My Batcave - MA rack, Rives designed room - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #571 of 583 Unread 02-02-2017, 06:51 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 184 Post(s)
Liked: 148
That's the one. But Chief did change the "buttons" on those mounts at some point. Don't remember when but you need to be sure you get the plate with the right buttons on it so it locks properly.
Mike_WI likes this.
GetGray is online now
post #572 of 583 Unread 02-02-2017, 06:57 AM
GetGray's Avatar
Quoted: 184 Post(s)
Liked: 148
Originally Posted by Mike_WI View Post
@GetGray -
Thanks for the input.
Let me call Chief and see if the Chief SLM281 works with the 1st gen RMPA(U). I presume it should.
Fastest way to get up and running would be to just get that.
The Chief -> Milo link makes me create a dealer account: https://www.milestone.com/my%20account
The Amazon link has a delay.
Would love to get ASAP to mount.
It may be hard to have a new ceiling base as it is screwed into wood in ceiling not a pipe or other standard fixture.
Certainly worth $100 to get it installed fast and then think about these other issues for next projector in a few years.
I was also wondering about:
1. positioning of JVC RS520 vs. RS20 relative to CineSlide and ISCOIIIL anamorphic lens
RS520 and RS20 are about similar length, so may still work okay
2. Do I need anamorphic lens with new projectors having memory modes for that and using the Lumagen Pro?
If I sold both of those should help finance the recent HT updates.
I may message you soon.
I think I have your email address.
Mike
Personally, I'll be keeping my lens. because:
1- You need every photon you can get for HDR
2. I think using a Lumagen and no lens is the worst of all worlds. All your 16:9 content is downscaled to a lower resolution so you get scaled image and lack of panel. Better off to zoom for 2.35 IMO.
3. The market for them is weak, so the keep it proposition is high IMO
As for the mount I forget when they went lens in the middle. After that I think the case stayed the same. If the Old PJ has the offset lens (off to one side), then something would have to move.
Mike_WI likes this.
post #573 of 583 Unread 02-02-2017, 07:04 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
I called Chief.
RPMA (O) not (U)
Can't get longer brackets.
Can't buy just one through Milestone.
SLM281 should mount to top piece of 1st generation.
1st gen and later are interchangeable.
@GetGray -
Can I ask you to order a SLM281 for me.
Can switch to email/phone for details.
Mike
PS - @SOWK - will think about options for a shelf mount in the future.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
post #574 of 583 Unread 02-02-2017, 07:12 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
I think the RS20 is off center and RS520 on center (?).
So that's why a shelf would allow projector movement as the setup for CineSlide and ISCOIIIL was a big arbeit.
If I get the new Chief SLM281 plate I can at least see how things are working without and potentially with ISCO.
Will email you.
Mike
HT Details: link
post #575 of 583 Unread 02-02-2017, 07:43 AM
SOWK's Avatar
Quoted: 488 Post(s)
Liked: 400
1. Personally I think HDR is near worthless on any realistic sized front projection screen. But your statement is accurate.
2. He can use the lens memory feature for 16:9 content without having to scale the image in the lumagen.
3. This is also an accurate statement. He would not get much for the lens/slide.
Mike_WI likes this.
SOWK is online now
post #576 of 583 Unread 02-02-2017, 08:05 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Thumbs up Thanks for input all...
Chief plate ordered from Scott / @GetGray .
Will see how that works and go from there.
I will have time before professional calibration (Craig, @CIR-Engineering ) -- with expected FW updates from Lumagen and Oppo -- before deciding on if ceiling mount works or I need to move CS/ISCO, take it out, or build a shelf.
Mike
EDIT
Chief plate arriving Mon, 2/6/17.
HT Details: link
post #577 of 583 Unread 02-06-2017, 03:42 PM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Smile JVC RS520 installed
JVC RS520 installed with new Chief plate.
Relatively easy to install.
Limited space for power plugs next to rear column compared to JVC RS20.
@GetGray -
May need a primer again on how to position the CineSlide/ISCOIIIL combo.
Lens now needs to be moved for new projector.
01-20-2009 (CS/ISCO): My Batcave - MA rack, Rives designed room
05-06-2009 (CS/ISCO installed): My Batcave - MA rack, Rives designed room
05-24-2009 (calibration figures): My Batcave - MA rack, Rives designed room
06-17-2009 (close up of RS20 w/ CS/ISCO installed): My Batcave - MA rack, Rives designed room
Quick Zoom/Shift/Focus and setting on "Cinema" looks great with a blu ray.
Haven't tried a UHD yet.
May try one with 16:9 first.
Also ordered 3D emitter and 5 glasses today.
Link
Mike
EDIT:
Hmm, as I think about it, maybe I can't/shouldn't move the CineSlide/ISCO as it is centered for the screen.
May need to build that projector shelf after all.
Haven't experimented with the anamoprhic setting on RS520 much yet.
HT Details: link
post #578 of 583 Unread 02-07-2017, 04:39 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Reading the RS520 manual:
http://pro.jvc.com/pro/attributes/PR...017_manual.pdf
p.51
Doesn't seem that I need the anamorphic button on the JVC remote given that I have a Lumagen Radiance Pro.
I guess I need to think about lens memory modes for:
16:9 TV/movie
2:40:1 movies
With different zoom (+/- shift) and focus settings saved?
Mike
HT Details: link
post #579 of 583 Unread 02-08-2017, 07:18 PM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
3D emitter and glasses arrived. Unpacked but didn't test yet.
Oppo UDP-203 36-0122 Beta Test Firmware link from Oppo and installed.
Played a little with the HDR slider.
Changed Lumagen Radiance Pro HDR from Off (for prior JVC RS20) to "Auto" and tried HDR.
Too dark, but still interesting and impressive.
4K source was Oppo with Miss Peregrine's Home for Peculiar Children.
Some muted colors and 16:9, but hope to try soon with other movies in 2.35:1 (zoom, no ISCO for now) and also 3D.
Mike
HT Details: link
post #580 of 583 Unread 02-12-2017, 06:00 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Watched a 3D BR (Avengers - Ultron) last night with the kids.
3D started off gimicky feeling, but was better after eyes/brain acclimated to it.
Kids loved it.
I haven't tried a 4K (UHD) 3D title.
Suggestions?
Mike
HT Details: link
post #581 of 583 Unread 03-24-2017, 03:05 PM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
With updates now 3 things to watch for firmware (FW) updates:
1. JVC RS520
http://support.jvc.com/pro/firmwareu...serieslist.jsp
CMD fix?
2. Lumagen Radiance Pro
http://www.lumagen.com/testindex.php...ncepro_updates
HDR Intensity Mapping algorithm complete for some time, and I recently added Hybrid Log Gamma (HLG) support to the table generation code
3. Oppo UDP-203
http://oppodigital.com/blu-ray-udp-2...-41-0317B.aspx
Release date: March 24, 2017.
Category: Latest Public Beta Test Release
Main Version: UDP20X-41-0317B
Loader Version: TF0030
MCU Version: MCU203-01-1118
Comparing to the current Official release version UDP20X-38-0222, the major changes included in this version are:
Added the Dolby Digital and DTS options under the S/PDIF Output setting in Audio Output Setup, which allows the player to re-encode different audio formats into the Dolby Digital or DTS audio format for the S/PDIF output.
Improved the output accuracy when using the RGB PC Level color space.
Resolved a frame dropping issue when using cable or satellite boxes through the HDMI In.
Improved A/V sync when using the HDMI In.
Resolved an issue where the Full zoom mode would not fill the screen when playing 4:3 content.
Improved stability when accessing SMB servers.
Resolved an issue where ejecting the disc tray could lock up the player.
Improved compatibility with Optoma 4K projectors.
General disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted disc samples.
HT Details: link
post #582 of 583 Unread Today, 06:02 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Discussion and pictures in this thread "HDR in Anamorphic Widescreen" about my change from JVC RS20 to RS520 and need to change mount or build shelf for projector.
Start: Post 14
End: Post 23
Plan:
Build a shelf on column behind projector to better align the CineSlide and ISCOIIIL.
Thanks @GetGray (Scott Horton)
CC @funlvr1965 (for prior help and to see if you are still out there).
Mike
Name:	DSCN4005 - Projector mount side view.jpg
ID:	2072129   Click image for larger version
ID:	2072137   Click image for larger version
ID:	2072145   Click image for larger version
ID:	2072153   Click image for larger version
HT Details: link
post #583 of 583 Unread Today, 06:05 AM - Thread Starter
Mike_WI's Avatar
Quoted: 152 Post(s)
Liked: 86
Projector Shelf Pics
More historical (2008-) pics of JVC RS20 and build of column behind projector.
ID:	2072169   Click image for larger version
HT Details: link
Emotiva Xpa 3 Amplifier , Denon Avr 5308ci Receiver , Oppo , Oppo Bdp 103 3d Blu Ray Player , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Sony Bravia Ex700 Series 60 Inch Lcd With Led Back Lighting Hdtv Kdl 60ex700 , Samsung Bd P2550 1080p Blu Ray Disc Player
