AVS Coverage of CES 2014 - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 354 Old 01-17-2014, 09:08 PM
Orbitron's Avatar
Quoted: 479 Post(s)
Liked: 355
Scott, why do you like the Vizeo Reference more than the Sharp 8K model?
Orbitron is online now
post #332 of 354 Old 01-17-2014, 09:24 PM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Originally Posted by Scott Wilkinson View Post
The Vizio Reference Series playing content graded for its Dolby Vision capabilities, no question in my mind.
Thanks Scott, did you see any of the Samsung displays?
vvuuren is offline
post #333 of 354 Old 01-17-2014, 09:50 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Resolution isn't everything...
vinnie97 is offline
post #334 of 354 Old 01-18-2014, 12:14 AM
Scott Wilkinson's Avatar
Quoted: 1330 Post(s)
Liked: 3875
As vinnie97 said, resolution isn't everything; in fact, it's probably not the most important thing, at least at "normal" screen sizes. Yes, the Sharp 8K looked amazing, but in my view, the Vizio beat it in terms of overall picture quality.
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
post #335 of 354 Old 01-18-2014, 12:16 AM
Liked: 3875
Yes, I looked at them extensively. They looked great generally (except for the curves, which I object to on all but the very largest screens). Samsung is the best in the industry when it comes to edgelit black levels and uniformity, but I still prefer FALD.
Scott Wilkinson
Editor, AVS Forum
post #336 of 354 Old 01-18-2014, 07:52 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Thanks Scott. Appreciate your response
vvuuren is offline
post #337 of 354 Old 01-18-2014, 12:03 PM
G-Rex's Avatar
Quoted: 435 Post(s)
Liked: 268
Kind of surprised Sony was caught sleeping and is going with 8 bit panels vs Vizio's Reference's 10.
In light of the Vizio being 10 bit, how much better would the display likely be (for future 4k BDP source and no computer/video game use) had it been equipped with the 18 gbps hdmi chip?
Was the difference between the Sony 950/900 and the Vizio Reference so obvious that the choice between the 2 will be easy?
How much content will be out there that will support the Dolby Vision tech? Any chance Netflix 4k streaming will? I would assume 4k bluray disc players will have this ability.
G-Rex is offline
post #338 of 354 Old 01-18-2014, 12:22 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2455 Post(s)
Liked: 2230
In light of the Vizio being 10 bit, how much better would the display likely be (for future 4k BDP sources) had it been equipped with the 18 gbps hdmi chip?
Yeah, I'm a little surprised myself that the bottom level panel can't handle more than 8 bits.  But in reality though, dithering neighboring color levels to achieve intermediate values is not as easy to detect as you might think.  Particularly at 4K.
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is offline
post #339 of 354 Old 01-18-2014, 12:28 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I may be wrong here, but with a temporal dithering scheme, wouldn't you sacrifice half the refresh rate capability of the display? (which would mean that content produced in higher frame rates might not be able to take advantage of the dithered bits)
spacediver is offline
post #340 of 354 Old 01-18-2014, 12:34 PM
tgm1024's Avatar
Liked: 2230
You'd want spatial dithering.  Not temporal.  Sony already has bit-depth upscaling to that effect, though I'm only beginning to understand everything it does.
And you're only dithering very close (or neighboring) values to get the effect of an intermediate level.
http://www.sony.net/SonyInfo/technology/technology/theme/8ido18000001pf69-img/8ido18000001pfd3.gif
tgm1024 is offline
post #341 of 354 Old 01-18-2014, 01:06 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
Wouldn't you sacrifice luminance resolution (relative to the original signal) if you used spatial dithering?
post #342 of 354 Old 01-18-2014, 01:46 PM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
Doesn't the display also have to have the capability to accept, process and actually display the 14 bits in order to improve PQ ? My Lumagen Radiance converts 8 bit to 12 bit for internal processing and sends 12 bit 422 to my Sharp Elite which accepts that as input. What the elite does with internally is unknown.
dsinger is offline
post #343 of 354 Old 01-18-2014, 02:32 PM
tgm1024's Avatar
Liked: 2230
I'm sorry, I don't understand the question.  If you have a panel that is fundamentally 8 bits, you can have software that drives it at high bitdepth by playing games such as dithering.  It's not perfect, but it's better than having contouring everywhere like my R550A does.  Yikes.
tgm1024 is offline
post #344 of 354 Old 01-19-2014, 09:40 PM
Mr Bob's Avatar
Quoted: 166 Post(s)
Liked: 98
This was LG's video wall, which everyone who was destined for the LG section was exposed to and had to walk through, to get in.
It was huge, dwarfing any one observer. It was comprised of 140 50" LG LCD panels, 7 panels tall and 20 panels across, with massive 3D images streaming across, around and through the truly massive array. Total immersion was effortless. Images flew out at you, flew past you, allowed you to look down into, floated with you in space... It was truly impressive. It required plastic LG 3D glasses which were given out by linen-gloved LG personnel, showing how good flat panels can look in 3D. No twin-projector setups, no opposing polarized filters in front of projector lenses - everything implementing the very impressive 3D was built-in to each panel.
Observers - shows about 1/3 of them in the first shot, the rest were to my left, off camera. My phone's cam (Samsung S4) did not capture that this is all in the dark, it made it look like it was fully lighted in there, but no it was actually very dark, the exact same lighting levels as you'd see in a movie theater. I have not explored my phone enough to know how to change the light level getting into the phone's camera lens, otherwise I would have stopped it down appropriately. So use your imagination, it was like being in a movie theater.
The shots I took of the wall itself had to be done through just one lens of the polarized glasses that were handed out up against my camera's lens, or they would have appeared as double images, which is what you would see whenever you took the glasses off.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
post #345 of 354 Old 01-20-2014, 09:31 AM
Quoted: 911 Post(s)
Liked: 489
Did you guys catch the Dirac "active room correction" demo?
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #346 of 354 Old 01-20-2014, 10:07 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Please tell us more.
vvuuren is offline
post #347 of 354 Old 01-20-2014, 10:32 AM
Quoted: 911 Post(s)
Liked: 489
Here's all I've seen:
Serious Audio Blog
DS-21 is offline
post #348 of 354 Old 01-21-2014, 10:29 AM
PhilipsPhanatic's Avatar
Quoted: 397 Post(s)
Liked: 52
PhilipsPhanatic is offline
post #349 of 354 Old 03-05-2014, 06:55 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
Sorry Scott but I beg to differ with you when you say Samsung is the best in the industry when it comes to edgelit black levels and uniformity. In my opinion Sony's HX850 and W900 beat anything Samsung put out.
steve1971 is offline
post #350 of 354 Old 03-05-2014, 10:59 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Can't what has definitively the best black levels be measured? I don't see what opinion has to do with it. Uniformity is a harder nut to crack objectively, I suppose.
vinnie97 is offline
post #351 of 354 Old 03-05-2014, 11:09 AM
Mr Bob's Avatar
Quoted: 166 Post(s)
Liked: 98
Vinnie -
Would love to see what you really meant to say, but right now I cannot make out your first sentence and what you are trying to say.
Oh wait. OK, I get it.
The black levels with strong white content present will be different from the black levels with a mostly dark scene, in terms of shadow detail and the ability to make it out. When we used to calibrate using the original Joe Kane VE disc, the Pluge pattern was incredibly valuable, but at CES one year Jim Doolittle pointed out to me that the following pattern was just as valuable. It was the pluge on the left side, against black background, with a 100 IRE all white field on the right side. It was very challenging to get the blacker than black bar to show, with that brilliant all white field there on the other side of the pattern. Sophisticated expensive ceiling projectors could do it with easy, the less expensive sets had a much harder time of it.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #352 of 354 Old 03-05-2014, 11:12 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Sorry, was awkwardly worded (could've done better for clarity's sake).
vinnie97 is offline
post #353 of 354 Old 03-09-2014, 12:54 AM
MorrenCraige's Avatar
seems like the top of the line tv's will be awesome but what if any enhancements have been made for mid level
MorrenCraige is offline
post #354 of 354 Old 03-09-2014, 05:43 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Originally Posted by monitormaven View Post
One can increase the apparent bit depth of an LCD panel via a technique called temporal dithering, wherein you repaint the image at a high refresh rate (greater than the eye/brain can detect) and change the intensity of a pixel during repaints. An gross example of this would be to make the whole screen white during one pass and the whole screen black during the next. This would give a 50% duty cycle and would result in a mid gray. The result is not linear, so there are algorithms in place to linearize the process. This technique is used on medical (radiology) diagnostic monitors to achieve 10 and 12 bit resolution which better approximates film. The "gothcha" is that the radiographs are static and TV images are dynamic. I really don't know if anyone has experimented with LCD TV images complete with motion smoothing augmented by temporal dithering. It might make for a flickering mess.
Samsung has some 6 bit +FRC LED /LCD SPVA TV panels I have one in my Sony KDL 40R450A surprisingly in spite of that it has a decent picture I'm not sure if it is handicapped
(or not ) as far as 2K displays go because of that but it looks fine maybe someone more knowledgeable than I would know?.
tubetwister is offline
Reply Latest Industry News
Ces 2014
