Logitech Debuts Two Harmony Remotes - Ultimate and Smart Control - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 261 Old 12-31-2013, 04:31 PM
blueroomelectro's Avatar
I have a fairly spartan media setup yet it does everything I'd ask of a media centre, the Harmony Smart.
WMC7, Denon AVR & AppleTV3. Simple yet very effective.
As a bonus apparently it's possible to control WMC with bluetooth.
http://aps2.toshiba-tro.de/kb0/htd0602xa0000r01.htm
blueroomelectro is offline
post #242 of 261 Old 01-02-2014, 04:49 PM
pmcd's Avatar
Quoted: 13 Post(s)
I have a Harmony One now and a 659 before. Really like the One but the idea of the Smart Control was too much to resist so I went out and bought one with the remote.
1- works really well and the remote is fine
2- setting this up was overly complicated. In fact it was a nightmare and I had to complete it by hooking the base to my Mac. Instructions were poor. I can't imagine anyone with no Harmony experience performing the setup.
3- once you do get it set up then the unit is fantastic. Love the ability to define two purposes for most keys. Nice size for the remote too.
4- as good as the Smart Control is I returned it and got the Harmony Ultimate. The Smart Control remote would have been great had it been backlit. Also, the 8 device limit is odd.
5- importing settings from my Harmony One was easy on the first try but then after having to reset things I was unable to import anything. It seems to only work once . Documentation is really missing. myharmony.com would not let me complete the setup. I felt like smashing the unit. I hooked it up to my Mac. Didn't work until I unplugged and rebooted the computer. myharmony.com with its outdated Silverlight and crazy browser plugin permissions is a disaster until you get things working.
Tonight I will set up the Ultimate. Hopefully it will be smoother. I have never been through such a convoluted setup as with the Smart Control. To be fair, I didn't read the manual which was not something available when I went through the process.
Great product, really, but I absolutely abhor the setup instructions. And importing settings from my older Harmony One was more luck than anything else. Who knows if I still can?
I highly recommend either product, especially the Smart Control if backlighting is not important.
Sorry for the over the top comments about the setup. I have never seen anything like it.
Philip
pmcd is offline
post #243 of 261 Old 01-06-2014, 06:50 PM
cashishift's Avatar
Quoted: 13 Post(s)
Originally Posted by blueroomelectro View Post
Thanks for the tip, I'm going to look into it today. I wonder if it can wake up the WMC via Bluetooth.
Okay for wish number two: I wish the Harmony Smart could control my AppleTV3 via Bluetooth. smile.gif
You can, add it as a function.
I just set mine up the other day, it works awesome.
cashishift is offline
post #244 of 261 Old 01-15-2014, 06:56 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2483 Post(s)
Liked: 2263
a great product with a horrendous set up is not a great product.
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
post #245 of 261 Old 01-15-2014, 08:24 AM
As remotes go it's currently the cream of the crop. The web interface IMHO is easier than the iOS interface for initial setup. You basically plug in your equipment list and it'll generally work. Now tweaking it to work the way you want it to work might take some time. If you really wanted to you could treat it like a simple dumb IR learning remote.
Could Harmony's software be better, of course. Is there better out there now? Not that I'm aware of.
post #246 of 261 Old 01-16-2014, 12:21 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 986
I wouldn't go quite that far. It's a nice, simple RF remote, and the smart phone aspect is a great bonus. But it's far too limited to deserve cream status (only 8 activities, no variables, subroutines or conditional branching, no pronto hex import, no display, no direct IR, only 2 functions per button, requires a smart phone for any additional functions or favorites). My $8 JP1 remote runs circles around it. Even my JP1 remote from 10 years ago runs circles around it. Software-wise, again, JP1 software is far better, and has been for years. As far as the smart phone side goes, iRule, Roomie and others are far more powerful as well.
Just in the Harmony lineup, both the Touch and Ultimate are far better than the Smart. URC and others have better remotes than the Smart.
I would only agree that it's the cream of the crop if your criteria was easy-to-program, no display, RF remotes with smart phone integration for under $100.
mdavej is offline
post #247 of 261 Old 01-23-2014, 07:31 PM
triadpc's Avatar
I'm coming from a Harmony 890 Pro RF remote w/ RF blaster/hub setup and looking at the new Ultimate remote as a possible replacement.
My setup is that I have my TV in a cutout area above the fireplace in my living room with all of my home theater equipment (AV receiver, Blu-Ray player, Cable box, etc.) in a closed closet in the same living room.
The 890 Pro works well, but my concern is that the Ultimate's hub only has 2 RF mini-blasters whereas the 890 Pro has 4 mini-blasters (with the plastic pieces that go over the "eyes" of each device and stick in place).
With my setup, will the Ultimate remote work with the hub installed in the closet with the rest of my home theater equipment and the TV outside of the closet, but in the same room?
There is no direct line of sight from the TV to the closet, hence why I've been using the 890 Pro for several years (and it works really well).
I downloaded the user guide for the Ultimate remote and it shows one of the mini blasters being installed right next to the TV with the other mini blaster installed in the same cabinet/rack as the rest of the equipment.
Anybody got any feedback/suggestions?
triadpc is offline
post #248 of 261 Old 02-18-2014, 07:11 PM
TorinTPG's Avatar
The Ultimate remote does in fact have built in IR as far as I understand. This means that you could program the remote to control your TV via RF on the remote and then use the hub and blasters for the closet devices
"he other thing the Ultimate brings is an extra IR blaster and the ability to configure where the IR is emitted from: from the Hub's built-in emitters, the wired ones or directly from the hand-held remote. Setting it to emit from the remote does undermine the mobile apps, however."
In the setup, you can select which device is being controlled by individual peripherals: Remote, Hub, Blaster, or Hub and Mini Blasters
TorinTPG is offline
post #249 of 261 Old 02-18-2014, 07:13 PM
TorinTPG's Avatar
For those that are using the hub, how well does the IR blast from this device work? All of my equipment is on a bookshelf facing outwards. There is a wall to the right of them and a couch approx. 3 feet in front of them. I need at least two devices controlled via RF/IR blasters, but I'd like to have my AVR be "hit" with the hub or blasters as well
TorinTPG is offline
post #250 of 261 Old 02-19-2014, 07:49 PM
cadmium's Avatar
Just got one. So far so good. I have my hub about 8 feet away pointing in the general direction of my stuff.
I have a question though, does anybody know if the Smart Control will pair as a Bluetooth remote with a Vizio TV? So far, I haven't been able to figure it out.
cadmium is offline
post #251 of 261 Old 02-27-2014, 07:56 AM
rlb
rlb's Avatar
Quoted: 1787 Post(s)
Liked: 1458
No, its Bluetooth pairing is limited to a couple game platforms (e.g., PS3). It won't pair with my Samsung F9000 which has a Bluetooth remote. Luckily, the Samsung also has traditional IR support.
Samsung 65JS9500 and 65F9000 w/SEK-3500U, Denon AVR X3300 & Outlaw 755
Samsung K8500, OPPO 103-D, PS3, HR44, HR24, and Roku Ultra
rlb is offline
post #252 of 261 Old 02-27-2014, 10:58 AM
tgm1024's Avatar
Liked: 2263
I'm glad that more and more phones are showing up with IR blasters.  Unfortunately my Galaxy Note 2 doesn't have it.  :-/
-Mad Sweeney
tgm1024 is offline
post #253 of 261 Old 03-20-2014, 04:03 AM
blairy's Avatar
Quoted: 137 Post(s)
Liked: 72
I guess I got used to the myharmony web version with their other remotes. I'll give it a second look but for my minimal entertainment setup the hard button remote works fine. Yes the USB only sync for the PC kind of sucks. I've also got to try that bluetooth hack mentioned earlier, just seems so neat.
Wish #3: Harmony smart works via WiFi with IP controlled devices such as my Denon AVR.
Wish #4: WiFi sync with myHarmony
My Denon (AVR3808) comes with a web based app. You can access this via any web browser.
From a windows based device (PC/laptop/tablet) you could try Command3808. Software tool designed to control your denon.
blairy is offline
post #254 of 261 Old 09-28-2014, 10:53 AM
iserum's Avatar
Quoted: 122 Post(s)
Liked: 62
i got the remote, the HUB and IR blaster is placed in a different location on the other side of room on DVD rack, all equipment is in open Audio rack, both rack are almost placed parallel to each other, i was skeptical but it worked. TV is wall mounted over fire place, i was worried about TV most, but i have no problems with any of the equipment. So far so good, the setup is more tedious on iPhone as compared to PC. i hope it is done, it took me half hour to setup everything working now, I have been using Harmony remotes since they made first ones, own two Harmony One and one 650, 688 i traded in at BB to to get $100 coupon, sweet deal.
iserum is offline
post #255 of 261 Old 10-05-2014, 05:11 PM
bobpaule's Avatar
Quoted: 42 Post(s)
Liked: 53
I can reassure you that the 2 mini-IR blasters I purchased in anticipation of my Harmony Smart Keyboard are catching dust in the closet, so powerful is the hub's IR. This is in a home office with hub under display and receiver on side table, and no command ever fails.
bobpaule is offline
post #256 of 261 Old 09-27-2016, 08:46 AM
gonnapena's Avatar
Quoted: 18 Post(s)
Anyone get Smart Control to control more than 8 devices?
Has anyone gotten the Logitech Harmony Smart Control remote to control more than 8 devices? Are there any hacks or workarounds to get it to control more than 8 devices?
gonnapena is offline
post #257 of 261 Old 09-27-2016, 10:57 AM
mdavej's Avatar
Liked: 986
Learn all the commands for an additional device to an existing device.
mdavej is offline
post #258 of 261 Old 10-07-2016, 02:58 PM
lovingdvd's Avatar
Quoted: 2839 Post(s)
Liked: 600
Hi all - new owner of a Harmony Elite with hub here. I have a question please. The remote frequently complains that it's too far away from the hub. I then hit the back arrow and its fine again for like another x minutes. Then the same thing happens. This is with the remote just 5-10 feet away. In one case it happened while the remote was IN the cradle! The remote also seems to not send the signal right away. Like I'll hit left arrow and it may take 10 seconds before I see the menu on the equipment I'm controlling to move. Any suggestions? Thanks!
lovingdvd is offline
post #259 of 261 Old 10-07-2016, 08:49 PM
sddawson's Avatar
Quoted: 29 Post(s)
Certainly doesn't sound right. I'd get on to Logitech support. They've been very good when I've had the need...
sddawson is offline
post #260 of 261 Old 10-11-2016, 01:11 PM
Liked: 1
Originally Posted by jhoff80 View Post
<div class="quote-container" data-huddler-embed="/t/1468662/logitech-debuts-two-harmony-remotes-ultimate-and-smart-control#post_23220345" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>repete66211</strong> <a href="/t/1468662/logitech-debuts-two-harmony-remotes-ultimate-and-smart-control#post_23220345"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
I've loved my One. My only complaint concerns the web-based interface. Is it really that difficult to put it on a disc or allow the consumer to download it?</div>
</div>
<br>
It actually is half running locally. Before Logitech bought Harmony, it was complete web-based setup (except for the part to directly interface the remote with the PC) and it was actually faster then. They managed to bloat up the software and slow it down, while not even getting rid of the web-dependency.
Yes, web dependency can be problematic. Had a customer who wanted at his remote cabin.
Danny Malan is offline
post #261 of 261 Old 01-26-2017, 08:48 PM
Quoted: 100 Post(s)
Can i get by using ultimate vs elite?
zibaji is offline
Reply Latest Industry News
Logitech , Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
