dnp UNVEILS SUPERNOVA™ MOBILE SCREEN - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-14-2007, 03:49 PM - Thread Starter
David Bott's Avatar
Liked: 45
dnp UNVEILS SUPERNOVA MOBILE SCREEN
Portable Version of Award-Winning Supernova Debuts at InfoComm 2007 Booth # 4836
ANAHEIM, CA - June 14, 2007 - dnp, the world's leading supplier of optical projection screen technology has recently revolutionized the industry with the Supernova Screen, the first-ever optical front projection screen that allows viewing in brightly lit environments. The new dnp Supernova Mobile Screen is the portable evolution of the award winning Supernova Screen family. The Supernova Mobile is ideal for presentations on the go. This advanced optical front projection screen is quick to set up and conveniently rolls back into its lightweight metal case for easy transport and storage. Exceptionally high-contrast, vivid images in a handy, portable format, make the Supernova Mobile perfect for situations where viewing locations and conditions change.
Contrast is what gives a picture depth, nuance, atmosphere, stated Manfred Freiberger, senior account manager for dnp USA. With Supernova Mobile you get up to 10 times more contrast. And since optical screens filter out unwanted reflections, dnp can deliver this quality even in broad daylight. Finally, no more darkened rooms or yawning audiences due to low lighting in a room.
For the first time ever, the Supernova Mobile allows presentations to be performed with the lights on, where speakers are free to maintain eye contact with the audience. This allows them to read their facial expressions for instance, or clarify a point by quickly drawing on a whiteboard, hold up a product sample for the group to see, and keep every viewer captivated.
The Supernova Mobile was created by applying the award-winning Supernova Screen surface to an ultra-thin yet durable polymer backing. The backing material resists light from behind and also serves as an attractive frame around the image area.
The Supernova Mobile delivers up to ten times higher contrast than standard front screens. The technology used to develop Supernova is based on a revolutionary high-contrast filter that allows the projected image to be reflected from the screen, effectively absorbing incident light from other angles such as windows and room lighting. As a result, the screen is virtually unaffected by ambient light. Supreme black levels are balanced with an ergonomic brightness level to create vivid images with full color saturation to prevent eyestrain regardless of viewing position.
Complete with foldable supports to mount the screen either on a table or floor (depending on the screen size) and a metal case for storage, the Supernova Mobile can easily be taken along for use in various locations. It fits into a car and is ideal for the travelling sales rep. After unfolding the built-in supports, the smaller 40 screen unrolls horizontally and stands on a table. The larger 80 screen is unrolled vertically and stands on the floor. Supernova Mobile is intended for use with a table-mounted projector.
During the upcoming audio/visual tradeshow, InfoComm 2007, June 19-21, 2007 in Anaheim, California, the Supernova Mobile will be featured at dnp booth # 4836. dnp will also showcase other products from the award winning Supernova line such as the fixed Supernova One Screen, the tiled Supernova Infinity and the retractable Supernova Flex. dnp will also showcase three high-end rear projection screens for meeting and control rooms; dnp's new Wide Angle ScreenÔ, dnp Sigma Screen and dnp Giant Wide Angle ScreenÔ.
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
Reply Latest Industry News
