New setup revisited - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 08-01-2010, 10:31 AM - Thread Starter
Liked: 62
Well, I moved to a new place, so I figured I should post my new setup. Plus, I have some new stuff.
TV is a Samsung 720p DLP. I've been toying with getting a larger Mitsubishi DLP or a flat panel, but this thing just keeps on truckin'.
Speakers are Athena Audition series F2.2s, C1.2, and four B1s (the original black woofers.) Sub is a Bic Acoustech H-100, that will get a DIY Subdude to minimize physical vibrations.
I used to have a 7.1 with rear surrounds. I've since switched to front heights because the room layout is different. I've also moved all the components except the cable box from under the TV to an outboard component shelf rack.
Closeup of one of the B1s as a side surround. Not shown is its mate on the other side. The other two heights are shown in the main pic.
Detail of the Omnimount shelf that holds the center. I often get questions of how it stays up there. This shelf is solid and keeps it up even in mild earthquakes. Speaker is also slightly tilted by a small rubber doorstop, $1.40 at Home Depot.
Components. From the top: Onkyo TX-NR807 receiver, Onkyo DV-CP706 DVD changer, Onkyo TA-RW255 cassette deck (still have lots of cassettes), and a Mitsubishi HS-U748 SVHS VCR. I like to use legacy equipment, even if it isn't up to modern standards.
And yes, I'm an Onkyo slut of sorts. Actually, I like DVD changers (and wish a Blu-ray 5-6 disc one existed) and Onkyo's cassette deck is pretty good. I may update to a Blu-Ray player at some point, but I haven't found one I really like yet. I have no interest in 3D at this point.
Yes, I need some cable management. I'll try to clean it up sometime.
Right now the system is pretty good as is. Probably the TV is the next upgrade, but that's sometime down the road.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #2 of 28 Old 08-05-2010, 05:57 PM
bfm
bfm's Avatar
Looks great but hide the wires man. You need only a stud finder, a fish, electrical tape and a friend who can respackle your drywall after you fill the holes w mud?
So easy. Nice system must sound awesome.
bfm is offline
post #3 of 28 Old 08-05-2010, 07:27 PM
hikarate's Avatar
Hey how you like the front heights vs the 7.1 surround configuration? Nice setup.
hikarate is offline
post #4 of 28 Old 08-05-2010, 07:30 PM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
OK. Now, I will pile on. You really need some acoustical treatments or, at the very least, some other stuff on the walls to break up all those uninterrupted reflective surfaces.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5 of 28 Old 08-05-2010, 08:36 PM - Thread Starter
Liked: 62
Not much difference, to tell you the truth, but it definitely seems to fill in the front sound.
Tulpa is offline
post #6 of 28 Old 08-05-2010, 08:40 PM - Thread Starter
Liked: 62
Well, I rent the place, so I don't know how kosher doing that will be. I already use wiremold to hide the wires going around the room. It's just behind the TV and stand where it's bad.
Tulpa is offline
post #7 of 28 Old 08-05-2010, 08:42 PM - Thread Starter
Liked: 62
The area behind the TV? Any suggestions? The opposing wall already has some pictures and stuff up. The wall with the sliding door I can't do much for. I can't alter the blinds per apt. management.
Tulpa is offline
post #8 of 28 Old 08-05-2010, 09:23 PM
hikarate's Avatar
Blinds are vinyl and should be better acoustically than walls and other flat surfaces based on what I have read. Someone with more experience than me can correct me if I am wrong. Thanks for the reply.
hikarate is offline
post #9 of 28 Old 08-06-2010, 07:45 AM
Quoted: 771 Post(s)
Liked: 542
Trivially better if they have glass behind them.
Kal Rubinson
post #10 of 28 Old 08-06-2010, 08:27 AM - Thread Starter
Liked: 62
Yeah, unfortunately there is.
Looks like they make some stylish treatments. Maybe one behind the TV between the front heights? Swap out the stuff on the other side for another one? Traps in the corners?
Granted, about where I took the photos is a wide open space, so that and the doors might be the biggest problems that I won't be able to solve. Maybe swap the bedroom and living room?
Tulpa is offline
post #11 of 28 Old 08-06-2010, 09:42 AM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Hey bud you could do what my wife likes to do and hang a hand made quilt on the wall. See my pics on my system page. You will see one hanging behind the TV and near the bottom of the first page there is another HT themed quilt she made hanging above the couch. It is not to be confused with bass traps or sound absorbers but it does remove some of the slap echos in a room.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #12 of 28 Old 08-06-2010, 01:01 PM
eggyhustles's Avatar
Quoted: 14 Post(s)
awesome
eggyhustles is offline
post #13 of 28 Old 08-08-2010, 07:21 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
That's illegal unless the wires are in-wall rated.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #14 of 28 Old 08-12-2010, 01:58 PM
vzphoneman's Avatar
Quoted: 105 Post(s)
Liked: 109
this may help dress things up a bit...you can slip multiple cables in each sleeve. ends up looking like high end cable.
http://www.parts-express.com/wizards...fg&srchMfg=299
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #15 of 28 Old 08-12-2010, 03:37 PM
AvGeek07's Avatar
you might want to look at ats acoustic panels, i have 4 of them on the first reflections spots in the room,you can hang them like a picture. http://www.atsacoustics.com/
AvGeek07 is offline
post #16 of 28 Old 08-16-2010, 04:40 PM - Thread Starter
Liked: 62
My aunt actually said she was going to make one for me at some point.
Tulpa is offline
post #17 of 28 Old 08-26-2010, 07:06 AM
caper_1's Avatar
Liked: 26
Yeah, monoprice sells in-wall rated speaker wire, hdmi, etc (UL, CL2, etc)...that's what I used as well as wirewold, and also removed a baseboard and chisled the very bottom of sheetrock about the width of a flathead screwdriver...then I made a small groove in the back of the baseboard so I could run the cable behind it, instead of on the outside so when I put the trim back on, so sign of wire whatsoever. The wirewold stuff is paintable so I rolled it before installing to match the walls...
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #18 of 28 Old 09-26-2010, 09:29 AM
fookoo_2010's Avatar
Quoted: 245 Post(s)
Liked: 84
You are in LA, so think about coming out to some of the LA Home Theater system meetings or get togethers. You will find it fascinating to see stuff that you can only dream about and possibly learn something in the process, especially when talking to some of the members. On the AVS Forum go to: Area Home Theater Meets and find the LA branch.
fookoo_2010 is offline
post #19 of 28 Old 12-27-2010, 12:23 AM
micksh's Avatar
You have a cassette deck. That's so nice.
What brands of cassette tapes did you guys have in US? I saw Sony, Maxell, TDK, Memorex in early 2000's when I came here from Europe. But I saw only basic models that were on sale in large stores like Best Buy. I'm sure audiophiles had variety of options.
Did you have BASF? I think BASF looked very nice. I still keep few different BASF cassettes for memory. Chrome Maxima, Reference Maxima TPII, few models, just as on these pictures:
http://www.google.com/images?hl=en&q...w=1200&bih=819
Some tapes looked so classy, like these BASFs, Sony UX-S/Pro and other higher end models. Inserting them into cassette deck was like handling a piece of art.
micksh is offline
post #20 of 28 Old 12-28-2010, 10:24 AM - Thread Starter
Liked: 62
I still have a ton of cassettes and don't feel like rebuying them in CD mp3 whatever the new format is format.
I think we also got most of the brands you mentioned, but not sure about BASF. But I think I remember seeing it.
Tulpa is offline
post #21 of 28 Old 01-03-2011, 09:35 PM
mikieson's Avatar
LPs and Cassettes are great to look back on and "remember" but I cant imagine ever listening to them over digital..not even these high end turn tables would change me..BUT having said that...nice set up TC
mikieson is offline
post #22 of 28 Old 01-05-2011, 02:11 PM - Thread Starter
Liked: 62
I don't think the cassette signal ever goes to digital on this setup. Analog connections all the way through I would think.
Tulpa is offline
post #23 of 28 Old 01-23-2011, 04:38 PM
ahwig60's Avatar
Quoted: 17 Post(s)
what do acoustic panels do or help with?
ahwig60 is offline
post #24 of 28 Old 01-27-2011, 01:25 PM
basehitter3's Avatar
i like the one lazyboy in front of the tv
basehitter3 is offline
post #25 of 28 Old 02-10-2011, 05:21 PM
pcampbel01's Avatar
The system must boom when sitting in the lazy-boy. I like the corner wire mold, but if you have exposed wires, make them a statement.
pcampbel01 is offline
post #26 of 28 Old 12-13-2011, 05:51 PM
slinkeey's Avatar
Nice
I just had to click that link on your postings..
I also have a thing for the older stuff. I have a Turntable and a CD Player hooked up to my system.. I got rid of my Mitsubishi DT-10 Tape deck about maybe 5 years ago. I didn't have many tapes but it hung around for some reason.
slinkeey is offline
post #27 of 28 Old 12-13-2011, 07:15 PM
jproy13's Avatar
Liked: 26
Nice gears and nice to see another Athena owner
jproy13 is offline
post #28 of 28 Old 08-06-2013, 09:04 AM
excusemaker's Avatar
that's a cool looking set up you have there. very nice! it reminds me of my old system I had when I lived in calfornia. I believe you stated you live in an apartment. if you ever buy a house you really should consider an in wall audio system. it will save you a lot of space. your equipment looks very nice though and I especially like how clean your place is.
you mentioned you don't have 3d tv and all the new goodies out. everyone I know that has it doesn't use it so you aren't missing out on much. I don't have the newest stuff either. I don't know if you've ever watched Netflix, but most of the new blueray players come with it. I actually watch Netflix with my blue ray player more than I ever watch blueray discs and dvds. they have some blue ray players that are wireless too so you don't have to worry about running a cable from your router. 100 bucks for a cheap blue player at frys that will do it all.
as for cable management I wouldn't worry too much about that. the main thing I would do is try to keep the power cords away from the communication cables and that's about it. at frys they have a big ole thing of zip cords for under 10 bucks you can get to tie your cabling together to clean it up a little.
your setup is very nice. I like it a lot! thanks for sharing.
I look forward to learning more from all of you.
excusemaker is offline
Athena , Acoustech H 100 Cinema Series 500 Watt Front Firing Subwoofer , Onkyo Tx Nr807
