Are 3D Printed Speakers to DIY for? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By CMonMan
  • 1 Post By CMonMan
  • 1 Post By WhskyTangoFoxtrt
post #1 of 30 Old 01-23-2013, 11:01 AM - Thread Starter
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4940 Post(s)
Liked: 8364
3D printing is becoming more popular, affordable and capable. This is exciting news for the DIY crowd - it promises to make advanced speaker and subwoofer building much easier. There are some DIY speaker builders who have talent that is undeniable, but most people don't have the tools or the skills required to create enclosures that compete with high-end commercial offerings. 3D printing promises to change that by eliminating the need for woodworking skills. The potential exists to create radical designs in terms of how the interior cavity is engineered, incorporating ports and bracing that would be difficult or impossible to create with traditional methods.
After doing a bit of digging, I found some interesting examples of how 3D printing is already empowering DIY speaker and subwoofer designers. 2014 is going to be the year of the first-ever 3D printed house. Imagine the possibilities that presents a DIY home theater buff. For now, let's look at what's already possible:
Dodecahedron speakers are a popular 3D printed DIY speaker project
At normal listening distances, an array of twelve speakers arranged on the faces of a dodecahedron is a very good approximation of a point sound source, and the sound waves it produces are very close to perfectly spherical.
http://www.instructables.com/id/A-Dodecahedron-Speaker-for-Desktop-Printers/
Check out this gorgeous bookshelf/desktop speaker enclosure that was created by some good folks over at AutoCAD.. The entire enclosure - including openings for the drivers and details like screw holes - was 3D printed in one shot.
. The speaker enclosure is a combination of flexible and rigid material, printed simultaneously, so no assembly was required. All that had to be done was to install the actual speaker drivers themselves into the enclosure. The result was a high performance speaker with great acoustical properties.
http://labs.blogs.com/its_alive_in_the_lab/2012/10/3d-printed-speaker-made-at-the-office.html
I found this enigmatic slo-mo video on YouTube - It claims to be a rotary subwoofer built primarily with 3D printed parts. Unfortunately there is no link to a build thread or any other information
Rotary subwoofer, 16.5" (420mm), created primarily with my 3D-printer. Recorded at 480 fps. It will start 'woofing' at around sec. 15 at about 22Hz.
You can see the door to the garage (in which it was fitted and which was fixated) moving as a result.
The 'Sway' portable speaker is based on a housing constructed of 3D printed parts
Sway is designed so the user can customise parts to reflect their own personal style. The speaker grills have changeable designs, along with a silk layer that adds a splash of colour and protects the electronics. Being able to influence the look of the music player helps build a stronger attachment to the device and encourages people to think of electronics as something to be treasured.
http://www.core77.com/blog/object_culture/move_over_jambox_vintage_via_3d_printer_in_sway_portable_speaker_22759.asp
Here we see an interview with a systems engineer at Harman International about 3D printing and product development. There is a lot of promise for DIY folks interested in experimental waveguide designs.
Robert Scoble interviews Charles Sprinkle, a systems engineer at Harman, a maker of audio equipment. Sprinkle uses Arduino and 3D printing in the design, testing and improvement of new speakers at Harman.
ZDnet discusses 3D printing in general
It paves the way for prototypes to be designed more efficiently and the cost of adoption is falling, but for 3D printing to reach mainstream adoption, its use must first be simplified for the non-technically savvy
http://www.zdnet.com/3d-printing-heads-toward-mainstream-7000010176/
Mark Henninger
imagic is online now
post #2 of 30 Old 01-23-2013, 12:13 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I wonder how expensive it will be to do? Hopefully not as expensive as a milling machine.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #3 of 30 Old 01-23-2013, 01:51 PM - Thread Starter
imagic's Avatar
Liked: 8364
At any given size/capacity, 3D printers cost something similar to a CNC milling machine of similar capacity, or less. The price of 3D printers is dropping while capacity is increasing at a higher rate than with CNC milling, plus there are different capabilities to consider: Since 3D printers can create enclosures that are hollow and incorporate ports and bracing, complete speakers can be created in one shot from a digital plan... which would need to be done in parts or layers with CNC and that would be much more challenging - and in the case of some designs almost impossible to accomplish. It's a very bright future for DIY speaker designers.
Mark Henninger
post #4 of 30 Old 01-25-2013, 12:29 AM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I was looking at 3d printing online and I don't quite understand how it works. Would a speaker be made out of plastic? Does it melt the plastic to make it solid?
ellisr63 is offline
post #5 of 30 Old 01-25-2013, 01:22 AM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
From the above video ... I take it the 3d printing would only be for making small plastic parts?
ellisr63 is offline
post #6 of 30 Old 01-25-2013, 03:02 AM - Thread Starter
imagic's Avatar
Liked: 8364
The two applications I see are for speaker enclosures and for waveguides. Current, affordable machines are size-limited to about 6"x6"x10" although much larger machines exist. Once the Makerbot units get to 12"x12"x18", DIY bookshelf speaker enclosure designs will be possible.
Indeed that's what the machines do. Think inkjet printer, but with melted plastic coming out the nozzle.
Mark Henninger
post #7 of 30 Old 01-25-2013, 08:56 AM
filmphile's Avatar
I'd try it! I'm excited about 3D printing.
filmphile is offline
post #8 of 30 Old 01-25-2013, 03:11 PM
mani's Avatar
Quoted: 14 Post(s)
You can print in 3D with different materials. 3d metal printing has been going on for some time now. There was news on cnn.cm yesterday I believe , where some one is printing entire house and very unique looking as well.
http://production3dprinters.com/slm/direct-metal-slm
http://3dprintingindustry.com/2012/12/05/supersized-industrial-3d-printing-in-metal/
I am sure they are very expensive , but hopefully in near future it may be possible to email your 3d CAD drawings and get something printed in metal or other materials for a fee.
mani is offline
post #9 of 30 Old 01-25-2013, 06:16 PM
benclement11's Avatar
So is this something you could veneer? Who wants plastic speakers?
I know Jay Leno has a 3D printer. He bought it from a company my friend works for in Minneapolis.
He uses it for car parts that can't be bought anymore...like stuff for his really old rare cars.
Adam Carrolla has talked about having him do stuff for him before.
I would agree 3D printing is very exciting on a lot of fronts.
I don't understand it all, but like i mentioned earlier....I don't want speakers built entirely out of plastic.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #10 of 30 Old 01-25-2013, 06:32 PM - Thread Starter
imagic's Avatar
Liked: 8364
Iris, pioneers in Giclee printing, have a 3D system that uses paper pulp. The detail and precision is amazing and it is full-color. It might not be MDF but it points to a future where wood-based 3D printing is an option. http://blog.ponoko.com/2012/12/01/new-paper-based-iris-3d-printer-to-be-used-in-new-staples-3d-printing-service/
Mark Henninger
post #11 of 30 Old 01-25-2013, 08:45 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Would a speaker that was made from a 3d printer be strong enough to withstand a sub backwave?
ellisr63 is offline
post #12 of 30 Old 01-27-2013, 04:37 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Leaving aside CNC programming costs, which would alone would make CNC more costly, the costs are inverse in the sense that with CNC you pay for the material you start with plus how much you remove, with 3D printing (dunno about the new paper one), you pay for the net volume of material you end up with.
Probably; max pressures in sealed/ported are a few tenths of a psi, though quite a bit higher in bass horns.
Noah
noah katz is offline
post #13 of 30 Old 01-27-2013, 08:13 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I found this video that explains the 3d print process for metal...
http://www.youtube.com/watch?feature=player_detailpage&v=i6Px6RSL9Ac
ellisr63 is offline
post #14 of 30 Old 01-27-2013, 08:22 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
And here they actually make a bike...
http://www.youtube.com/watch?feature=player_detailpage&v=hmxjLpu2BvY
ellisr63 is offline
post #15 of 30 Old 01-29-2013, 12:22 PM - Thread Starter
imagic's Avatar
Liked: 8364
Engadget just published a 3D printer roundup with MSRP (or Kickstarter Contribution) and 'working area' listed. http://www.engadget.com/2013/01/29/3d-printer-guide/#continued
Mark Henninger
post #16 of 30 Old 01-29-2013, 04:33 PM
CMonMan's Avatar
Liked: 34
Think I'm going to buy a 3D printer, print a 3D printer with it and sell it. BOOM free 3D printer.
ellisr63 likes this.
CMonMan is offline
post #17 of 30 Old 01-29-2013, 07:38 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
ROFL.....
Can you print one for me too after you get your free one?
ellisr63 is offline
post #18 of 30 Old 01-29-2013, 07:53 PM
CMonMan's Avatar
Liked: 34
I don't see why not! lol
CMonMan is offline
post #19 of 30 Old 01-29-2013, 07:53 PM
CMonMan's Avatar
Liked: 34
uniquepattern likes this.
CMonMan is offline
post #20 of 30 Old 02-22-2013, 09:14 PM
Hmmm. I like the way you think. That had never occurred to me.
post #21 of 30 Old 02-22-2013, 09:15 PM
nice.
post #22 of 30 Old 03-04-2013, 02:15 PM
Matt Oldham's Avatar
Our company recently acquired a (DMLS) Direct Metal Laser Sintering Machine (3D metal printing) our build envelope is approximately a 12" cube. No info on our website yet but I am happy to quote 3D metal printing from 3D CAD Files. www.acrotool.com
info@acrotool.com
Matt Oldham is offline
post #23 of 30 Old 07-12-2013, 07:42 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
A desktop speaker that is (almost) completely 3D printed.
http://www.geek.com/news/designer-3d-prints-a-desktop-speaker-in-9-hours-1561800/
imagic likes this.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #24 of 30 Old 07-12-2013, 08:46 AM
Ziegler's Avatar
3D printing has been applied to many fields.
Ziegler is offline
post #25 of 30 Old 12-22-2014, 03:14 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
Came across this:
SpeakerGen - Parametric 3d Printed Speaker Enclosures
This OpenSCAD / Thingiverse Customizer script lets you:
- Generate a box of any desired volume / ratio / wall thickness
- Determine optimal sealed box size for any driver using Thiele / Small parameters (Qts, Vas and Fs)
- Include cutouts for speaker / terminal (and screw holes)
- Include a bass port of any dimensions
Audio Geek is offline
post #26 of 30 Old 12-22-2014, 04:18 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
Now this is really interesting ... something that's not easy to DIY.
Project NOMOON - A Parametric Spherical Speaker Generator
NOMOON is a parametric spherical 3d-printed speaker generator created in OpenSCAD.
NOMOON
Orbital
Music-making
Opensource
Openscad-generated
Nihilator
Click here to access NOMOON on thingiverse.
NOMOON is loosely based on my previous OpenScad speaker generator - Speakergen http://nothinglabs.blogspot.com/2014...d-printed.html.
NOMOON can create spherical speaker enclosures of any volume. You can configure things like wall thickness, bass port dimensions, number of screw holes, etc.
NOMOON also includes a speaker stand. If your speakers tend to rotate forward in the stands - strategic application of a rubber band can solve this.
Why is this relevant for DIY speaker builders?
Loudspeaker Diffraction Loss and Compensation
Compare the diffraction losses on the different speaker enclosure shapes.
How about some DIY designs inspired by B&W?
post #27 of 30 Old 12-22-2014, 04:59 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
Hm. Realized that this thread is in the "Latest Industry News", not the "DIY Speakers and Subs" section.
I'll create a new thread ...
post #28 of 30 Old 02-14-2015, 04:47 PM
Owen81's Avatar
Genius! haha
Owen81 is offline
post #29 of 30 Old 08-18-2015, 06:18 PM
Liked: 0
Lol i want ones!
Ddbizkit is offline
post #30 of 30 Old 10-01-2015, 05:46 PM
bearberry's Avatar
Not a new idea
http://reprap.org/
bearberry is offline
Reply Latest Industry News
