Coax Type-F Tools (TV Cabling) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-29-2007, 08:35 AM - Thread Starter
Status's Avatar
So I've got my new HDTV and am going to set up an attic Antenna for local reception. I'm looking at buying some cabling tools online, but need some help, as I can't have them in my hands to make sure I'm getting the right items.
I'm running coax cable from my antenna to the wall next to my TV. Less then 40'. I think I need Type-F tools, correct?
I have a cable stripper already.
Any suggestions as to a good online retailer and the tools I'll need?
Need crimper, cable and connectors (standard US TV connection/hook-up).
Status is offline
post #2 of 5 Old 05-29-2007, 05:56 PM
Greg_R's Avatar
partsexpress.com sells most of the stuff you'll need. For f-type connections I just got a crimper and F-connectors from Home Depot. For RCA or BNCs you could think about investing in a Canare crimp setup. It sounds like you're talking about a small number of cables so there's no sense in spending a bundle (in fact, it might be cheaper to just buy some good ones from an online retailer like Blue Jeans cable, etc.).
Greg_R is offline
post #3 of 5 Old 05-31-2007, 12:37 PM
osu fan's Avatar
Heres what I bought, works great! http://www.partsexpress.com/pe/pshow...51&rak=360-046
osu fan is offline
post #4 of 5 Old 05-31-2007, 01:51 PM
DaveHolland's Avatar
Skip the crimp kind & go straight for the compression type fittings. Get the Zenith compression tool from Lowes($12) & pick up some Digicon fittings off eBay. Same cost as crimp, better connection.
DaveHolland is offline
post #5 of 5 Old 05-31-2007, 03:00 PM
badahab's Avatar
I use Canare stuff every day at work. Its great for studio stuff, but its kind of overkill for an antenna in the attic. Ive heard a few cable tv installers complain about the Canare f-type connectors not making a good connection before, but its usually cheap wall plates not making a good connection on the center pin.
For anything F-type I prefer the compression connectors like the others were talking about. They are usually more water proof and are more corrosion resistant.
If all your doing is making a single 40' run I would just buy something pre-made. You might have to get a 50' roll, but that will let you play around with antenna placement in the attic. Gives you some wiggle room for the difference between guestimation and as the wire runs.
-Sean
badahab is offline
Reply Tweaks and Do-It-Yourself
