connecting PC to TV - need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-07-2007, 03:32 PM - Thread Starter
sweetverve's Avatar
Total newbie here...hope you guys can help.
I am trying to connect my HDTV to my PC as a monitor. The TV has a VGA output, and I've successfully connected to my computer through that. However, I wanted to be able to have both my original PC monitor on and the TV on at the same time, sort of an "extended desktop" deal (mainly to be able to watch movies stored on my PC through the TV, which is not next to the PC but on the other side of the room).
I am currently trying the following set-up, and it's not working:
- I connected a VGA- to - VGA-and-DVI adapter/splitter to the VGA output on my PC
- to the VGA output of the adapter/splitter, I connected my original monitor
- to the DVI output of the adapter/splitter, I connected a DVI-to-HDMI cable
- then I connected the HDMI end of the cable to the HDMI output on the TV
The monitor is on, but the TV is showing "no signal." What am I doing wrong here?
sweetverve is offline
post #2 of 8 Old 03-07-2007, 04:10 PM
dbc
dbc's Avatar
Your adapter/splitter is probably analog only, so you would then be trying to make a VGA to HDMI connection, which won't work.
If I understand correctly, the TV has a VGA Input. Why don't you try a simple VGA split?
dbc is offline
post #3 of 8 Old 03-07-2007, 04:20 PM - Thread Starter
sweetverve's Avatar
If I connect the TV to my PC through VGA, I need a separate audio connection.
Although I suppose connecting DVI-to-HDMI needs a separate audio connection as well, right?
post #4 of 8 Old 03-07-2007, 05:40 PM
whoaru99's Avatar
Liked: 69
Yes, DVI is only video. Besides, as the previous poster mentioned, the digital TV input will not accept an analog signal from the video card.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #5 of 8 Old 03-07-2007, 05:53 PM - Thread Starter
sweetverve's Avatar
Can I do a VGA-to-component connection from my PC to the TV, instead of VGA-to-VGA, just so I wouldn't need a separate audio cable?
post #6 of 8 Old 03-07-2007, 07:20 PM
Targus's Avatar
No, only HDMI can carry audio as well as video.
Targus is offline
post #7 of 8 Old 03-07-2007, 09:11 PM - Thread Starter
sweetverve's Avatar
So if my video card only has a VGA output, there's no way I can connect my computer to the TV via HDMI, correct?
post #8 of 8 Old 03-08-2007, 07:56 AM
Targus's Avatar
correct, VGA is not HDMI
Targus is offline
Reply Tweaks and Do-It-Yourself
