Why UltraHD is Not 4K - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 01-11-2013, 06:09 AM - Thread Starter
VinnyS's Avatar
Liked: 54
Source of picture
UltraHD and 4K have been the big talk at CES this year and it seems the terms has been getting some mix up.
But for industry pros, all the talk about 4K being UltraHD, and vice-versa is heresy.
Forbes spoke with an industry expert in both pro and consumer video topics Patrick-Pierre Garcia, who states;
The UltraHD format has a horizontal resolution of only 3,840 pixels whereas the 4K format has 4,096 pixels. There’s nothing secret about this. UHD and 4K are official formats and I don’t understand why the CE industry is confusing consumers by calling UltraHD products, 4K.
The confusion might even delay the adoption of UltraHD.
Here's some fun facts to help clarify some of the mix up:
1. 4K is the format used by professionals (movie studios, TV channels…) to create content and has a resolution of 4096 × 2160. It replaces 2K and will be replaced by 8K
2. The UltraHD format was voted by the Consumer Electronics Association (CEA) last October and refers devices with a horizontal resolution of at least 3,840 pixels. Sharp also calls QuadHD
3. And what about 4K UltraHD or UltraHD 4K? Well, these are marketing gimmicks not based on any kind of reality says Garcia
So I guess consumers will be buying UHD Displays and watchig downscaled 4K Content. So even after spending a couple of thousands of dollars to watch what?....downscaled content?
Source
Get all your A/V News at: AVS Latest News
Like AVS Forum on Facebook
Follow AVS Forums on Twitter
AVSForum
Bringing the AV Community Together
VinnyS is offline
post #2 of 40 Old 01-11-2013, 11:54 AM
Flavius's Avatar
Liked: 46
Why did they bother with such a small difference to begin with? All it does it confuse people. Talk about not being willing to go the extra mile and add 200 measly lines of pixels!
I thought I was going to be able to get the true cinema resolution 4K experience at home, so this is pretty lame, even if minor.
gonzo90017 likes this.
Flavius is offline
post #3 of 40 Old 01-11-2013, 12:06 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
It is understandable if it cuts cost, I don't think one would be able to tell the difference between the two. So it's all good to me. I am still on the fence wether we need this or not but once it's affordable I will be buying a 4K or UltraHD Passive 3D set.
I have a 42" Hitachi plasma with the res of 1024 x 1024 purchased in the early days of HD and it still looks fabulous. Rivals my native 42" Sharp 1920 x 1080 LCD set but that's due to the deep blacks of a plasma and the size. I do own a 55" Vizio as well and all the files that once looked good on the 42" sets at 720p now look less impressive on the 55" Vizio LED.
Size makes you need the higher res but with a 200 pixel difference I don't think you will notice other than the obsession with having the set with the higher number pixels...
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
post #4 of 40 Old 01-11-2013, 12:14 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 49
The reason for the resolution(pixel count) difference is due to the aspect ratio. 2K, 4K and 8K are more closely based to aspect ratio of 35mm film so they can caputue all the information contained in a frame. The aspect ratio of 35mm is close to the standard flat aspect ratio of 1.85:1. The aspect ratio of HDTVs is slightly less at 1.78:1 or more commonly referred to 16:9. So that is the main difference. The CE industry had no intention of slight change of aspect ratio for consumer 4K, UHD, QuadHD or whatever they end up calling it.
This brings up a slight quandry when transferring titles from the theatrical masters due to the slight difference in the pixel resolution between 2K and 1920x1080 and it will be an issue again on 4K to UHD.
Option 1
Basically in the transfer process you could just take a subset of the pixels (1920x1080) from the center of the slightly larger 2K image. This is basically cropping. The downside is that you sacrafice a little of the original image. Aspect ratio purists tend to lose sleep over this, but in reality it is no way like throwing away a quarter to half of the image when our TVs had an aspect ratio of 1.33:1. This approach yields a very sharp image since there is no interpolation/scaling involved.
Option 2
The other approach is scale the original 2k image in its entirety. The benefit is that the original aspect ratio is saved, but the bad part is that the original aspect ratio and the one that it is being scaled to are so close and yet slightly different that the resulting quality is entirely dependent on the quality of the scaling algorithm. The sad fact is unless you are scaling in integer values in either direction that no amount of the original information remains in your resulting image.
This is exactly why UHD, QuadHD is exactly 2x(1920 by 1080) the number of pixels in each axis . It makes it much easier for the scaling algorithms to work on 1080 content in the new UHD sets. You basically say its line doubling. An old trick applied to a new format that requires minimal processing power.
The general concencous from professionals is that the higher quality image is from option #1 especially when dealing with flat (ie non scope films).
With scope films there will alway be scaling involved if we want to retain the original aspect ratio since our displays are going to be based on the HDTV aspect ratio for the forseeable future.
Justinicus and nuisance like this.
Toknowshita is offline
post #5 of 40 Old 01-11-2013, 02:18 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
SD vs HD vs UltraHD (QuadHD in the pic) vs 4K
PlayNice is offline
post #6 of 40 Old 01-11-2013, 02:41 PM
trackmaster1's Avatar
IT IS FOR 4K BUT IT JUST NOT NATIVE, IT IS FLAT CROPPED4K UHDTV , NATIVE WOULD BE 4096 × 2160
4K UHDTV (2160p) has a resolution of 3840 × 2160 (8.3 megapixels), 4 times the pixels of 1080p
trackmaster1 is offline
post #7 of 40 Old 01-11-2013, 02:54 PM
Quoted: 37 Post(s)
Liked: 49
The reason you are not getting native is because of the aspect ratio. They aren't going to change aspect ratio for content that isn't even available yet. 16:9 is going to be the standard aspect ratio for a long time.
post #8 of 40 Old 01-11-2013, 03:03 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
A few sets today mostly monitors vs TV's use the 16:10 ratio i think it will be the same with 4K only a few will adopt this and go 16:10 either way it’s not that noticeable and shouldn’t be an issue when buying a new set.
PlayNice is offline
post #9 of 40 Old 01-11-2013, 03:36 PM
Quoted: 37 Post(s)
Liked: 49
Except 16:10 is going in the wrong direction if we want to keep a native wider aspect ratio.
2K, 4K, 8K have ARs that are roughly 1.9:1. HDTV/UHD is 16:9 or 1.78:1. The bastardized computer 16:10 ratio is 1.6:1.
post #10 of 40 Old 01-11-2013, 05:07 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Ok I see what you are getting at but I don’t think you see what I am getting at… I am saying the aspect ratio and resolution is so minuscule it won’t matter.
4096x2160 is 16:8.4375 and 3840x2160 is 16:9 when you have a TV set or Projector up on the wall no one is going to notice the half of a decimal missing or gained. We will be in awe of the outstanding clarity though.
PlayNice is offline
post #11 of 40 Old 01-11-2013, 06:01 PM
DaViD Boulet's Avatar
Liked: 41
Option 1
Option 2
Best post so far.
Good (or bad?) news is that many 1.85:1 films are "cropped" to 1.78:1 (16x9) already to make a simpler transition to HD. So that trend is already there and should carry over to UltraHD convesion from true 4K preserving pixel integrity.
I personally hope that this approach is adopted as I'd rather lose a minicule amount of left/right info that would have been matted out in the theater anyway than risk the compromise of recalculating the entire pixel domain.
As far as 2.35:1 films are concerned, I keep dreaming of a "native 2.35" or "20x9" or something encoding format in the future so our software could be "native" 20x9 and allow for downscaling on-the-fly in consumer hardware like we did with 16x9 DVDs on 4x3 TVs. Then for high-end home-theaters able to run native 20x9, they'd have significanly more detail than standard "letterboxed" Ultra-HD images. Imagine Ben-Hur in native 20x9 "4K" (naturally that encoding would extend the horizontal resolution beyond the UltraHD spec to widen from 16x9 to 20x9). It could be called "UltraHDW" or something. smile.gif
1080p and lossless audio. EVERY BD should have them both.
DaViD Boulet is offline
post #12 of 40 Old 01-11-2013, 06:12 PM
mr.marts's Avatar
Heres my 2 cents on the matter I think the timing is wrong after the failure of 3D and the fact that many people did not want to upgrade their TV with a failure to understand the 3D new technology, introducing a new technology which is not even developed is pointless and will further add to the confusion for consumers wanting to upgrade their TV sets today. What i believe they should have done is introduce a glassless free 3D TV as it seemed to a popular amongst the consumer rather than the facade of glasses, and in the meantime further developed upon a Ultra HD. I just hope that when the 4k tvs hit mainstream they either get rid of the gimmick of 3D (active and passive) or make it glassless free.
mr.marts is offline
post #13 of 40 Old 01-11-2013, 06:24 PM
Liked: 41
Technology can't evolve into mature deliverable products overnight just because we wish it so... autoscopic 3D has some difficult challenges that are still being worked out and won't really be "ready" for a while (though hopefully some compromised, yet "good enough" for non-videophile solutions will be availale this year). But guess what... many autoscopic technologies benefit greatly from added screen resolution, so autoscopic-3D and 4K aren't mutually exclusive R&D investments. Passive-Polarized 3D and 4K resolution are also good friends (one way of getting "full 1080p HD 3D" from a passive set). win-win.
post #14 of 40 Old 01-11-2013, 09:06 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Really? 200 some od pixels is the big hang up? It's close enough to 4k, jeez people.
Lumenlab "Community driven video lab".
blake18 is offline
post #15 of 40 Old 01-11-2013, 09:42 PM
w1retap's Avatar
Quoted: 52 Post(s)
Liked: 51
For televisions going taller is of course the wrong direction to take things, since most movies are shot in a wider aspect ratio. But as far as computer monitors, having a vertical resolution that is taller is wanted by many including myself, just due to the vertical real estate needed for reading documents, photo editing, having room for complex menu's and many other things. I deliberately purchased computer monitors that had 1920x1200 instead of 1920x1080 just because it makes such a big difference without having to turn a monitor vertical.
w1retap is offline
post #16 of 40 Old 01-12-2013, 01:49 PM
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
Why can't they give me a 100 inch screen of my choice, either 16:9 or 2:35:1 and have it be Kuro PQ??? I BE HAPPY
They can keep their 8K or 24K. Who cares..
Bardia is offline
post #17 of 40 Old 01-12-2013, 08:42 PM
cid67's Avatar
If they gave me a set that was a cinema scope native 4k resolution that conformed to the D-cinema standard out of the box with some kind of masking system id start saving right now.
With a built in hard drive that received content right from the same network that the D-Cinema equipped movie theaters get there digital content the studios could have a viable option to replace theaters without sacrificing a thing. this is the future in my opinion.
cid67 is offline
post #18 of 40 Old 01-12-2013, 10:25 PM
pokekevin's Avatar
Liked: 102
What about the differences in color space...
I know a few professionals were explaining to me how UltraHD doesn't use the same color space as 4k DCI (p3 i think?)
pokekevin is offline
post #19 of 40 Old 01-13-2013, 01:05 PM
Phil Wheeler's Avatar
I don't know what I think of glass-less 3D; there's not much content of value out there (I own one of the best disks, Avatar) -- and there seems to be very little broadcast 3D content.
That seems to be the biggest problem with "4K": Content. Will the existing over-the-air, cable and satellite bandwidths support the much-higher bandwidth of 4K? Or perhaps there is some technical magic I've not yet heard about.
Phil
Phil Wheeler is offline
post #20 of 40 Old 01-13-2013, 03:31 PM
BAMABLUHD's Avatar
Quoted: 68 Post(s)
Liked: 127
Basically, all of this confusion sounds like the chatter surrounding HDTV about 10 years ago....
What it all means is anyones guess, but I won't be an early adopter this time. I went HD in 2005, and although I am glad that I did, it may still have been early.
I like the progression of tech, and I look forward to 4K and 8K in the home one day, as I may be one of the lucky ones with a Man Cave, so the wife doesn't care about the size of the TV.
However, the confusion, cost, and mystery surrounding content delivery will make the adoption of 4K very slow I think.
The prices will drop soon, but the bandwidth issue is a long way to being solved. I personally don't like compression, even though I am forced to deal with it, (DirecTV MPEG 4, iTunes, etc). It seems that most others don't seem to care and don't notice the difference.
UltraHD, or 4K? Neither will matter much in the consumer world for at least the next 5-8 years. For those of you who move forward within the next 2 years, good luck, as I'm rooting for you.
LG 65B6 OLED 4K HDR| Pioneer ELITE VSX-52 | Samsung K8500 4K Blu Ray | Polk Audio RTi and CS2 5.1 | Video cables by Monoprice! Audio cables by Audioquest
PS4 | Apple TV | Sonos | Amazon Echo
BAMABLUHD is offline
post #21 of 40 Old 01-14-2013, 09:16 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
Heres my 2 cents on the matter I think the timing is wrong after the failure of 3D ...[snip]
What? Did I miss a board meeting? 3D failed? I suppose DTS 7.1 and Dolby 7.1 failed as well, since you didnt buy extra speakers...
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #22 of 40 Old 01-15-2013, 06:56 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 306
This entire mess is really nauseating to me. Hard to imagine them devising a way to defuse public interest in the whole thing any better than they have so far.
Forget it- for me, anyway. I'm simply going to buy one of these absurd-performing $1000 projectors and "suffer" with it for a few years until this is all sorted.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #23 of 40 Old 01-15-2013, 06:43 PM
mcnabney's Avatar
Already solved. h.265 can cut the required bandwidth in half. So that means that a 2 hour 4K/UHD movie can fit on on a 3 or 4 layer BD. Broadcaster dial the compression up even higher to fit it into a 1080p slot with minimal distortion.
mcnabney is offline
post #24 of 40 Old 01-15-2013, 07:16 PM
wuther's Avatar
Quoted: 579 Post(s)
Liked: 139
StereoVision was trotted out after 2 decades of slumber purely to make more money then mono films. It failed by a lot to do so, it's rare to see a breakdown but from what I can tell the mono version of the same film still makes more money and the films not in StereoVision rake in more cash overall.
The often claimed 'all films will be in StereoVision' (and TV) statement is something that clearly will not happen.
wuther is offline
post #25 of 40 Old 01-16-2013, 01:04 PM
Quoted: 747 Post(s)
Liked: 649
Anyone can look up box office receipts and see the breakdown. 3D is alive and well, and some movies will do better than others, 3D or not. According to Boxofficemojo.com, R-rated movies were down 13.5% in 2011. Does this mean R-rated films have failed? rolleyes.gif Not every film is in 3D, nor does every film necessarily do better because it is in 3D. This doesn't denote failure of 3D, just as choosing to watch a film in Dolby 5.1 (or in mono on your cellphone) doesn't denote a failure of 7.1.
I don't know what you're talking about when you state 'all films will be in StereoVision', as I've never seen that claim before. 3D is just another choice in the marketplace, just as 5.1 or 7.1 surround, or even extra butter on your popcorn. The fact that it isn't chosen by EVERYONE doesn't make it a failure.
Anyway, we are way off-topic. There are plenty of threads for debating the viability of 3D. without polluting this one further. Let's move on.
post #26 of 40 Old 01-17-2013, 02:26 PM
Oscar Goldman's Avatar
When the HD "standard" was decided upon in the U.S., people pointed out that 16:9 doesn't match ANYTHING. No theatrical format used this aspect ratio, which set us up for the continued compromises and incompatibility of our acquisition formats and TV presentation.
But then, what do you expect when we still have 1930s interlacing and 1950s non-integer frame rates in our digital TV system?
Oscar Goldman is offline
post #27 of 40 Old 01-17-2013, 05:14 PM
Quoted: 747 Post(s)
Liked: 649
16:9 was selected as the fairest compromise between all of the aspect ratios, because all ratios, from 4:3 to 2.35:1 fit inside its rectangle.
post #28 of 40 Old 01-17-2013, 08:35 PM
HughScot's Avatar
As someone already said this is all so reminiscent of the early 2000s. Back then everyone was so concerned over a few pixels and 720p vs 1080i vs 1080p, but what really matters is how good the picture looks to the viewer. If you can't see it yourself don't worry about it. Whether it's 4k or UltraHD, if all else is equal can you see the difference?
Hugh Campbell
HughScot is offline
post #29 of 40 Old 01-18-2013, 10:33 AM - Thread Starter
VinnyS's Avatar
Liked: 54
I think it comes down to some people won't stop until they can get anything in a native format, whether it be audio or video.
AVSForum
VinnyS is offline
post #30 of 40 Old 01-22-2013, 07:47 AM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
Great. I knew I shouldn't have spent so much money on BluRay discs! Blu Rays on 4k tv's are going to look like dvds on your 1080p tv. I can't imagine what a 720x480 res movie would look like on a 4k tv. Is the answer not to adopt any type of tangible media and just go to subscription? I feel like BR's are just becoming mainstream now. I would imagine that we are probably looking at 2-3 years before 4k is reasonably priced, and maybe another 2-3 years before there is a considerable amount of 4k content? Starting to feel a little better.
johnBlanker is offline
Reply Latest Industry News
Ces
