Max length for HDMI? - Page 2 - AVS Forum
post #31 of 39 Old 09-04-2013, 02:52 PM
alk3997's Avatar
Liked: 87
Which you can't do since the maximum High Speed distance for a passive HDMI cable is just over 25 feet.
alk3997 is offline
post #32 of 39 Old 09-04-2013, 07:29 PM
Colm's Avatar
Liked: 87
I doubt 75' will be doable. But we need to wait to see how the speed increase was achieved. If they just upped the clock rate, the maximum distance for 18Mbps will be considerably less than for 10Mbps today. If they changed the encoding scheme, it could be as long or longer.
Colm is offline
post #33 of 39 Old 09-04-2013, 08:06 PM
alk3997's Avatar
Liked: 87
I've been wondering about that too. Since it's backwards compatible, I assume they didn't "repurpose" any of the lines, although that could be worked around.
Clock increase would be easiest since the clock would be increased freq if 2.0 was detected and remain as-is if not. Encoding scheme would be interesting and today's chipset should support it. Until HDMI 2 is detected stay with current linear encoding and once HDMI 2 is detected go to a lossless compression (for instance). I suspect that might increase handshaking time though.
Either way I'm wondering if any of the cat 6 converters will work. I suspect the answer is no and would be detected as HDMI 1.x anyway. I don't have enough information to guess about Redmere.
Well, I've certainly used up my weekly allowance of speculation with those paragraphs.
alk3997 is offline
post #34 of 39 Old 09-04-2013, 08:13 PM
Xperplay's Avatar
I see, what`s the best option at the moment tough? I need to install something within next week. Would it make sense to use a booster at the end point of the cable outside the wall? Perhaps one on each end? or one on the input end?
I guess I could settle for 10gbit if that`s the best I can achieve at 75ft, how do you go on testing actual speed?
Xperplay is offline
post #35 of 39 Old 09-04-2013, 08:24 PM
Colm's Avatar
Liked: 87
You are not going to get 10Gbps at 75' with a passive HDMI cable, 25' is about the limit for a certified high speed HDMI cable. For 75' I would go with Cat 6 cable and an HDBaseT-based extender.
Colm is offline
post #36 of 39 Old 09-04-2013, 09:02 PM
alk3997's Avatar
Liked: 87
Agreed. Cat 6 with HDBaseT. Then replace the HDBaseT devices when HDMI 2 HDBase-T becomes available in about 3 years or so, if you still even care about UHDTV at that time.
alk3997 is offline
post #37 of 39 Old 09-05-2013, 01:58 AM
Xperplay's Avatar
Cat6 seems good for in wall. Seems future proof and I can cut it to size unlike hdmi. I have to read up on hdbase as it's all new to me. Thanks for your help, any product recommendations?
Do I need equipment on every end of the cat6?
Xperplay is offline
post #38 of 39 Old 09-05-2013, 08:18 AM
alk3997's Avatar
Liked: 87
Try here (and append there if you have HDBaseT questions)...
http://www.avsforum.com/t/1384980/the-unoffical-source-for-everything-hdbaset
alk3997 is offline
post #39 of 39 Old 09-05-2013, 09:09 PM
jautor's Avatar
Quoted: 49 Post(s)
Liked: 335
Two cat6 and a flex conduit is probably the only sure thing answer at this point. We should know more after CEDIA how HDBaseT and Redmere will pay with HDMI v2.0... But some cat6 and a conduit would be my choice regardless.
jautor is offline
Reply Tweaks and Do-It-Yourself
User Tag List
