Velodyne Releases New Digital Drive 2.0 Software - AVS Forum | Home Theater Discussions And Reviews
Old 05-17-2005, 11:35 AM - Thread Starter
David Bott's Avatar
Liked: 45
Velodyne is pleased to announce general availability of Digital Drive software version 2.0. This software is compatible with all current Digital Drive subwoofers, and the upgrade is free of charge. The new version can be downloaded at:
http://www.velodyne.com/support/digital_drive
This new version features two different forms of auto-EQ, individualized EQ settings per preset, better navigation, default preset select, defeatable low-pass crossover and a host of other features. You can read about the new features by viewing the data sheet at the above link.
You’ll need a windows PC with an RS232 serial port and a male-to-female RS232 9-pin “mouse extension†serial cable to perform the upgrade, available at any computer store or you can obtain one from Velodyne by emailing techhelp@velodyne.com. If you only have USB ports on your PC, you can obtain a USB to RS232 serial adapter at most computer stores.
Note that version 2.0 restores defaults if upgrading from an older version, so note your settings before upgrading.
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
