my system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 04-05-2009, 03:59 AM - Thread Starter
victor tubeman's Avatar
speakers,martin logan,prodigy,logos,request rear
subs 2x revel b15 front,rear 2 x SGR 18inch mal x 125l .
amps,audio research reference 600 mkIII monoblocs L and right
krell TAS 5 channel centre,fronts for tv
krell ksa-150 class a,spare
bat vk-500 rears
Peavey cs4080hz subs, Svs ASeq1
pre amps,bat vk-5 Left,Right (tube)
copland cva306 6 channel blueray only(tube)
proceed AVP sub vol only blueray
cd transport,mark levinson reference cd transport No 31.5
dac jadis js2mkII
samsung 50inch plasma (tv cable ).JVC rs2 110inch 16x9 (to install )
blueray,panasonic bdp85 (temp,oppo if B/M correct)
and big aircon,victor.
system 2 rear pro panasonic 56inch crt
denon 3805,
toshiba hd-xe1
definitive technology mthos 4 times 4.
New Arrival,Avantgarde Duo,s .Wavelength Napoleon Silver 300b mono,s
http://www.avsforum.com/avs-vb/attac...1&d=1239793751
[IMG]
[ATTACH][ATTACH][ATTACH]Attachment 139774[/ATTACH][/ATTACH][/ATTACH]
victor tubeman is offline
post #2 of 26 Old 04-05-2009, 09:48 AM
ddgtr's Avatar
victor,
""Spare" class A Krell?? OMG!! Now I can submit a petition to my wife for another amp since you've set precedence!!
The system sounds awesome!! Can you post some pictures, errr... eye candy??
Dan
ddgtr is offline
post #3 of 26 Old 04-05-2009, 08:13 PM
Roger That's Avatar
Pics or it didn't happen.
Roger That is offline
post #4 of 26 Old 04-05-2009, 08:53 PM
ldgibson76's Avatar
Quoted: 14 Post(s)
In this section of the forum, if you are introducing a system without photos, it's a tough room!
Photos should always accompany an equipment listing.
Regards.
"Chance favors only the prepared mind." Louis Pasteur
Ldgibson76
Current Ensemble
ldgibson76 is offline
post #5 of 26 Old 04-14-2009, 04:37 AM - Thread Starter
Regards.
I will post some pics soon,please note MY ROOM IS TOUGH,
regards victor
post #6 of 26 Old 04-15-2009, 04:26 AM - Thread Starter
pics up 1st post regard victor
post #7 of 26 Old 04-15-2009, 05:59 AM
ldgibson76's Avatar
Quoted: 14 Post(s)
Victor, Victor, Victor!
Wow! Your system is insane! In a good way!
Very impressive collection of components you have there.
There's a lot going on.
Can you elaborate a little more on the configuration?
From the looks of it, you have a lot of power for such a small room. Not a bad thing, mind you, but do you think you are getting the full potential of the system?
As you can see, I took the liberty of embedding your photos for all the world to see! I hope you don't mind....., I have a habit of doing that?!
Great setup!
Regards.
Ldgibson76
Current Ensemble
post #8 of 26 Old 04-16-2009, 01:00 AM - Thread Starter
Great setup!
Regards.
Thankyou for enlarging photo,s taken by a friend for me i don,t have dig camera.
system is very complicated,2 channel transport to jadis dac,then bat pre,to power amps audio research ref 600mkIII (600watt tube amp) don,t look big but they are ,robert harley had mk2 said best ever amp he had but too much heat 800 watts/amp at idle,max 2300watts/amp mono,s with 2 other is nice and warm.to prodigy,s run full range,for now
5.1 pioneer analog out centre,L BACK,R BACK into copland cva 306 6 channel valve pre amp.left and right fronts into bat vk-5 2 chan pre amp to ref 600mkIII to prodigy,s.Centre to krell tas using only 1 channel to logos.L back and R back go to bat vk 500 2 chan,power amp,not shown in pics then to rear martin logan request run full range with 2 genesis subs each,rear subs not in pics,1 revel front not in pics either.forgot sub output from blue ray to avp analog bypass x over 100hz connected to 2 front revel b15 sub, eq flat 15hz to 100hz .because i have 3 volume controls i have it set -8 db from ref 75 db i cant just turn up or down need to calibrate all 3 pre amps.
most movies use 1watt peak for 102 to 105 db at seating position,on mono blocs peaks.
sound,
most home theatres lack power,amps clip due to huge range in most movies,not mine its coasting all the time.mid range is very transparent and highs too,bass very tight.blue ray movie sound tracks are betterthan people realize.2001 space ,audio is best i have heard with real music its like heaven.
room is 15 x 21 x 8 ft height,regards victor
post #9 of 26 Old 04-19-2009, 05:05 PM
ldgibson76's Avatar
Quoted: 14 Post(s)
Hello Victor.
Thanks for the breakdown. If you get a chance, check out "ddgtr" setup. He has a similar configuration.
http://www.avsforum.com/avs-vb/showthread.php?t=1094330
Regards.
Ldgibson76
Current Ensemble
post #10 of 26 Old 07-30-2009, 12:49 AM
Franin's Avatar
Quoted: 2396 Post(s)
Liked: 1490
Hi Victor very nice setup. How do you find the Martin Logans? I demoed a pair here once in W.A very nice.
_________________________
Franin is online now
post #11 of 26 Old 07-30-2009, 01:01 AM
Waboman's Avatar
Quoted: 5021 Post(s)
Liked: 11596
Victor, very nice setup! We're thinking along the same lines. I rock with the Martin Logan Prodigy, as well as a full Martin Logan 7.1 setup.
Very similar, I had a couple of Krell amps and the 70XBR2 too.
Waboman is offline
post #12 of 26 Old 07-30-2009, 01:01 PM
krab's Avatar
This is one OUTSTANDING system!
Enjoy it to the max, you earned it. Nothing beats top of the line equipment.
You are absolutely correct about many home theater systems starving for power and lacking the ability to play clean at both ends of the dynamic range.
This is why I don't care for 90% of the receivers used in home systems. There is no free lunch, you want to play you have to pay and adequate clean power is at the top of my list
Keep climbing the equipment ladder, the exercise will help you live longer because you'll never reach the top
krab is offline
post #13 of 26 Old 07-30-2009, 06:20 PM
Boonyarat's Avatar
Quoted: 47 Post(s)
Liked: 27
Hello VICTOR very nice & complicated set up. How can you bring all high end brands work together.
Boonyarat is offline
post #14 of 26 Old 07-30-2009, 07:59 PM
croseiv's Avatar
Man I bet you don't need to run the heater in the Winter time!!! Very nice!
croseiv is offline
post #15 of 26 Old 07-31-2009, 01:37 AM - Thread Starter
Thankyou,
They are very good for HT,new models are much more amp friendly but not for very large rooms,and/or very high db 115db(at listening position) but on quality movies with music etc are sublime(tube amps 85% of the great sound)
Cheers Victor.
post #16 of 26 Old 07-31-2009, 03:02 AM - Thread Starter
Thankyou,
It looks complicated,but not really but I do connect and swap them for different sources,bluray and 2 channel stereo.
Regards Victor.
post #17 of 26 Old 07-31-2009, 03:22 AM - Thread Starter
Thankyou i30krab,
post #18 of 26 Old 07-31-2009, 03:37 AM - Thread Starter
Thankyou Waboman,
ML,s are great for HT and 2 channel(surround too) but you all ready know that,
Cheers
Thankyou Croseiv,
In winter must still cool room,but it nice and toasty all year round,
Regards Victor
post #19 of 26 Old 12-19-2009, 12:07 AM - Thread Starter
NEW SPEAKERS.
This week had some speakers,Avantgarde Duo,s arrive with 300b amp to follow soon for use in System 2 downstairs and the start of a new 2 channel system even with entry level components the sound is very,very promising.
Regards Victor.
post #20 of 26 Old 12-20-2009, 12:40 PM
Blues In Thirds
javry's Avatar
Hey Victor,
Could we have somemore pics since you now have the Duos? It'll be interesting to hear your comparisons between Avantgarde and ML in a HT setting.....not to mention their response to tubes.
javry is offline
post #21 of 26 Old 02-02-2010, 03:47 AM - Thread Starter
Originally Posted by javry View Post
Hey Victor,
Hi Javry,
I will get to post pic,s soon sorry reply took a while been away.When new amps to use with Duo,s arrive(system 2) I will post comparisons at the moment Duo,s with cheap denon Avr sound good.Main System is around 10 times AUS $ OF system 2,so not really fair.They have the same traits,low level detail,speed and dynamics(these and more make things sound real,main system adds timbre,tone,delicate and holographic,those ref600mkIII really are that good words fail(believe the hype they are that good.)
Tubes and ML adds weight,ie they have speed but can sound light with ss amps when they should not.With Larger tube amps they add power and speed(wilson Alexandria X2 watch out) listened at less than 110db above this level Duo,s will have the edge as they can do 125db plus too loud for me.I always use db meter as both systems get loud and don,t sound that loud(very low distortion.)ML for HT excell.they do require better amps etc as very revealing of sub standard components and drive 1 ohm loads.
Cheers Victor.
post #22 of 26 Old 02-02-2010, 07:27 PM
kevon27's Avatar
Quoted: 163 Post(s)
Liked: 189
You need a bigger house. Your components are crying for room to breath!
kevon27 is offline
post #23 of 26 Old 02-26-2011, 03:14 PM - Thread Starter
Attachment 203389
Attachment 203390
Attachment 203391
Attachment 203392
Attachment 203393
2 new subs 125l mal x2 with peavey 4080hz 2000 rms per sub ,used with 2 revel b15 and Svs aseq1 for sub eq (very impressed ).
To install JVC Rs2 and 110inch 16x9 screen (can,t wait ) .
Using a panasonic bd85 as a temp player(does bass Management correctly) while i choose new player to mod (oppo 95 maybe) and move pana to small system .
Cheers Victor.
post #24 of 26 Old 02-28-2011, 10:47 AM
BrolicBeast's Avatar
Quoted: 1358 Post(s)
Liked: 1430
Originally Posted by ddgtr View Post
victor,
Dan
I couldn't stop laughing that the whole "Spare" comment. That's like someone having a spare helicopter. lol
BrolicBeast is offline
post #25 of 26 Old 04-24-2011, 04:18 PM - Thread Starter
Attachment 209999
Attachment 210000
Projector (jvc hd-100/rs2 ) and screen 110inch 16:9 was installed 1 week ago and after many movies I am more than impressed with the result.
Going from a 70inch tv to the larger screen adds so much detail even movie studio logos are new with details not noticed on a small screen.Now movies have greater emotional impact , I had avoided getting a projector , for a long time thinking not missing too much.
Now I see that it makes a big difference to a movies impact , like the audio side does .
Main seat is 3.6m from screen and projector is ceiling mounted approx 4m from screen.Projector has really impressed me great black levels and is very sharp.Bluray is as expected very good, dvd,s are ok and some much better than expected (I only buy bluray,s in the last 3yrs ).
Nearly finished.
Cheers Victor.
post #26 of 26 Old 04-24-2011, 07:40 PM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
No scope? Kinda surprised but still awesome projector and I bet it looks and sounds spectacular. Consider me quite jealous of all that audio bliss.
pcweber111 is offline
