Projector Pole Wrap/Cable Management - AVS Forum | Home Theater Discussions And Reviews
Old 03-11-2007, 07:55 PM - Thread Starter
mooneycj's Avatar
Anyone know a website where I can buy a split, plastic, round tube that I can cover my projector ceiling mount? I have a cream colored one that came with my Sharp projector several years ago, but it is cracked and needs replacing. It is great because it snaps around and covers the pole, and you can hide the cables from the ceiling to the projector under the cover. I can't seem to fine one anywhere. Any ideas? Thanks in advance.
mooneycj
mooneycj is offline
Old 03-11-2007, 10:08 PM
Rupert's Avatar
You might try here:
http://cableorganizer.com/
Rupert is offline
Old 03-11-2007, 11:50 PM - Thread Starter
mooneycj's Avatar
Originally Posted by Rupert View Post
You might try here:
Thanks Rupert, that's what I've been looking for, however, I don't need a 50 or 100 foot roll, and I'm not sure 2" is wide enough to go around the pole and hold the cables. My current one is bigger (3" I think).
mooneycj
mooneycj is offline
Old 03-12-2007, 04:02 PM - Thread Starter
mooneycj's Avatar
UPDATE;
cableorganizer.com DOES have a 3.5 inch diameter split flex tube. And, they sell by the foot. All is well again. Thanks.
mooneycj
mooneycj is offline
