Please Help!? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-25-2007, 07:46 AM - Thread Starter
axellagerlf's Avatar
Hey you guys, you gotta help me out on this one!:
I cleaned out my Panasonic AE300, the same as L300u)
and I did so, successfully as far as I can tell, however I scratched the polarizers with the Q-tip I was using didnt even think u could do that....
So now the projected image is all blurry, but I can still see that I got rid of the green tint...
Is there anyone out there who knows how to polish these things? I mean its just plastic right? is there any substitutes to these that i can use?
Please You Gotta Help Me, its an expensive piece of hardware....
axellagerlf is offline
post #2 of 10 Old 06-25-2007, 02:40 PM - Thread Starter
Please You Guys, Help Me!
post #3 of 10 Old 06-25-2007, 03:10 PM
11001011's Avatar
If they indeed are scratched then sorry to say, you just learned an expencive lesson.
What did you clean it with? (besides a Q-tip)
Could it be that there was some kind of film left behind?
A 'phile and his money are soon parted...
11001011 is offline
post #4 of 10 Old 06-26-2007, 04:24 PM - Thread Starter
Well I saw that some of the dust had dried on it so I used a little water on it together with the q-tip, that mustve been what caused the scratches, I recently scrathed one of the polarizers so bad now that its rendered useless(it accidently was grinded against a cable)...
But shouldnt there be Some kinda way that you could fix this, I mean theyre not very deep..... I have called some optics but theyve been reluctant to the idea of polishing it for me...
All the 3 of them need polishing on both sides isnt there anyone out there who has fixed something like this? what substance did you use?
Or is it by any chance possible to use some kind of subsitute to the polarizers such as cutting out those round ones you use in cameras.
in that case, are there any labels on these type of shades? because optics should be able to cut out a small piece from one of those..
Just type polarizer on google ,scroll down and youll see one of those..
post #5 of 10 Old 06-27-2007, 02:54 AM - Thread Starter
Does anyone here know if the AE100-Ae200 (same as L100u-L200u uses the same polarizers as in the AE300 (same as the L300u)
post #6 of 10 Old 06-27-2007, 08:45 AM
Targus's Avatar
Sure, you just have to re-etch the precision microscopic grooves in the polarizer...polishing it accomplishes the opposite of what you want.
Targus is offline
post #7 of 10 Old 07-02-2007, 01:23 AM - Thread Starter
Please explain!?
post #8 of 10 Old 07-02-2007, 04:48 AM
Gir_1337's Avatar
Think of a venetian blind. They have little grooves in them that absorb the light horizontally or vertically. If you were to take two polarized lens, put them together and keep twisting them, when they grooves are at 90 degrees from each other, no (or very little) light passes through.
Gir_1337 is offline
post #9 of 10 Old 07-02-2007, 06:20 AM - Thread Starter
And what do you mean by re-etching them? Is this an easy-to-fix problem?
What should I do to make the scratches go away?
post #10 of 10 Old 07-02-2007, 07:33 AM
Gir_1337's Avatar
He was being rhetorical. You're not going to be able to fix these, they need to be replaced.
Gir_1337 is offline
Reply Tweaks and Do-It-Yourself
