A/V Cabinet Ventilation Suggestions - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By John Megadeth
post #1 of 18 Old 06-12-2007, 01:23 PM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Presently, I have an A/V Cabinet that has practically no ventilation. The cabinet has 2 doors in the front that contain 8X10 flosted plastic inserts in each door so that a remote can be used. In order to better ventilate my cabinet, I have placed 2 usb driven adjustable fans in the cabinet but all this does is push air around and when my PS3 gets warm, I need to open the cabinet doors to create air flow. I'm thinking of replacing the 8X10 frosted glass inserts with either speaker cloth or perforated metal to create ventilation. Has anyone does this and what do I use to attach the cloth or metal to the back of my cabinet doors? Suggestions? I believe that speaker cloth would be easier to apply but will a remote work through speaker cloth? Below are pictures of the items I plan on using.
Speaker cloth:
Perforated Metal:
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2 of 18 Old 06-14-2007, 06:11 AM
joshkelley's Avatar
A remote would work through the speaker cloth, but you won't get much ventilation.
Was the link to perforated metal supposed to be an alternative option, or to be used with the speaker cloth. If it is an alternative, it should provide sufficient ventilation, but again, with the speaker cloth there won't be much air movement.
joshkelley is offline
post #3 of 18 Old 06-14-2007, 07:04 AM
tmnjus's Avatar
What is the back of the cabinet? Could you mount the existing fans in the back material (wood?) and exhaust the air out? You would need some type of intake opening/vent to allow the air to flow. If the cabinet shelves are not tight (against the door or the back), cutting a vent hole in the bottom-front (floor) of the cabinet with the fans in the top-back, this may work. If the shelves are tight, perhaps cutting a few holes in both the front and back of the shelves to allow air to move from the bottom to top. This is how I made my built in cabinets.
Another option would be to put the perforated metal on the back. If this is a standalone cabinet, and the back is needed to keep the cabinet stiff, you can (assuming you have the tools) cut out a rectangle in the back, keeping 4-6 inches of the current material on the 4 outside edges. Cover the opening you create with the metal.
Pictures would help.
Tom
Best is what you perceive it to be, not what others tell you it is.
tmnjus is offline
post #4 of 18 Old 06-14-2007, 12:15 PM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
My cabinet is very similar to this and has a "false" back and not needed for support. Although, the way my cabinet is positioned, you can see the back of it from other places in the room. It is not flush against a wall but at a 45 degree angle similar to a (K), with the back being the wall. The fans I have now can be positioned anywhere in the cabinet. I was thinking that I could use the perforated metal sheet in the front to replace the plastic glass and in the back to replace the fiber board cutout.
I did not realize that speaker cloth would not allow are to flow. I see it on all kinds of cabinet units.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #5 of 18 Old 06-14-2007, 02:48 PM
RandyFreeman's Avatar
You might be surprised at how much ventilation you can get by putting stick-on rubber bumpers on the inside of the cabinet doors to keep the cabinet doors slightly open. If one isn't enough, try stacking up two.
One more idea. I've used the cane which is used for chair seats to ventilate cabinet doors. It looks good, it's strong and it allows for lots of ventilation. You need to soak the cane in water and install it tightly. When the cane dries it shrinks and becomes very tight. It's not cheap but it looks very nice.
Randy
RandyFreeman is offline
post #6 of 18 Old 06-14-2007, 08:32 PM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Randy
You're are correct, I'm surprised. I'll pick up some rubber bumpers at the store tomorrow. I'm confused by the "cane" idea, can you explain in more detail? How do you attach the cane to the door, glue or nails? Thanks for the advice.
Mike
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #7 of 18 Old 06-15-2007, 02:01 PM
Hi Mike,
The chair cane is available in several different colors, patterns and widths. I like the look of the hexagonal pattern. Check with a good woodworking store in your area to see if they carry chair cane. There are also some good mail order sources for this material.
I've made a frame out of hardwood to mount the cane. Then I've attached the frame to the inside of the cabinet door. The cane gets very tight when it drys so it puts some strain on the frame. A strong hardwood frame is necessary to stop the frame from distorting too much. I've always stapled the cane to the frame using lots of 1/4" monel staples. After the cane was dry I used a good bead of yellow glue to permanently attach the cane to the frame. The staples were hidden behind the door frame. This probably works best if you build the cabinet or at least the doors. I would consider this a good project for someone who is an experienced woodworker.
http://www.wickerwoman.com/seatweaving.html
Best regards,
Randy
post #8 of 18 Old 06-19-2007, 11:10 AM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Ohh, that's wicker. Thanks for the information.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #9 of 18 Old 06-19-2007, 12:17 PM
DonoMan's Avatar
I think what would look better would be to raise the glass away from the doors a bit and have it connected at the corners otherwise having a gap around the edges. And even then, I wouldn't rely on soly that for ventilation.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #10 of 18 Old 06-26-2007, 02:38 PM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
The glass is inset into the door. Is there a small tool that I can use to saw a couple of holes in the back panel? The back panel is made out of very think cardboar/fiberboard. Can I use a Dremel tool or something similar?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #11 of 18 Old 06-26-2007, 05:53 PM
tanneritekid's Avatar
I have raised panel solid oak doors on ours.
The back is a diamond pattering wire mesh from home depot painted black.
Rip that cardboard out, put in the mesh, attach a 120v fan from radio shack to the mesh. Plug the fan into the switched outlet on the A/V receiver.
tanneritekid is offline
post #12 of 18 Old 06-27-2007, 11:08 AM - Thread Starter
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Great idea, how see thru is the wire mesh? Curious because the back of my cabinet can be seen because it is not flush against the wall but at a 45 degree angle from the wall. Would hate for everyone to be able to see all my wires.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #13 of 18 Old 03-01-2015, 09:28 AM
Quoted: 23 Post(s)
I actually removed the back of the cabinet which allowed heat to escape up and out the back. Try this if it is possible, make sure it is structurally sound before placing tv on top. Great thread because heat is the enemy of electronics.
All animals are equal, but some are more equal than others
nextgenfmradio is offline
post #14 of 18 Old 03-02-2015, 10:42 AM
MOTILAC's Avatar
Liked: 3
Have any of you seen this product line?
http://www.activethermal.com/
They have some great products to deal with ventilation issues.
MOTILAC is offline
post #15 of 18 Old 03-10-2015, 01:42 PM
dangdude's Avatar
Menards of all places had really nice painted metal vents in their building section. They are the same width and maybe half the height of a typical HVAC vent, made out of stamped steel. I plan on using them (with 12v fans) when I cut vent holes for my future projector cubby & audio closet.
dangdude is offline
post #16 of 18 Old 03-26-2015, 11:20 PM
Quoted: 23 Post(s)
Well, I have basically moved my receiver to the top of my new component cabinet. Plenty of ventilation up there
I didn't like having it in a cabinet!
post #17 of 18 Old 03-26-2015, 11:34 PM
AUDIOgiant's Avatar
Quoted: 365 Post(s)
Liked: 83
i have a projector setup and my solid wood AV console sits below the screen. All of my electronics sit on top because I've been lazy about putting a false back on my console. What annoys me, though, is that when I've been running the setup for some time I can begin to see the "shadow" of the hot air exhaust coming out of may various electronics. I only imagine this will be more concentrated and visible if I were to put all my electronics in the console and vent the exhaust out a false back.
Has no one else noticed something similar in their setup?
And is everyone just venting the exhaust out into their viewing room or does anybody have some creative ideas for this?
AUDIOgiant is offline
post #18 of 18 Old 02-04-2016, 10:50 AM
John Megadeth's Avatar
My solution
I'm still in the process of modifying the media center, but I recently replaced the wood backboard with a custom-cut piece of pegboard. I did so for two reasons--to provide better ventilation and to secure cables and power supply units to the rear. I also replaced the tempered glass panes in the lower cabinets with solar screen mesh. Note that the power center is not yet complete, as I need to do some cable management. The surge protector is remotely controlled by a switch I installed in the console of the theater seating. Unrelated to ventilation, but I installed some heavy-duty casters (I forget what weight they're rated at) on the bottom.
hpp8140 likes this.
John Megadeth is offline
Reply Tweaks and Do-It-Yourself
