just finished flexi rack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-17-2007, 06:13 PM - Thread Starter
praveenk25's Avatar
I just finished building my flexi rack. I put 4 casters underneath the bottom rack so that its easier to move. Thanks everyone for the great tips!
praveenk25 is offline
post #2 of 15 Old 04-17-2007, 09:52 PM
Gir_1337's Avatar
I think I've decided I'm definitely doing something like this. Yours looks very nice, great job!
Gir_1337 is offline
post #3 of 15 Old 04-28-2007, 08:07 PM
r:o:b's Avatar
total cost????
r:o:b is offline
post #4 of 15 Old 04-30-2007, 12:22 PM - Thread Starter
praveenk25's Avatar
3/4" MDF (49"x97") - $19.76
5/8" Threaded rods - $25
Casters - $9.32
Washers & Nuts - $15
Thats approx $70 + tax...everything from Lowes and I did use 10% off coupon. I didn't had to buy primer and paint since I had some leftover from a previous DIY project. I still have MDF left which I might use later to add more racks. One of my friend loaned me his drill m/c to make 5/8" holes for the rod...otherwise renting is going to cost pretty much same as buying a new one.
post #5 of 15 Old 05-06-2007, 08:25 PM
Xmax BR's Avatar
Wow!
Renato
Xmax BR is offline
post #6 of 15 Old 06-26-2007, 01:49 AM
tilezzzzz's Avatar
Hi ya,
Ive just built one very similar myself. Can I ask exactly what paint you used?
I have used black satin paint and the finish looks prety awfull. - Need to get it sorted before i let it go in my setup!
Chris
tilezzzzz is offline
post #7 of 15 Old 07-10-2007, 12:36 PM - Thread Starter
praveenk25's Avatar
I used gloss enamel which is carbon black. I don't remember the exact brand name. Don't forget to run roller to give smooth finish otherwise you get streaks.
post #8 of 15 Old 07-13-2007, 08:38 PM
bryanesposito's Avatar
Looks great. I'll have to try this myself now!
bryanesposito is offline
post #9 of 15 Old 07-15-2007, 01:09 AM
Aviators's Avatar
great looking- in need of a similar rack so I'll have teo borrow from your idea!
Aviators is offline
post #10 of 15 Old 07-15-2007, 10:04 AM
Captain Crunch's Avatar
Outstanding ..............Well done.
Captain Crunch is offline
post #11 of 15 Old 11-22-2007, 11:33 PM
bdshort's Avatar
I'm about to embark on my own flexy rack. I ordered the threaded rod and fittings from McMaster-Carr. I'm wonder if I should use MDF or finish quality plywood for the shelves. Any suggestions? I'm in a small Alaska town and there isn't a single store here that sells MDF (which actually blows my mind, but that's the way it is), though I'd imagine I could special order it. I think I should be able to find some furniture quality plywood though. I do plan on painting it so I guess MDF is preferred.
My plan is to make something like this: http://www.studiotech.com/products/c...-33/index.html
but for quite a bit less money!
PSN: bdshort
bdshort is offline
post #12 of 15 Old 11-24-2007, 04:52 PM
Ericglo's Avatar
Quoted: 1697 Post(s)
Liked: 796
Good job on the rack!!
I did one as well. I intially painted it, but then decided to laminate it with some Wilsonart. It was the green marble design. I can't find a pic, but I think I posted a pic in the archives somewhere.
What are you planning on putting on the rack? I would think that some good quality wood work just as well.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #13 of 15 Old 12-13-2007, 04:02 PM
Avus_M3's Avatar
Any sites you know of that show some different ideas for racks?
-The Dave
----Check my QUAD 18" Fi IB Build Thread!! (DONE) King of the 400 lb Gorilla
Avus_M3 is offline
post #14 of 15 Old 12-13-2007, 06:51 PM
ChemEng's Avatar
Ive been thinking about putting something like this together myself. Yours looks great though!
Dumb question... Is each corner set on 1 threaded bolt? Or are they joined smaller threaded bolts? It looks like its just 1, but I wanted to make sure.
ChemEng is offline
post #15 of 15 Old 12-14-2007, 01:23 PM
Avus_M3's Avatar
Have you thought about routing the edges so they are not just a straight edge?
-The Dave
Avus_M3 is offline
Reply Tweaks and Do-It-Yourself
