How should I connect? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-09-2007, 11:46 AM - Thread Starter
Lungman00's Avatar
I want to be able to watch the tv with (7.1) or without (tv speakers) using the XR57.
I'm a noob so if more info is needed please let me know.
Also, after recommending a setup please let me know the cables i'll need to purchase. Assume I have none. I will be purchasing through monoprice.
My Stuff
Panasonic TH-42PD60U Plasma (EDTV)
--Input Terminals:
-Composite Video 2 (RCA)
-S-Video 2 (4-pin mini DIN)
-Component Video 2 (RCA x 3)
-HDMI Interface 1
-Stereo Audio In 4 (RCA L/R)
Panasonic XR57
-1 HDMI Input/Output Input & Output
-1 Video Output RCA
-S-Video Output(s) Yes
-Component Video Output(s) Yes
-Digital Input Yes
-Audio Input Yes
-Optical Digital Out No
Pioneer 640H
- Outputs
Component Video Output Yes
Dolby(R) Digital and DTS(R) Digital Output Yes
-Inputs
S-Video 1 Front Input/ 2 Rear Inputs
Lungman00 is offline
post #2 of 10 Old 02-09-2007, 06:19 PM
trekguy's Avatar
Are you getting TV over the air or from a cable or sat box?
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #3 of 10 Old 02-10-2007, 11:51 AM - Thread Starter
Lungman00's Avatar
As of now I have Comcast cable going directly into my plasma. In the future I hope to be getting digital cable.
post #4 of 10 Old 02-10-2007, 03:42 PM - Thread Starter
Lungman00's Avatar
bump
post #5 of 10 Old 02-11-2007, 11:20 AM
trekguy's Avatar
The receiver manual implies that is does not transcode video, so component in=component out and HDMI in = HDMI out.
Receiver to TV - component video, and digital audio (coax or optical)
Pioneer to Receiver -- component video and digital audio (coax or optical)
TV audio out to Receiver -- digital audio and L/R analog stereo. Your TV may need a firmware upgrade to pass digital audio http://www.pasctraining.panasonic.co...downloads1.asp It can be DIY or call Panny service
Video to Pioneer (for recording)- S-video
-Bertrand Russell
trekguy is offline
post #6 of 10 Old 02-11-2007, 01:16 PM - Thread Starter
Lungman00's Avatar
Thanks for the reply.
When you say "Video to Pio for recording" Do you mean Video out from Tv to Pio DVR video in?
And with this setup am I hooking the Comcast cable directly to the Tv still or to the Pio DVR first then to the Tv?
Another thing that had me confused was the HDMI and I think you cleared that up for me... No sense in getting an HDMI cable since nothing going through Receiver is HDMI. Correct?
Just to make sure I got it.
I need:
2 sets of the 3 plug rca component cables
3 digital audio, coax or optical
1 set RCA for L/R analog stereo?
1 S-video
Thanks again I appreciate the time.
post #7 of 10 Old 02-11-2007, 03:56 PM
trekguy's Avatar
Sorry I was so driven by a sunny break in the weather that I had go and get in a few miles on my bike.
I did not see a "cable in" for the Pioneer so I assumed that you were getting it from the TV. If it accepts cable directly it make sense to do that, and if it has an RF pass through (as most do) to connect that to the TV. So CC cable via coax to the Pio and on to the TV. If not use a splitter.
That's what the manual seems to say.
I need:
1 S-video
Ok except the S -video may not be needed. The manual seems to say the the TVs video out from its on-board tuner is composit video. If that's true, and you want to use the TV Guide to run your recorder, then the S-vid cable is not needed. If you you are going to record directly from the cable, then you don't need any addtional cables.
-Bertrand Russell
trekguy is offline
post #8 of 10 Old 02-11-2007, 04:45 PM - Thread Starter
Lungman00's Avatar
Thanks so much for taking the time to help.
post #9 of 10 Old 02-14-2007, 02:58 PM
dantothe4thpower's Avatar
all that decent gear, and you're running the coax feed directly into the plasma. tsk.
do yourself a favor. spring for the comcast hd package. and a dvr while you're at it the new models are better than the 6412.
dantothe4thpower is offline
post #10 of 10 Old 02-15-2007, 10:20 AM - Thread Starter
Lungman00's Avatar
LOL I know. The direct connection is just temporary. I'm remodeling the family room and the plasma will be wall mounted. And I will be getting the digital package, didn't want to pay for it until I can use it.
The Pio 640 is a DVR. But I'm waiting to complete the room before I hook it up. ;-)
Reply Tweaks and Do-It-Yourself
