Roger That 2.0: New Digs, New Gear, New Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 110 Old 03-18-2011, 03:48 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 150
Nice setup, nice photos. I dont think I have ever been in that area of Chicago.
The TV seems to be up a bit high? is that just my imagination, or is it a bit above eye level?
"But this one goes up to 11"
MichaelJHuman is offline
post #92 of 110 Old 03-18-2011, 02:06 PM - Thread Starter
Roger That's Avatar
Nope. Eye level is about a third of the way up on the TV, and the TV is angled slightly downward. The PJ screen is higher than I would like by a few inches, though, and I might add something to lower it a bit.
Roger That is offline
post #93 of 110 Old 03-19-2011, 06:08 AM
Dr.Evazan's Avatar
Quoted: 54 Post(s)
Liked: 68
angling oyour tv was a good idea. i just bought a new panny and im struggling to find a happy medium between tv height and center channel height (the center is right beneath it)
Dr.Evazan is offline
post #94 of 110 Old 04-01-2011, 03:18 PM
The Dark Knut's Avatar
1st off AWESOME. 2nd you placed your subs directly behind the couch. What brought you to do this and any problems with being able to localize the subs? How did you get them to blend in?
Repetition penetrates even the dullest of minds.
The Dark Knut is offline
post #95 of 110 Old 04-03-2011, 03:30 PM - Thread Starter
Roger That's Avatar
Placement behind the couch is a product of having nowhere else to put them. Didn't have room up front, and the room simply isn't big enough to place them anywhere else without it looking like they're out of place.
As far as blending, they don't localize at all. Audyssey MultiEQ XT32 has done some awesome things with my room, IMO. Eventually, I plan to add an SMS-1 or similar to try and improve it further.
post #96 of 110 Old 11-22-2011, 08:14 PM
thaxphenomx's Avatar
I just stumbled upon this thread while googling Salamander Synergy Stands with an Emotiva amp haha. First off, your condo is amazing. I must admit your home theater setup has given me some great ideas. I think I'm now going to do something similar for the surrounds. I currently have my rears on the wall behind the couch 8 feet off the ground angled toward the listening area and there is much to be desired there. How do you like your surrounds close to your couch like that?
I've been planning on getting basically everything you have component wise haha. I haven't decided on my front stage speakers yet but the Verus Grand line is in the running. Looks like you give them a nice recommendation.
I'm with you on speaker cables, I don't mind paying to get high quality, good looking cables even if they don't add to the sound quality. I love the looks of the Emotiva speaker cables.
I was planning on getting the Salamander Synergy Triple and down the road an Emotiva amp. If I get the doors and leave the back panel off do you think I'll be okay? I will probably have to have the stand a few inches away from the wall to make sure the amp fits.
Awesome setup man. Thanks for the pics.
thaxphenomx is offline
post #97 of 110 Old 11-25-2011, 08:51 AM - Thread Starter
Roger That's Avatar
Thanks, thaxphenomx.
I don't mind the surrounds where they are, but as is the case with most of my placement decisions, there aren't a lot of other choices. I toyed with the idea of ceiling-mounting them, but didn't feel like that would look that great when you enter the room, and would limit my never-ending tweaking of things. As much as I love my place, I long for a larger room just to spread things out a bit. My speakers can really fill up a room pretty well, and it would be great to have the room to push them.
On the Synergy stand, I've now had it for two years, and am still a huge fan of it. Incredibly strong, high-quality, and still looks great. Definitely a step up from the MDF stuff I've always had in the past. Yes, as long as you leave the back off, you could add doors to the front and have the Emotiva amps fit nicely. They hang out the back, but it's no big deal to me.
I'm due for some new pictures at some point. I've replaced the XPA-3 with an XPA-5, moved the subs to the front (which doesn't look as good, but sounds a LOT better), and angled the surrounds a bit differently. The UPA-2 is still there, but I don't use it, currently; I plan to add heights at some point, I think, which the UPA-2 will power.
Thanks again.
post #98 of 110 Old 11-25-2011, 01:29 PM
Yeah if you could take some pictures that would be great. I'd like to see the back of your synergy stand with your amps and the surround speakers. Good idea with the subs, you should look into auralex products. It made my sub sound even better. I have a couch shaped just like yours and not a lot of room around the couch so the speakers would need to be close like yours. What stands are those on and how did you get the speaker wires back there cleanly?
Thanks for sharing your setup. I'm constantly tweaking my system as well and just buying a little at a time. I'm going to take pictures of my setup and start my own thread soon.
post #99 of 110 Old 12-02-2011, 12:16 PM - Thread Starter
Roger That's Avatar
For stands I just got some generic ones from Aperion...it was whatever they had on their site. They can probably be had on standsandmounts.com or similar.
On the cabling, I used techflex around the window-side of the room...it's surprisingly invisible to the eye unless you're looking for it. Works great!
post #100 of 110 Old 12-06-2011, 06:09 PM
Spanbauer's Avatar
Incredible setup, incredible home! Very well done, Roger that!
Click here for my home theater setup
Spanbauer is offline
post #101 of 110 Old 12-13-2011, 04:38 PM - Thread Starter
Roger That's Avatar
Thanks, Spanbauer!
post #102 of 110 Old 12-21-2011, 03:30 PM
trek737's Avatar
Very clean and beautiful setup. Oh yeah not a bad few either!
trek737 is offline
post #103 of 110 Old 01-16-2012, 08:40 AM - Thread Starter
Roger That's Avatar
Thanks, trek737
post #104 of 110 Old 01-16-2012, 11:35 AM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
Very nice set up! Didn't see that projector in the first place lol
pokekevin is offline
post #105 of 110 Old 03-12-2012, 03:53 AM
Ralph-Holland's Avatar
Very nice setup Roger! It looks really cool.
Do you post a picture with the subwoofers on the front?
Ralph-Holland is offline
post #106 of 110 Old 03-15-2012, 06:48 AM
SJTrance's Avatar
Beautiful place, man. Awesome.
SJTrance is offline
post #107 of 110 Old 05-10-2012, 02:26 PM - Thread Starter
Roger That's Avatar
Thanks, guys!
Ralph, I haven't posted a pic with the subs up front. Keep meaning to do that. I have some on my camera at home. Traveling currently, but will post one when I get back.
post #108 of 110 Old 05-28-2012, 10:22 AM - Thread Starter
Roger That's Avatar
Finally getting around to posting a couple of pics with the subs up front:
Also updated original post to reflect the change.
post #109 of 110 Old 06-04-2012, 08:01 PM
BasicBlak's Avatar
I continue to be completely and utterly awestruck at your fabulous setup, Roger... Simply amazing! Keep up the great work, my friend.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #110 of 110 Old 02-06-2015, 05:50 PM
darthray's Avatar
Quoted: 1101 Post(s)
Liked: 1013
Originally Posted by Roger That View Post
***EDIT 5/28/12: Updated to accurately reflect gear and new photos.***
So, I bought a condo...upgraded the theater in addition to the living space.
Here's the old apartment setup/thread.
Video:
Pioneer Kuro KRP-500M (Broken In, Patched, and Calibrated by D-Nice)
Panasonic PT-AE4000U
DaLite Contour Electrol 119" (HP Fabric)
Audio:
Onkyo PR-SC5508
Emotiva XPA-2
Emotiva XPA-5
Aperion Verus Grand Towers Front
Aperion Verus Grand Center
Aperion 5B Surround
Aperion 4B Surround Back
(2) Rythmik F15HPSE Subs
Sources:
DirecTV HR24 HD-DVR
Playstation 3
iTunes/AirTunes/AirPlay
Apple TV
Misc:
Salamander Synergy Stand (Maple/Black)
GIK Acoustic panels/bass traps
Harmony One
Tartan Cables
Emotiva Cables
Monoprice Cables
Panamax 5300
Pics:
And here's a pic with the screen down:
Very nice condo set-up
How do you like your aperions?
I got the same Verus Grand for the front.
They do look a lot more different with the grills on, I got mines with-out (can be seen here).
The Chimaera theater
I think, if you got your self a bigger area carpet, it could do wonder for your sound.
And your cat on the last picture look gorgeous
What a beauty.
Ray
darthray is offline
