How Big is to big? Samsung's 85-inch 4K S9 Ultra HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-08-2013, 05:33 PM - Thread Starter
IfixitBIG's Avatar
Samsung has revealed an 85-inch 4K Ultra HDTV. While I'm sure the 4K image is stunning, people seem to really be fixed on the "floating design".
The metal frame reminiscent of an easel holds 120-watt 2.2 speaker system that surrounds the display. The TV also features Samsung’s new Smart Hub software, voice control, gesture control, set of locally dimmed LED-backlights, app support and S-Recommendation.
A TV this big presents more than a few problems. Throw price, and features out the window. You have to ask yourself, "Where do I put it?" " How do I get it through the door?" " Where do I put the center channel?" "Is the wife going to let me keep it?"
So do you go for this beast, or do you look to a projector and screen?
Read and discuss!
http://techglimpse.com/index.php/samsung-85inch-4k-tv-floating-metal-frame-largest-hdtv.php
John Burton
IfixitBIG is offline
Reply Latest Industry News
