UHD/4K Quandary: To Buy or Not to Buy - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 689Likes
post #571 of 2384 Old 07-28-2014, 03:13 PM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
Originally Posted by losservatore View Post
Mark Schubin discusses 4K…and its problems.
I don't think Schubin's account of why 4k demands higher frame rates makes any sense. If there are twice as many pixels to move across, then for smooth motion the framerate has to increase?? Why?
The solution to getting past data rate limitations of HDMI is staring us in the face. We can already get 4k video to TVs over the network by using IP and by-passing HDMI altogether. So we should just eliminate HDMI in favor of local networks, wired or wireless.
Greg Lee
GregLee is offline
post #572 of 2384 Old 07-28-2014, 03:37 PM
sage11x's Avatar
Quoted: 729 Post(s)
Liked: 808
Originally Posted by Stereodude View Post
I was thinking more along the lines of how much stock can you put in the opinion of someone on things resolution and picture quality related when they think HD channels on cable look the same as Blu-ray.
I'll happily agree that it is possible to upscale 1080p to UHD and end up with a subjectively better result than 1:1 display of 1080p on a similar size screen. However, the algorithms to do this are extremely computationally intensive. These algorithms were not used in 1080p TVs for scaling SD or 720p. The standard billinear and bicubic scaling routines we find in TVs add ringing and soften the image.
Lets take a step back for a minute. It is also possible to make LCD panels without vertical banding, and make edgelit TVs that don't have clouding and flashlighting, but the CE companies don't bother to do so. The same TV makers who won't spend a little more to eliminate some of the more obvious flaws of LCD TVs have done an about face and decided to include these more expensive scaling algorithms in UHD sets when the vast majority of buyers wouldn't know the difference or even know they're present? They haven't bothered to fix the much more visible issues, but I'm expected to believe they're spending the money on very high end upscaling at the same time they're trying to dive the price of the UHD TVs and drive market adoption... I don't think so.
I couldn't agree more.
I often get made out as a plasma (only) fanatic but the truth is I just like good picture. The Sharp Elite proved LCD has some growth potential but it feels like we've drifted far away from the goal those displays set out to achieve. I'm sorry but it's inexcusable for a several thousand dollar LCD to have uniformity issues. Hell, my ancient Olevia 7 series has zero uniformity problems. I also expect more from a TV that costs several times more than my last plasma (which itself wasn't cheap). What's wrong with expecting better? 4k as it stands now is not a compelling enough reason for me to want to upgrade. Especially when real 1080p content still feels like a luxury to me.
fierce_gt and losservatore like this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #573 of 2384 Old 07-28-2014, 04:06 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
If the lg 60 oled was cheaper I would of been a 1080p member still. However the 4k set was less.
I only would of got the samsung 4k. It at least is upgradable.
Eventually it will be in my room and ill have a 4k oled in the den.
All tech has good and bad.
Mrorange303 is offline
post #574 of 2384 Old 07-28-2014, 05:09 PM
sage11x's Avatar
Quoted: 729 Post(s)
Liked: 808
I like OLED but they have to get the motion and longevity/wear sorted before I'll consider it.
Kalani likes this.
sage11x is offline
post #575 of 2384 Old 07-28-2014, 05:13 PM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4943 Post(s)
Liked: 8367
I was just looking at the Samsung OLED today and thinking to myself "this looks quite a bit better than the company's 55-inch UHDTVs." I'm all about a UHD/4K OLED that's not first-gen, I figure that's what will replace my plasma one of these days.
Kalani, sage11x and losservatore like this.
Mark Henninger
imagic is offline
post #576 of 2384 Old 07-28-2014, 07:09 PM
Liked: 355
Same goal. Oled 4k 2nd to 3rd gen. Then the hu9000 goes in the room.
post #577 of 2384 Old 07-28-2014, 07:17 PM
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
Because if there are twice as many pixels in the TV in both directions, to get the advantage of the increased spatial resolution, your screen size needs to increase or viewing distance needs to decrease. The result is that objects jump further relative to the eye (judder/strobe), and if the frame rate/shutter remains the same, for whatever is in motion, you aren't really gaining (much) by the increase in pixel resolution - because the objects/camera in motion will be blurred - eg. what was a blurred object is now a blurred object with twice the pixels in width and height - no (or not that much) more real detail - unless you increased (eg. doubled) the frame rate - and just reducing the shutter time but keeping the same frame rate will increase the judder/strobing and not improve motion at all.
eg. in the 2nd video, the object jumps twice as far (twice as many pixels, and twice the distance - so it can seem more juddery/strobe more) as the one on the left - the image size is twice as big (w & h) so we get the full benefit of the increased resolution. And it's only when the object is still that you see the full benefit of the increased resolution (when it's moving it's blurred to due motion. Shutter on both is 180 degrees). Increasing the frame rate (keeping the same shutter) would reduce the blur (allowing is to benefit more from the pixel resolution increase when there is motion) and smooth out the motion, reducing the judder/strobing.
Joe Bloggs is offline
post #578 of 2384 Old 07-28-2014, 07:23 PM
fierce_gt's Avatar
Quoted: 1628 Post(s)
Liked: 1570
sign me up with these guys! I know for a FACT that it's possible to make a plasma, lcd, or oled tv that I think looks fantastic. but it's been proven time and time again that manufacturers are NOT making 'high end' displays anymore. the 'top of the line' model from most manufacturers flat out sucks compared to some models made many years ago. that's not how technology is supposed to work. things aren't supposed to get worse. so it's clear to me that this is a decision being made, not a limitation of any specific technology, and thus I have my serious doubts that any change in technology will actually improve the picture quality. the fact that nobody seems to be interested in OLED anymore pretty much proves this point. somebody, somewhere made the choice to curve edgelit led screens instead of developing oled, or even using a FALD backlight. there's no way that choice was made based on delivering the best picture quality.
if manufacturers want me to buy another tv in the next 10yrs, they need to make one that's better than what's on the market now, not curve it, not make it thinner, not add another hdmi input, not add more 'smart features'. it's very very very simply to me. I buy new electronics when they are better than my current ones. my example is dolby atmos, I'm SUPER excited about that, and want to upgrade my avr immediately when that starts hitting shelves and there's an avr with it that meets my other needs. dolby atmos is the kind of thing that would make me rethink my entire audio chain from source to speakers. UHD right now feels like a lateral move. one step forwards, one step backwards
Stereodude likes this.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #579 of 2384 Old 07-29-2014, 02:13 AM
abates17's Avatar
Liked: 24
Originally Posted by Mrorange303 View Post
4k. But then you'll make an excuse for something. Notice the freckles. Better color?
After painstakingly reading through this entire thread, I can only conclude that you don’t actually see a lot of the picture flaws on his 4K set, because you are too entranced by the color reproduction which is obviously not as accurate. The comparison shots from Frozen really sealed the deal for me, since you were quick to point out how the 4K one looks better, when you can compare the screenshots directly and see how it is not accurately representing the film image.
Specifically, in the first image, I can see how you can be led to believe that the 4K picture (on the left) is more detailed, because you can see more fine details in the hair. However, just noticing how much darker the shadow area of the hair is, it is obvious that the 4K set has the contrast turned up way too high. Obviously that will accentuate the details in the image, but at the expense of accurate color reproduction (in this case, making her red hair appear closer to copper).
And yes, you can see details like the freckles on her nose more clearly, but again, that is because the flesh tones of her face are blown out to almost white, and the contrast is increased so that subtle details become less subtle. Things like the freckles are supposed to be subtle texturing and details, not a distinct black mole in the middle of her nose.
In the second image, you can see the problems with increased contrast, and also possibly some edge enhancement. Ignoring the moiré effect from the camera, you can see that the 4K image on the left has more compression artifacts around the eye, and the hair coming down looks sharper, but not nearly as smooth. The hair is filled with jaggies on the 4K image that are simply not there on the 1080p image, and you can see a clear white ring around the iris in the 4K image that is not there in the 1080p image. Having a white fringe is a clear sign of oversharpening and edge enhancement.
Finally, the third image shows just how much detail is lost because of the increased contrast and edge enhancement on the 4K set. The 57:57 time marker is fuzzy on the 4K image, and markedly clearer on the 1080p image. On the 1080p image, the Snow Monster text and progress dots are clearly an ice blue, whereas the 4K text and dots are closer to white. In fact, it is much harder to distinguish the blue dots from the white dots on the 4K image. And look at the movie frame itself: The snow monster on the right is smooth and detailed, with a subtle purple highlight on one side and a blue highlight on the other side. But on the 4K image, the purple highlight is almost white, and the subtle blue highlight has turned into a completely white blown-out mess. Meanwhile, the purple light on the rear wall is also much closer to white, and the ice structure in from has become a mess of artifacts instead of a smooth image.
Honestly, for someone who has been touting the increased detail of the 4K sets, I’m surprised that you don’t notice how bad the image really is. It seems like you are equating fake sharpness with detail, like someone who boosts the bass and treble to extremes and then talks about how much better the audio sounds. There is a lot to be said for subtle details, and the 4K display just doesn’t have them.
ID:	185490   Click image for larger version
ID:	185498   Click image for larger version
abates17 is offline
post #580 of 2384 Old 07-29-2014, 02:47 AM
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
Originally Posted by abates17 View Post
After painstakingly reading through this entire thread, I can only conclude that you don’t actually see a lot of the picture flaws on his 4K set, because you are too entranced by the color reproduction which is obviously not as accurate. The comparison shots from Frozen really sealed the deal for me, since you were quick to point out how the 4K one looks better, when you can compare the screenshots directly and see how it is not accurately representing the film image....
Also the comparison shots are from 2 different frames (not the same frame of the film).
post #581 of 2384 Old 07-29-2014, 03:27 AM
abates17's Avatar
Liked: 24
They are maybe a few frames apart, but from the same scene. Her hair did not change from golden orange to copper red in one shot, and the lighting didn’t suddenly change dramatically. And more specifically, the lettering in the menu, and the associated still frame of the snow monster, are exactly the same in both pictures
abates17 is offline
post #582 of 2384 Old 07-29-2014, 03:41 AM
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
I agree that most of the differences will be down to the different picture settings (eg. contrast - the 4K TV being set to very contrasty). But if he's going to ask if we notice how things are visible in one but not as much in the other (though most differences will be down to picture settings - and the fact that the 4K TV distorts the picture), it helps if both are from the same frame (which they aren't) so a valid comparison can be made between the two, as the characters are obviously moving between the frames so different things are going to be more visible (due to position and the lighting at the new position) and at different positions on one display than they are on the other.
post #583 of 2384 Old 07-29-2014, 04:57 AM
dfs88801's Avatar
Quoted: 42 Post(s)
HU9000 and AX800 not impressed
NO HDR
upscaling Bad ( Especially Panasonic in sports broadcasts 720P screen the tables results jingle)
Colors weak
There is money there is no reason to change
dfs88801 is offline
post #584 of 2384 Old 07-29-2014, 07:16 AM
Liked: 355
I always liked the kuro videos. Let's start there. Post this pic. Panasonic kuro best is the video.
This will show the great color a 4k can do and the image is upscaled. Now I hope a plasma fan can appreciate this shot.
Even better i hope a few of the members post the same from their top of the line 1080p whatever sets so we can compare.
You will be lucky if I'm the only 4k owner to do this.
There is plenty of evidence in the 4k forums. But clearly you didn't check there where the owners of 4k sets could give you evidence from an owners perspective.
Not the kid up the block on his computer answering these questions and he doesn't even have a 4k set.
Just saying. A lot if info in here about 4k is wrong
It's a preference. It's beautiful. It's now.
65hu9000 , Panasonic BDT360 bluray player.
post #585 of 2384 Old 07-29-2014, 07:18 AM
Liked: 355
Sorry wrong one. You ain't beating that one. Well plasma owners can match it. But not the LCD 1080p owners. My bad. Here is the kuro shot. Lol.
post #586 of 2384 Old 07-29-2014, 07:23 AM
Liked: 355
How about CORALINE. One of the most detailed movies that exist to the eye.
Other mother? This movie will expose all kinds of nasties. If 4k sucks as most of you say then CORALINE will make it suffer.
Let's do this one. Ooh that would be fun.
post #587 of 2384 Old 07-29-2014, 07:30 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
yet again camera picture...
Stereodude and sage11x like this.
mightyhuhn is offline
post #588 of 2384 Old 07-29-2014, 07:34 AM
Liked: 355
Like I said. You have access to the owners forums. I've also personally uploaded video of me taking pictures of the kuro shots. So before you try to act all high and mighty huhn. Pun. Do some research. The video is on YouTube. Same exact tv the shots came from.
Oh it's in hu9000 owners forum too.
You won't care but I made it 4k also.
post #589 of 2384 Old 07-29-2014, 07:55 AM
Liked: 355
Mind you I'm not saying it beats your sets picture wise. I'm saying your pictures cannot beat it.
Meaning it is indeed doing a fantastic upscale job. That's all that's for.
Not to say my set is better. Unless your set is an 1080p led LCD. Then yes my tv is better.
But to say it cannot upscale. No. Just no.
post #590 of 2384 Old 07-29-2014, 08:00 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
try a QUOTE if you talk to people.
post #591 of 2384 Old 07-29-2014, 08:16 AM
Liked: 355
Sorry.
post #592 of 2384 Old 07-29-2014, 08:33 AM
Liked: 355
I tried. I also had 5 min to take the shot on the 1080p set. Run downstairs to the 4k. Turn the sharpness down to 20 like my other set then snap the pic and return the movie back upstairs to a mob of angry children.
I'll try to be frame accurate next time. I mean I did try. Not well though.
And some of the things you guys agree with are actually things wrong with the 1080p picture. Like not having freckles showing when the character has them. Many small things show up like this in animated movies.
Movies like Pacific Rim benefit from a much much better motion system this year for Samsung.
The Sony has no motion issues. But it does has banding.
Either way they both could be considered super 1080p sets that allow you to view your content in a higher resolution which adds depth to a picture .
10 years from now buy the oled 4k 600hz, HDR, thx, rec 2020 or slightly less than, or whatever, lower gray scale etc.
I'll be there too. That's the point. If you are buying a set today it does make sense to consider 4k.
It's basically the in between set. Does 1080p at colors and such it should because it is using the same standards. But also allows for a transition period into 4k and really allows you a longer transition as you can share some benefits until not only standards are set but prices are more affordable on 4k uhd sets.
The benefits of today's best 1080p is in these sets. It does those things extremely well too. The upscale tech is absolutely amazing. Sorry for the pics. But you can see even at 4x the resolution the sets hold on and enhance some detail.
post #593 of 2384 Old 07-29-2014, 08:41 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
@Mrorange303
so you meant me with that:
can you plz show me where i said something like that?
post #594 of 2384 Old 07-29-2014, 08:48 AM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
MrOrange, can't you just accept that not everyone has the same goals or opinions regarding televisions. You aren't going to convert anyone to your "side". This isn't a contest. Just because some people don't agree with you and your assessment and haven't hopped on the UHD bandwagon doesn't invalidate your opinion of your set or mean you can't love it.
There is no perfect TV. If there was everyone would buy that one. Every TV is a compromise. Each person picks the compromises they can live with and the ones they can't and buys accordingly. Just because two knowledgeable people don't buy the same model doesn't mean one of them chose incorrectly.
Please give it a rest.
sage11x likes this.
Stereodude is offline
post #595 of 2384 Old 07-29-2014, 09:14 AM
Liked: 355
@Mrorange303
Said sorry man. Wasn't you that was for.
post #596 of 2384 Old 07-29-2014, 09:21 AM
Liked: 355
Yes I can. And your right. But im one 4k person. This thread should have 2 sides. Just as poeple have the right to give reasons for why not.
Is it not just as important for a potent I al buyer to see reasons for as well?
Or is this another thread of 4k is not ready. Because this thread has unfairly turned into another one of those filled with just that.
4k is not represented correctly here. Its value in the current market and the reasons for buying one today are not discussed.
We all know 4k is in its infancy. So was 1080p at one point.
Still it had benefits.
Ill stop. But this thread still has several members just spewing thinhs they read. No expirience with 4k.
Not a fair comparison. Believe me all 4k owners have had 1080p sets. Still do.
post #597 of 2384 Old 07-29-2014, 11:48 AM
abates17's Avatar
Liked: 24
See, the thing with the freckles just highlights my point: A lot of details in movies (especially animated movies) are subtle. The freckles are a subtle detail that show up perfectly well on a 1080p set, but since they are more obvious on your 4K set, you believe that the 4K set is enhancing the detail, when in fact that set is less accurate.
As I showed you from your screenshots, the colors are just not accurate: Blacks are muddy, the whites are blown out, some pinks and blues are almost white, and the whole picture looks oversharpened. You talk about how the color is so much better on the 4K set, and it definitely looks different from the other picture you posted, but I can’t say that it is better. In fact, just based on the hair color alone and comparing it to my set, I would say that the color on your 4K set is less accurate.
Now, I’m not saying that any of this is due to 4K itself. In fact, since 4K doesn’t have any effect on color, I would chalk it up to calibration differences between the two sets. But if you’re trying to demonstrate how the 4K set has better color, it would help if the sets were calibrated the same.
This thread does have two sides! You have spent an inordinate amount of time posting here, so your side is well represented. The problem is that you don’t really have much of a case to stand on. You keep talking about how the color is so much better on your 4K set, and people have responded that resolution does not affect the color at all. And your response to that is, “Other people who have 4K sets will agree with me!” Then someone says that a well-calibrated 1080p set will look better than a poorly-calibrated 4K set, and your response is, “But what if someone likes the look of the 4K set better? You can’t say that someone’s opinion is wrong! You can’t argue preferences!”
Yes, some people might prefer a picture where the colors are overexaggerated and the details are oversharpened, just like fans of LPs might think that the pops and clicks make the music more “warm” and “natural.” But that doesn’t change the fact that CDs can play music that is physically impossible to represent on LPs, or that a well-calibrated set is more accurate than one where the picture is set to Vivid.
abates17 is offline
post #598 of 2384 Old 07-29-2014, 12:54 PM
toomanytvstosee's Avatar
Quoted: 148 Post(s)
Liked: 49
while I am jumping on the train I have to at least say I think 4k is accomplishing two things.
(1) its giving tv makers something new and exciting to talk about and hence the chance to return to some profitability (yes I said that) as the low end and low margin will
never inspire technical advances.
(2) 4k is going to come down in price (yes counter-intuitive) but never the less it will push development cycle and technology even harder as they clamor to claim market share.
Everything trickles down in commerce and the tv is no different. We have to accept a medium because sadly no matter how much we try to deny it, we cant have it all.
Look at the Sharp Elite. It was to be the holy grail of LED and its dead in the water. The point is get in if you want it now, wait if you dont. There will always be
"something new" on the horizon because we as a society like "New"
4k at least has more appreciable promise then some of the other past gee whiz bang tech (240 and 480 refresh..I mean really)
toomanytvstosee is offline
post #599 of 2384 Old 07-29-2014, 01:13 PM
Ken Ross's Avatar
Quoted: 5700 Post(s)
Liked: 6062
Beyond that, people continue to micro-analyze both color and detail from crude snapshots from a TV screen.
You can't do it, but people have been doing it for years and will continue to do it. Good luck with that.
How anyone can answer the '4K or not?' question from these images is absolutely beyond me.
Ken Ross is offline
post #600 of 2384 Old 07-29-2014, 01:16 PM
GregLee's Avatar
Quoted: 801 Post(s)
Liked: 259
How do you know his 4K set is less accurate with the freckles? How do you know they "show up perfectly well on a 1080p set"? Do you have some unique esthetic intuition about how they ought to look that the rest of us can only envy?
Greg Lee
GregLee is offline
Reply Latest Industry News
frontpage
