Right angle RCA adapter for component cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-10-2007, 02:15 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 85 Post(s)
Liked: 48
I need a right angle RCA adapter for my component cable but I can't find ones for video only audio. For the sake of the adapter do you all think it's okay to use a audio rated adapter for a vidoe cable? The adapters don't give an ohm rating.
Monkey_Man is offline
post #2 of 16 Old 04-10-2007, 02:32 PM
Targus's Avatar
yes....it's not like RCA connectors conform to any specifications anyway....it's electrically too short to matter.
Targus is offline
post #3 of 16 Old 03-04-2009, 07:31 AM
connector_guy's Avatar
I knwo this thread is old, but its a valid question about your RCA connection. If you use an adapter there is a little signal loss. RCA just carries a signal, audio or video is not important unless you want the color of the connector to match. RCA connectors and adapter work on both audio and video.
--good luck--
Will
I know connectors
connector_guy is offline
post #4 of 16 Old 03-04-2009, 08:10 AM
duvetyne's Avatar
no there isn't.
duvetyne is offline
post #5 of 16 Old 03-04-2009, 09:39 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Yes there is... "no there isn't" is the wrong answer/assumption.
Post #2 is correct. But... all connectors/adapters do introduce an inherent loss.
Also, RCA plugs do not have a 75 Ohm impedance, so therefore, the use of "RCA adapters" could have more impact/degradation than the traditional F or BNC connector for video application(s).
Ratman is online now
post #6 of 16 Old 03-04-2009, 10:35 AM
duvetyne's Avatar
Sorry, you're wrong.
You don't seem to know what characteristic impedance is, or what it means.
read up on that before posting such mistruths.
duvetyne is offline
post #7 of 16 Old 03-04-2009, 12:15 PM
Ratman's Avatar
Liked: 1022
Prove me wrong...
RCA connectors are not 75 Ohm impedance. And all connectors/splices/adapters will produce an insertion loss whether it's RCA, BNC, F, etc...
Make sure your six gun has bullets before you draw and shoot cowboy.
http://www.bluejeanscable.com/articles/75ohmrca.htm
...but is there such a thing as a true 75 ohm RCA plug? Not really; Canare's RCAP-series plugs, which we feel are the best RCA plugs available for video, are often referred to as "true 75 ohm" plugs, but that's not quite accurate.
You need to follow your own advice (admonishments).
post #8 of 16 Old 03-04-2009, 05:51 PM
ChrisWiggles's Avatar
No, sorry mister uhelpful jerk with a bad attitude. You are incorrect. RCAs are inherently not 75ohm, and using an additional adapter connector (like using additional RCA junctions in general) on a 75ohm video run is a poor choice particularly over distance and at higher resolutions.
But it isn't as if you've ever posted anything helpful on these forums except to thread-fart about subjects you don't fully understand.
ChrisWiggles is offline
post #9 of 16 Old 03-05-2009, 02:31 PM
Ratman's Avatar
Liked: 1022
Hypothetical response:
Sorry... upon further reading, you are correct. I apologize for being condescending and stand corrected. I will try to be more helpful in the future and try to provide repsonses that are helpful and accurate (to the best of my ability).
post #10 of 16 Old 03-28-2009, 09:53 PM
lonjim2's Avatar
Video is pretty resilient to be honest...you might be able to get away with it. I'd just crimp on an F-style connector and buy a right-angle adaptor. I know my electronics store sells yellow "video" connectors that are the exact same (aside from colour) as the white and red audio connectors.
lonjim2 is offline
post #11 of 16 Old 04-05-2009, 10:57 AM
sage11x's Avatar
Quoted: 727 Post(s)
Liked: 808
I had this same question.
I have my Panasonic Plasma mounted to an OmniMount TV stand (moda 50fp) and the columns that support the TV conveniently block ALL my component connections and one of my hdmi. The hdmi was easy to sort out as right angle adapters are readily available. The component connections were a different matter... I had really two choices:
a) buy some RCA right angle connectors and pray that the loss wasn't enough to affect my video signal (1080i cable TV and 1080i HD-DVD).
b) buy some very expensive, very cheap looking, Monster Cable "FlatScreen" cables which terminate in stubby little connectors that can be just barely squeezed in between the back panel and the column- and then pray that the resulting sharp bend in the cable didn't degrade the signal or ruin the cable itself.
Currently I'm using the Monster solution and the results seem to be satisfactory with the exception that I'm worried that the resultant pressure of such a sharp bend is either ruining the cable or applying un-due stress on the connectors. Any advice for me out there?
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #12 of 16 Old 08-18-2010, 11:18 AM
frankenstein897's Avatar
Sage, what did you end up doing for your component cables? I too am looking at a right angle solution for component cables. I know its been away since your post.
frankenstein897 is offline
post #13 of 16 Old 08-18-2010, 07:06 PM
Gizmologist's Avatar
Liked: 31
No problem at all using a right angle RCA for video -baseband or otherwise. We use a LOT of "signal plumbing" in the pro world with zero negative effect or degradation.
Gizmologist is offline
post #14 of 16 Old 08-18-2010, 08:48 PM
Colm's Avatar
Liked: 94
You back or just lost?
Colm is offline
post #15 of 16 Old 08-18-2010, 09:38 PM
Liked: 31
Just went cruising around all my old haunts to see what has transpired. I just lost my older sister to lung cancer 2 weeks ago yesterday so I am still sort of not quite ready to resume my shop activities. She was diagnosed on Friday with what she was told was stage 1. On Monday they said it was stage 4 and started heavy chemo. She suffered through 2 rounds before saying enough. She passed away the next day at 3:00 pm. She donated her body to the University of Hawaii for research.
I miss her so much.
Bill
post #16 of 16 Old 08-18-2010, 10:04 PM
Colm's Avatar
Liked: 94
My condolences for your loss. Good to hear from you.
Colm is offline
Reply Tweaks and Do-It-Yourself
