts, you're fine.
if you want to put it in your duct work, use a CL2P, CL3P or a CMP rated cable.
Robert Hansen, RCDD
sport06 is offline
Reply Tweaks and Do-It-Yourself
