UHD/4K Quandary: To Buy or Not to Buy - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 689Likes
post #901 of 2384 Old 08-05-2014, 03:01 PM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
Originally Posted by Mrorange303 View Post
Prove to me more pixels doesn't help detail. Let's start there.
With a 4k source, certain details that involve small color variations across a surface should be visible (using dither), though they could not be seen at 2k, at ordinary viewing distances.
Greg Lee
GregLee is online now
post #902 of 2384 Old 08-05-2014, 03:03 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Same principle works on displays big and small. This is literally science. Not my personal feelings.
I request the same. And don't say stand back further. 4k is to sit closer. So that point is a dead horse.
Whoever said more pixels don't help, please explain the difference between the iPhone icons Mr. Orange posted. All are form the same OS, but the last row is from a retina display. Can you see that?
vddobrev is offline
post #903 of 2384 Old 08-05-2014, 03:06 PM
Mrorange303's Avatar
Quoted: 1199 Post(s)
Liked: 355
Originally Posted by vddobrev View Post
Why is it that anytime someone post a "pro" for UHD, a bunch of people get aggravated and try to disprove him, while if someone posts a "con" it is greatly accepted and appreciated.
Great question indeed.
Mrorange303 is offline
post #904 of 2384 Old 08-05-2014, 03:07 PM
sage11x's Avatar
Quoted: 735 Post(s)
Liked: 808
This resolution 'enhancement' sounds suspiciously like the 'motion enhancement' that manufacturers use to 'improve' motion by interpolating artificial intermediary frames between the actual frames of a source.
So, what I'll say to that is some people like this sort of enhancement and some don't. I fall on the side of the argument that I don't want my display adding anything that wasn't there to begin with. Now, we're getting into a sort of grey area here as, unless the UHD set just quadruples every pixel of the 1080p source, it HAS to scale the source up similar to how an HD set HAS to scale an SD image up to fit the pixel count of the display.
In either case this isn't an ideal. I'll tell you that DVD looks better played natively on our 56" CRT RPTV than it does upscaled to any of our digital (DLP, LCD, plasma) displays. Having to create something from nothing is always going to leave a lot to be desired.
sage11x is offline
post #905 of 2384 Old 08-05-2014, 03:11 PM
Liked: 355
And there are 4 pixels on a 4k to do color transitions and variations compared to 1 for every 1080p screen.
SSo while the 1080p screen shows 1 pixel of color.
The 4k screen can literally show 4 pixels in the same space as the 1 and display 4 different colors.
This is why definition is greater which causes some detail lost from conversion to show up on the UHD screen.
They don't get it. I literally did not make any of this up. They just don't get it.
I'm lost.
post #906 of 2384 Old 08-05-2014, 03:12 PM
5x10's Avatar
Quoted: 606 Post(s)
Liked: 386
only a matter of time before 4k infiltrates all tvs, down to the walmart level
at that point, its going to be: Do i go with the cheaper lcd or the more expensive Oled
5x10 is offline
post #907 of 2384 Old 08-05-2014, 03:14 PM
Liked: 355
Motion interpolating has nothing to do with resolution.
You have 60hz, 120hz and so on but all are still 1080p.
If your saying it is that type of step I disagree.
I can get a video game in 720p at 60fps.
But will it show more detail then a game at 1080p 30 fps?
No. 2 separate features.
post #908 of 2384 Old 08-05-2014, 03:25 PM
Liked: 355
Detail is greater. Color etc all because of pixels. Not a feeling. If you debate this that is the first issue with your understanding of 4k.
post #909 of 2384 Old 08-05-2014, 03:27 PM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
Well, it's more complicated than that, because those extra pixels on the 4k screen are too small to be seen at an ordinary distance. Details that depend on the visibility of individual pixels at 4k will be lost -- the pixels are too tiny. My example concerned a detail of a different sort, that doesn't depend on the visibility of individual pixels. Rather, I'm talking about a detail that depends on distinguishing the colors of contiguous areas, where the colors are close enough that 8 bit color is not enough to distinguish them, but in 4k you can make the areas appear distinct by scattering some differing pixels in one of them. The distinguishing pixels themselves would not be visible, but the different color tint they add to the area could be seen.
Greg Lee
post #910 of 2384 Old 08-05-2014, 03:34 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Originally Posted by losservatore View Post
I bet you anything that the non retina example that apple use on that pic for marketing propose doesn't look like that close to a retina display.come on!!! You can't even see clear the letters.
The first row is 1:1, second and third row is blown up. Have you ever had an iPohone 3, or 2?
vddobrev is offline
post #911 of 2384 Old 08-05-2014, 03:36 PM
Liked: 355
This is not different. Just I use a real easy to understand version of it.
post #912 of 2384 Old 08-05-2014, 03:37 PM
Liked: 355
Yep. Been a while. Retina was huge.
Bottom line is it helps. That's all. I think we can agree it possible
And sorry that's not at you. I just agree with you.
post #913 of 2384 Old 08-05-2014, 03:54 PM
Joe Bloggs's Avatar
Quoted: 435 Post(s)
Liked: 118
That's native 4K resolution, whereas we were talking about upscaling, not showing native 4K.
Joe Bloggs is offline
post #914 of 2384 Old 08-05-2014, 03:59 PM
losservatore's Avatar
Quoted: 2304 Post(s)
Liked: 2049
Now we are going to exaggerate the look of a image over a retina or 4k display?
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #915 of 2384 Old 08-05-2014, 04:00 PM
Liked: 355
Sorry. It does help in upscale too. Like in frozen the characters wear a purple fleece type material. On my UHD you can see the texture of the material.
The material on my 1080p set is just not as defined.
Of course UHD content is really sharp so that helps.
But I'd say it helps a lot on upscale pictures.
post #916 of 2384 Old 08-05-2014, 04:02 PM
Liked: 355
If you argue it please just use evidence we can follow. We are open minded and are willing to take the time to review the evidence. Thanks. Its just I've given a good argument with something to follow. It makes it easier for all who maybe following to better understand your point. Thanks again.
post #917 of 2384 Old 08-05-2014, 04:05 PM
Joe Bloggs's Avatar
Quoted: 435 Post(s)
Liked: 118
Isn't that because you've set the sharpness on your 4K TV very high? You've calibrated the 1080p set but not the 4K set and set the sharpness to high. If you're going to do comparisons like this surely for a valid comparison you'd need both sets calibrated/similar settings on both (not sharpness/contrast turned way up on one but not the other).
I'm not saying upscaling doesn't help, but the difference you're seeing in this case is probably a lot to do with the different settings (eg. sharpness/contrast etc.), than just upscaling/the TVs res.
post #918 of 2384 Old 08-05-2014, 04:16 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
This picture clear said simulated images.
Of course it is, isn't it obvious?
vddobrev is offline
post #919 of 2384 Old 08-05-2014, 04:19 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
Yea, lets try exaggerating for a while, since you don't get it. You avoided the question, so it is obvious you haven't seen how iPhone 2 or 3 icons looked back then [exactly as depicted]. If you have, you would have know the difference...
vddobrev is offline
post #920 of 2384 Old 08-05-2014, 04:20 PM
bruceames's Avatar
Quoted: 521 Post(s)
Liked: 352
Somebody posted this chart below at another forum. Has anybody seen it? No source was given for it so I'm curious.
bruceames is offline
post #921 of 2384 Old 08-05-2014, 04:23 PM
Liked: 2049
That simulated images doesn't represent the real look of 4k and 1080p and I'm out, this is getting out of proportion.
post #922 of 2384 Old 08-05-2014, 04:27 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
The pictures doesn't represent the real look of 4k and 1080p and I'm out this is getting out of proportion.
Like hell it doesn't, so all this time I have been looking at a UHD with unreal look, and also an iPhone retina display with unreal look. What do you know...
vddobrev is offline
post #923 of 2384 Old 08-05-2014, 04:30 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
The details that's there is refined. Simple. Hair, grass, show detail. All benefit from resolution bumps. I meant the detail is more defined.
The science is not against me. It's against you.
So let's first prove more pixels doesn't help.
first you say it create new and now science is against me ?...
mightyhuhn is online now
post #924 of 2384 Old 08-05-2014, 04:34 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Yes, those have been posted several times. They're from Carlton Bale's website.
http://carltonbale.com/does-4k-resolution-matter/
Kalani is offline
post #925 of 2384 Old 08-05-2014, 04:42 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
I have an iphone 3 in my closet I also have an iphone 5 and iPad ,what will be next taking pictures with a magnifying glass?
No magnifying glass needed, just take your iPhone 3 out of the closet and put it next to your iPhone 5... perhaps you forgot how it looked, since you asked all these question. Gee... I cannot believe you said all of the above...
vddobrev is offline
post #926 of 2384 Old 08-05-2014, 04:43 PM
bruceames's Avatar
Quoted: 521 Post(s)
Liked: 352
The second chart is?
I ask because the second chart recommends about 3x the seating distance as the first, so I don't think it's from the same source.
post #927 of 2384 Old 08-05-2014, 04:56 PM
vddobrev's Avatar
Quoted: 83 Post(s)
Liked: 40
I have an iphone 3 in my closet I also have an iphone 5 and iPad ,what will be next taking pictures with a magnifying glass and zooming the image to 400%?
As I said, no need to zoom:
iPhone 3: 480×320 = 153,600 pixels
iPhone 5: 1136x640 = 727,040 pixels --> number of pixels increased 4.7 times, while screen increased with .5 inches.
Translate the above to 1080p vs UHD... you do the math.
vddobrev is offline
post #928 of 2384 Old 08-05-2014, 04:58 PM
Liked: 355
I apologized I misspoke. Did you see that?
Or after all this do you want to stay on this to avoid your error?
It ENHACES DETAIL. SORRY I MISSPOME. THE DETAIL IS THEORY BUT ENHANCED BY THE EXTRA PIXELS.
Or are you still stuck when EVERYONE else moved on and got the point just fine.
What more information do you need to understand this post?
Please advise.
Or move on like the thread did.
post #929 of 2384 Old 08-05-2014, 04:59 PM
Liked: 355
Those distance charts were theory that didn't hold up. It is now known at 55" most people can see the difference at 9'.
However you want to sit close. It's wonderful.
post #930 of 2384 Old 08-05-2014, 05:06 PM
Liked: 2049
Please don't quote my post with the same pictures,there was too many pictures on the page so I deleted my previous posts.
Reply Latest Industry News
frontpage
