Possible fix for Joytech 240c problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 01-25-2007, 01:16 AM - Thread Starter
NicolasG's Avatar
New here, if this is the wrong place, please do move it to a better candiate location, Sorry.
The intro (and my situation) can be found in the 'I need an AV switch; Any recommendations?' thread near the end of it.
Symptom: Joytech 240c a/v switcher introduces problems on the 'Y' signal of component video. (Some problems are horizontal lines, other include flicker and whatnot)
Problem: The IC used to switch the signals was not made for this purpose. They are using a HEF4051 8x1 mux. This 30 cent IC is not capable of properly handling the sync signal in the 'Y' of component video. Theres 6 of them in the 240c (one for each component signal, and one for the composite video, and 2 for the analog audio).
Solution: Replace the IC used for switching 'Y' with a better, proper, ic.
The candidate IC is MAX4315 8x1 video mux/amp.
The fix...(until i have time to create a proper one with full pictures and whatnot)
Replace the HEF4051 with the MAX4315. But the 2 chips are not pin compatible, so this means you will need to solder several wires to very small pins on the MAX chip (not for the faint of heart).
Grab the datasheet for the MAX4315 chip, and for the HEF4051
You will want to remove the HEF4051 chip from the pcb, and a few other components (see the red circle in the pic to see the components removed)
Dont forget to also remove the 4.7uf capacitor on the underside of the board.
You will now wire up the MAX chip. Use the datasheets to match the pins.
Take note of this:
- 'VDD' on the HEF is NOT connected to VCC on the MAX, you need to take 5v from
the proper place (see the DSC03734 image - 1st one) and connect that to VCC on the MAX chip.
- The "Y" inputs on the HEF chip map to the "IN" inputs on the MAX (ie. Y0 -> IN0)
- VSS on the HEF is GND. The pad on the pcb corresponding to this connects to GND on the MAC chip.
- SHDN on the MAX is connected to 5V (VCC) via a 10k resistor (resistor is not super important, but it prevents the MAX from getting damaged by accidental mis connection)
- You will also want to connect a 0.1uf capacitor (ceramic is fine, non polarized) between VCC and GND on the max chip (as close to the max as possible). Again this is not required, but if the voltage regulator is not stable, this will make sure the MAX is running properly.
- You will need a 75ohm resistor connected between 'OUT' pin on the MAX and to the location indicated by the blue arrow on the picture.
On the second picture you will see a brown board and parts below the MAX chip, IGNORE it. Its there for some tests that I did at first, and are not required for the fix.
One more thing, try and make the wires as short as possible. This prevents interference.
Hopefully this is clear enough for the technically inclined to try out.
Im busy this week, and probably wont be able to draw up more formal information, next week Ill get on it (if people want it)
(Maybe ill make a small pcb that will make life easier)
Im running it for about 5 days now. Working beautifully.
This fix also works for any other switcher based on the 4051 ic, such as some of the low end 'XBOX 360' switchers.
Enjoy.
PS. If any more experienced AV designers wish to add to this mod please do so. Im by no means an expert in this field, I simply saw a need and found out how to fix it.
NicolasG is offline
post #2 of 39 Old 01-25-2007, 01:17 AM - Thread Starter
NicolasG's Avatar
Useful links:
This is the circuit they based the 240c's video/audio switching on:
http://jap.hu/electronic/avswitch.html
http://datasheets.maxim-ic.com/en/ds...10-MAX4315.pdf
And for the HEF4051,
http://www.standardics.nxp.com/produ...f/hef4051b.pdf
NicolasG is offline
post #3 of 39 Old 01-25-2007, 01:19 AM - Thread Starter
NicolasG's Avatar
A quick way to determine if the problem is inded the Y signal do this:
Connect your source to any of the inputs, connect the output to the TV. (As you normally would).
A problem should be visible.
Now, disconnect ONLY the 'Y' signal from the input and disconnect the output 'Y' cable as well, then using a RCA joiner connect the two directly.
(That is, Y is connected directly from source to TV, and Pb/Pr are connected thru the switch)
If the problem has now dissapeared, then replacing the IC used to switch 'Y' will fix your problem.
NicolasG is offline
post #4 of 39 Old 01-28-2007, 12:39 AM
Glo8al's Avatar
How has your Joytech been? Still working OK?
I'm having a problem locating the MAX4315 IC in Australia (any one help?)
I have emailed a few electronic shops with no luck so far.
Glo8al is offline
post #5 of 39 Old 01-28-2007, 02:20 AM - Thread Starter
NicolasG's Avatar
Still running great.
The MAX4315 is a 'big' chip. Its retail is $4 in 1k lots.
Digikey has it for $8.
Its not something you can find at the local shop, but can usually be ordered.
Contact your local Maxim distributer, see if they can arrange for a free sample. Or try the website and see if you can order a sample there.
The alternative, use a MAX4314. This version is 4x1 (4 inputs).
If you only have 4 things that will be connected by component video, then this will suffice.
(It is also possible to connect 2 Max4314's, but it requires some extra logic to handle the selection bit A3)
NicolasG is offline
post #6 of 39 Old 02-05-2007, 09:05 PM
ultatryon's Avatar
I guess I am just looking for clarification on this before I go ahead and do this, I have the following pin-to-pin configuration from the datasheets, can you verify this is indeed correct?
Code:
4315         HEF
1            9     (A2)
2            10    (A1)
3            11    (A0)
4            +5V   (Vcc) [Sourced from board]
5            13    (In0)
6            14    (In1)
7            15    (In2)
8            12    (In3)
9            1     (In4)
10           5     (In5)
11           2     (In6)
12           4     (In7)
13           7     (Vee)
14           to +5V via 10k resistor [See pin 4]
15           8     (VSS)
16           3     (Output)
ultatryon is offline
post #7 of 39 Old 02-05-2007, 09:30 PM - Thread Starter
NicolasG's Avatar
Code:
4315         HEF
1            9     (A2)
2            10    (A1)
3            11    (A0)
5            13    (In0)
6            14    (In1)
7            15    (In2)
8            12    (In3)
9            1     (In4)
10           5     (In5)
11           2     (In6)
12           4     (In7)
13           7     (Vee)
15           8     (Vdd)
16           3     (Output)
Almost, the following pin is correct, but the designation is wrong:
15 8 (Vdd)
Correct is :
15 8 (VSS)
Everything else is correct.
NicolasG is offline
post #8 of 39 Old 02-05-2007, 09:34 PM
ultatryon's Avatar
hah, You are correct.. I am pretty tired tonight, and I tend to mess up my Vcc/Vee/Vdd/Vss designations even when I am not tired! Thank you for double checking me.
post #9 of 39 Old 02-12-2007, 07:08 PM
FrozenPea's Avatar
WOW! I just pulled apart my generic component switcher this past weekend out of frustration, to see what was inside. If my memory is correct it also had three of the HEF4051 chips inside.
Thanks muchly for sharing the info - sounds like a project i'll be looking into!
FrozenPea is offline
post #10 of 39 Old 02-12-2007, 09:47 PM - Thread Starter
NicolasG's Avatar
Thanks to a fellow member I saw the insides of a 245c.
The 245C is similar to the 540 (360 switcher) - which has the same problems as the 240c.
The 245 is not fixable (as easily) using the method I outlined above.
The 245 would require removal of several ic's and much more complex wiring.
NicolasG is offline
post #11 of 39 Old 02-13-2007, 09:53 AM
ultatryon's Avatar
Yea, it turns out that my "240c" is not a 240 after all, it is marked 965 on the front, but seems to be a 245, from the PCB descriptions.
It uses cascaded Quad 2x1 video switches, and I am currently working on a solution for it.
post #12 of 39 Old 02-13-2007, 07:41 PM - Thread Starter
NicolasG's Avatar
The 245/540 can in theory be fixed. The problem is you will need to run wires from all the Green component lines back to the MAX chip, and then the output runnedto the output signal. Also will need to remove all the 2x1 switch ic's and corresponding circuit (essentially isolate the Y signals)
NicolasG is offline
post #13 of 39 Old 02-13-2007, 09:51 PM
boon_army_cadet's Avatar
Looking into fixing this problem on my 245 and came to this thread from the one that spawned it.
NicolasG, you said there that:
"They did use better ic's, the TE330, but they did not use a proper amp on the output, thus limiting the bandwith."
Would that mean that the 245/540 problems could be fixed by the addition of an amp to the Y output? I'm far from an expert, and I may well have misinterpreted what you meant (in which case sorry). It would be relatively easy to add an amplifier circuit outside the box between the Y-output socket and the Y-plug on the cable, would that be sufficient?
That could even be what the fabled "adapter" that Joytech have told some they'll offer is, and not the plain-old resister that everyone seems to think it will be.
boon_army_cadet is offline
post #14 of 39 Old 02-14-2007, 09:25 AM
ultatryon's Avatar
If the dongle was an amp, it would require external power.
the problem with the TS5V330 is that it is a passive switch with 10 ohm resistance. When you cascade enough of them, that 10ohms adds up. Also, the effective bandwidth is reduced every time you cascade a switch, so with that many, it ends up being no better then the HEF.
post #15 of 39 Old 02-15-2007, 08:07 PM
I did think of that - a dongle could easily get power from the DC supply with a pass-thru type plug into the external power jack. But that's all conjecture anyway.
The cascading is the bit I don't quite understand. From the photo that was submitted and the TS5V330 datasheet: the 330 is a 4PDT switch and the photo shows 4 of them, cascading them to provide a 6 way switch would require 5.
The 330 has an enable input (pin 15) so you could switch 8 ways with only the four switches in a parallel layout. Since an individual switch can select left/right/neither you can select between 8 signals as long as you only enable one switch at a time.
That being said the circuit design skills here (or testing for that matter) really don't seem to be up to much. I really need to open mine up and have a poke around since the photo isn't quite clear enough to see exactly where even the topmost the traces go.
post #16 of 39 Old 02-15-2007, 09:12 PM - Thread Starter
NicolasG's Avatar
The output related problem with the TE330 is based on a post by Videostorm (who oviously knows much more about this than I do)
"TS5V330 is a 10 ohm passive switch. They would need to follow it with a high bandwidth amp in the box if they use that device. "
http://www.avsforum.com/avs-vb/showt...&&#post9638698
I dont have the 245/540 in hand, so I have not traced it out. But from the pictures I received of them, there is 6 of them. On the 540, 3 are on the top board and 3 are on the bottom board. I would venture and guess the 245 is the same, 6 chips.
Do note I have not delved into how the optical is being switched, given their design choices, they very well could be using the 330's for that too.
They are also using a hc04 logic inverter, which I assume is to aid in the control logic for the switching, and they are using two serial-parallel ic's (hc595).
Find attached 2 pics of the 540, displaying the ic's and locations. (let me know if you want hi-res versions)
NicolasG is offline
post #17 of 39 Old 02-15-2007, 09:13 PM - Thread Starter
NicolasG's Avatar
Im very happy that this is gaining momentum. Sure, were fixing a product that should work in the first place, but given the price (versus other switchers) the fix is very reasonable.
NicolasG is offline
post #18 of 39 Old 02-15-2007, 11:31 PM
I'll try to get some decent photos of it this weekend, the 245 is very stackable and since it produces no heat so it's at the bottom of the stack so extricating it will take some time.
One other thing to consider - by my reckoning it has to switch 6 video channels (Y/Pb/Pr, Y/C and composite) so I don't know if the TS5V330s are only used for component. I think I may need to do a bit more maths on the number of chips vs channels though.
It's annoying that it isn't totally up to spec, but as you said it is cheap especially for the functionality you get.
BTW on over at the Trusted Reviews site in their gaming section (can't link to it because I'm under the post limit) the review of the 540C states:
Update 31/01/2007: Joytech has been in contact informing us that they’re working on a discrete adapter to solve the Nintendo Wii output issues, as mentioned in the review. These will be given out free to anyone who needs one, and the changes will be incorporated into future manufacturing runs of the Control Center 540C.
post #19 of 39 Old 02-28-2007, 02:36 PM
cverwoert's Avatar
Hi,
I also have a 245c with the same issues...
I recently opened it up and found that the audio L/R still use the HEF4051.
Would it be crazy to rewire one of these and use for the Y signal?
cverwoert is offline
post #20 of 39 Old 02-28-2007, 10:58 PM - Thread Starter
NicolasG's Avatar
The HEF4051 is bad for Y switching. So feeding the Y signal thru these instead of the TE330 wont be of much use.
Give it a try though, connect Y to one of the audio and do the same on the ouput.
It most likely wont work, specially since the audio connections dont have the proper circuit to handle video, but its worth a shot.
NicolasG is offline
post #21 of 39 Old 03-01-2007, 04:29 PM
cverwoert's Avatar
sorry for my lack of explanation...
i meant, replace one the L/R HEF4051 chips with a MAX4315 then run the Y signal through.
post #22 of 39 Old 03-01-2007, 09:43 PM
Actually having read up on the datasheets I think I have a solution that will not even require opening the case.
The TS5V330 can pass a signal in either direction, so you send a signal (possibly just a simple DC voltage) into the Y "output" of the switch, it'll show up on the currently selected Y "input", do a bit of logic processing and you have the binary number representing the currently selected input. This can then be used to switch a MAX4315.
Granted that would require a lot of wiring but no desoldering or even opening the case - might not even invalidate your warranty
The logic should be fairly simple, the circuit I've got drawn up uses a few 4-input ORs but I think there's probably a simpler way.
You could even add opto-isolators to the circuit and use it to control things based on which input is selected.
post #23 of 39 Old 05-05-2007, 02:57 AM
Ssseth's Avatar
Wow... that is pretty sad that a user of the product (that was out for a long time) came up with a solution and the people that make the things couldn't! Good work anyway.
Sorrt for the bump, I just thought I'd give some kudo's on the fix! I'm not good enough with the solder iron to try it myself though.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein
Ssseth is offline
post #24 of 39 Old 05-05-2007, 02:29 PM - Thread Starter
NicolasG's Avatar
boon_army_cadet are you saying to use the systems input/outputs to determine which input is selected so that you can change the input on a secondary switch ?
Yes thats very possible, but in that case, i think its easier to have the secondary device receive IR signals, same ones as the main device, and switch based on that.
NicolasG is offline
post #25 of 39 Old 06-02-2007, 10:34 PM
tradewinds's Avatar
Quoted: 16 Post(s)
Which one should we get, MAX4315ESE or MAX4315EEE
and in QSOP or SOIC or uMAX(?)
thanks.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #26 of 39 Old 06-03-2007, 04:34 AM - Thread Starter
NicolasG's Avatar
soic is the biggest pin pitch possible. so go with that.
as for ESE or EEE, doesnt matter.
NicolasG is offline
post #27 of 39 Old 06-03-2007, 09:16 PM
tradewinds's Avatar
Quoted: 16 Post(s)
thanks. So with this fix, does this mean the 240c will be one of the best HD switchers? I have heard it had issues, however I am not sure if this fix mean that it will have no issues.
post #28 of 39 Old 06-03-2007, 09:42 PM
tradewinds's Avatar
Quoted: 16 Post(s)
BTW - Nicolas if you have the time, please draw up the formal instructions and parts list (possible where to obtain it, I know the US stores may be different in Canada, but it helps if you can link to a store in either country). Thank much.
post #29 of 39 Old 06-03-2007, 10:54 PM - Thread Starter
NicolasG's Avatar
Ive decided to leave this as is. All the technical details are there, just a matter of following them. For parts, radio shcak will have the simple stuff, and Maxim can send you free samples.
It does fix the problems with the video. Which is the majority of problems Ive seen on it.
I love it.
NicolasG is offline
post #30 of 39 Old 06-04-2007, 06:27 AM
tradewinds's Avatar
Quoted: 16 Post(s)
How many MAXIMs are required? From the instruction it appears to be at least 6. Am I reading this correctly?
Sorry for making the request, I am not very good at soldering stuff unless the instructions are detailed. The last time I did, I place a capacitor in the opposite polarity.
Reply Tweaks and Do-It-Yourself
