Chromecast: Google in the Living Room, Take Two - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #481 of 487 Old 02-19-2015, 01:06 PM
Boothbay's Avatar
Yes, i am aware what it looks like and the size, but for some reason i do not see them. What bugs me is that i had set this up a month or so ago, d/l the apps and etc., but never went beyond that cause of personal issues kept me from doing so. Now, when I tried to use it, i thought all i had to do was plug in the cc and take it from there, but all I get is messages to set it up. ..but I already had...now when i clicked on your recent link, its asking me to set up again. Why wouldn't it recognize my previous setup? BTW, I was using the app that was prior installed on my N7-13...does that make a difference? Another thing puzzles me, if I want to use the CC on another TV...ie..my smart TV, do I have to go through another setup and etc and etc? Thanks
Boothbay is offline
post #482 of 487 Old 02-19-2015, 01:20 PM
Athlon646464's Avatar
Quoted: 46 Post(s)
Liked: 24
My tablet's not close by so I can't give you step by step instructions right now, but...
Power up your Chromecast with the wall wart that came with it. Don't rely on the TV's usb port's power for this.
When your Chrocast is powered up, go to your Chromecast app on your tablet. (I don't understand why you are mentioning 'another app' - there has only ever been one and it has been updated several times.)
Now find in the CC app on your tablet where you can reset your CC and start over. That should fix it for you.
LG OLED65C7 | Denon 2113CI | Klipsch 5.1 setup - 2 Forte - 1 R-25C - 2 R-14S
BA Sub w/Bosch amp | Sony BDP S570
Athlon646464 is offline
post #483 of 487 Old 03-03-2016, 11:18 PM
relay12's Avatar
Liked: 0
Question
I have a Chromecast1 on first WIFI network. From the phone (Galaxy S4) Youtube app gives option "cast to nearby device" when on second WIFI network but I never see this when I try Chromecast app and "cast screen" option when phone is on second WIFI network it just says "no compatible google cast devices" (ie it is not getting detecting guest mode even though Youtube does). If I switch phone to first WIFI network Chromecast app detects CC1 device as expected.
Is this correct that it won't cast using guest+pin method for "cast screen"?
relay12 is offline
post #484 of 487 Old 03-04-2016, 02:07 AM
jprc's Avatar
Quoted: 83 Post(s)
Liked: 120
That's correct. The CC and the phone have to be on the same wifi network to cast screen (mirror). It's not streaming the screen over the internet like when you are casting a Youtube video - it's casting the screen directly from the phone.
jprc is offline
post #485 of 487 Old 05-22-2016, 08:10 AM
Liked: 0
Actually mirroring isn't casting the stream directly from the phone, hence the requirement that they be on the same wifi network. The frames go via the router to the chromecast.
The explanation why guest mode doesn't support mirroring is simple:
- Guest mode is an ad-hoc network. To mirror, the Chromecast would have to support Miracast. Miracast is a PITA to implement, though in theory it should be faster than the LAN method the it currently uses.
- Conversely, if guest mode did support mirroring, then the Chromecast would be an unofficial 35$ Miracast dongle, which I believe are normally priced starting at 70$.
I said unofficial because it still requires the Google Cast app to mirror, whereas official Miracast is supported at the OS level in Android and Windows.
jayvl is offline
post #486 of 487 Old 09-03-2016, 08:04 PM
Liked: 0
Ordered one, thanks Google, hope to play my amazon prime from this little device.
Hitechhome is offline
post #487 of 487 Old 09-03-2016, 08:08 PM
Neil S. Bulk's Avatar
Quoted: 13 Post(s)
The Chromecast doesn't handle Amazon Prime.
Neil
Neil S. Bulk is offline
Reply Latest Industry News
Google Chromecast Hdmi Streaming Media Player , Google
