Thrang's Home Theater (for now...) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
post #451 of 821 Old 05-12-2013, 07:33 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
I'm using Bryston 4B-SST's.
Rod#S is offline
post #452 of 821 Old 05-12-2013, 07:36 AM - Thread Starter
thrang's Avatar
Quoted: 1945 Post(s)
Liked: 1635
Originally Posted by Rod#S View Post
Two guys plus myself but the actual lifting was done by the movers. As with the 802's we didn't follow the unpacking instructions on the box to the letter. The guys and even myself were more comfortable with having the speaker lifted up and off of the pallet bottom rather than laying the speaker over on it's side to slide the pallet bottom off then standing it back up. Obviously they were strong enough to do the lift if not then laying the speaker on it's side per the instructions would have been the only way of getting the pallet bottom removed. If going the lift approach just be warned that there is very little room for your fingers under the plinth so there is a potential finger crush factor there smile.gif You could lift the speaker by grasping the bottom of the bass cabinet rather than the bottom of the plinth I guess. Also now knowing how heavy these things are if you are going to lay them on their side on hardwood make sure that there is ample padding around the plinth because that could make a serious dent if it's edge catches the flooring while standing the speaker back up.
Yes, with my back surgery I'lll be a tit on a bull for this. so I'll leave it up to my dealer to figure it out....
Box slides all the way up to remove? I have to be careful where I do this with my new ceiling treatments...
thrang is online now
post #453 of 821 Old 05-12-2013, 08:12 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Actually the cardboard simply peels away so it's not like a typical speaker box where it must be lifted up and over the top of the speaker so no need to worry about your ceiling. If you remember how your 802's were boxed it's basically the same idea. You first remove the top cap then release the cardboard surrounding the speaker, it is just interleaved with the pallet base to help hold it in place vertically. So the releasing of this cardboard wrapping is either done vertically like was done with mine or first by lying the speaker on it's side. If on it's side then the base pallet is simply popped off then the speaker is set up right again where the styrofoam piece over the head unit is removed then the 4 corner pieces are removed then the 2 interlocking styrofoam pieces around the bottom are removed. I think that's the order how things are removed. Then it's a matter of removing the soft blanket material enclosing the speaker, removing the bass grilles to take off their shipping material, installing the mid range grilles from the accessory boxes and removing the protective covering from the back of the high frequency nautilus tube. After that you remove the locking screw from the end of the mid range nautilus tube and of course taking the plastic plugs out of the speaker terminals where banana's attach.
How's the back? I hope the surgery went well.
Rod#S is offline
post #454 of 821 Old 05-12-2013, 08:51 AM - Thread Starter
thrang's Avatar
Liked: 1635
I'd completely forgotten how the 802 boxes came apart - the 803's I had to slide up and off I believe....
Surgery went well - just a lot of basic mobility and walking now, no rehab for a bit...I'm getting around fairly well without a cane or walker - just having bouts of chills and sweats - they did blood work to check for infection, and it came up clean - maybe reaction to the pain killers, or just residual body reaction to the trauma of the surgery.
post #455 of 821 Old 05-12-2013, 09:09 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Glad to hear things went well with the surgery and the blood work is good. It'll probably just take some time to get back into the swing of things, the body deals with surgery in so many different ways for different people.
Rod#S is offline
post #456 of 821 Old 05-13-2013, 06:10 PM - Thread Starter
thrang's Avatar
Liked: 1635
They're coming...hopefully Thursday
Was able to sell of my 2 pairs of 805's, one pair of 803's, and an MC302 very quickly to fund this...
post #457 of 821 Old 05-13-2013, 06:12 PM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
adidino is offline
post #458 of 821 Old 05-13-2013, 06:17 PM - Thread Starter
thrang's Avatar
Liked: 1635
Yeah like you subsist on peanut butter and jelly Mr Plats!
post #459 of 821 Old 05-13-2013, 06:44 PM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
adidino is offline
post #460 of 821 Old 05-13-2013, 09:47 PM
Nuz1's Avatar
Wow, thats going to be something! Did you get three 601s for the front? Or a pair for the 800s?
Nuz1 is offline
post #461 of 821 Old 05-14-2013, 05:40 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Very nice.
Amazingly quick sell for the McIntosh as well. With so much Mac stuff on Audiogon I figured it would take longer to sell the amp.
I look forward to your impressions, both comparisons for the 800's to the 802's and the extra 3db in power by going with 601's
Then after that I await the selling of all Mac gear and getting all Bryston biggrin.gif
Rod#S is offline
post #462 of 821 Old 05-14-2013, 10:52 AM - Thread Starter
thrang's Avatar
Liked: 1635
Very nice.
Even with help, reconfiguring your HT 10 days after back surgery is not so bright....
Anyway, NO BRYSTON! Huge respect for them, but that's addino's home turf in my neighborhood.
post #463 of 821 Old 05-14-2013, 06:16 PM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
So will you have a chance to listen to the 800's with your 302 or 303 before hooking them up to the 601's or is that a pairing that is never going to happen just do to the timing of everything arriving? It would be nice to get your impression of the difference that doubling of the power makes. Out of curiosity have you ever tried bi-amping your 802's just to see if you can hear any differences?
Rod#S is offline
post #464 of 821 Old 05-14-2013, 06:48 PM - Thread Starter
thrang's Avatar
Liked: 1635
I don't think that will happen, all likely comes in together
No have not bi-amped in some time...
I think Thursday is the day at this stage....
post #465 of 821 Old 05-14-2013, 08:32 PM
WestCoastD's Avatar
Quoted: 285 Post(s)
Liked: 106
Originally Posted by thrang View Post
They're coming...hopefully Thursday. Was able to sell of my 2 pairs of 805's, one pair of 803's, and an MC302 very quickly to fund this...
so you ultimately switching to 7.1? or 5.1?
WestCoastD is offline
post #466 of 821 Old 05-14-2013, 08:36 PM - Thread Starter
thrang's Avatar
Liked: 1635
7.2
800D fronts
802D Surrounds
803D Rears
HTM2D Center
2 - JL Audio F113 Fathoms
post #467 of 821 Old 05-15-2013, 06:03 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Rod#S is offline
post #468 of 821 Old 05-15-2013, 06:20 AM - Thread Starter
thrang's Avatar
Liked: 1635
Actually....
post #469 of 821 Old 05-15-2013, 06:57 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Nice!
Be sure to give us some pics of the unboxing. I got to excited when mine arrived and didn't take anywhere near as many as I had intended biggrin.gif
Rod#S is offline
post #470 of 821 Old 05-15-2013, 07:33 AM - Thread Starter
thrang's Avatar
Liked: 1635
Nice!
I will try but I suspect there will be so much mayhem I may forget too...!
post #471 of 821 Old 05-15-2013, 01:19 PM - Thread Starter
thrang's Avatar
Liked: 1635
Looks like Friday late morning now....cant get the manpower till then....
post #472 of 821 Old 05-15-2013, 02:07 PM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Oh well, at least you will have them for the weekend smile.gif and they did arrive very quickly to boot.
Rod#S is offline
post #473 of 821 Old 05-15-2013, 06:35 PM - Thread Starter
thrang's Avatar
Liked: 1635
I know, but I keep reading your comments about your experiences and I'm convinced you're just rubbing it in! smile.gif
post #474 of 821 Old 05-16-2013, 04:54 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
lol...I'll take full credit for your urge to upgrade IF you hear a difference over your 802's and that the difference is indeed good. I take no responsibility if you think they sound exactly or incredibly close to your 802's tongue.gifbiggrin.gif
Rod#S is offline
post #475 of 821 Old 05-16-2013, 05:07 AM - Thread Starter
thrang's Avatar
Liked: 1635
post #476 of 821 Old 05-16-2013, 05:56 AM
BVLDARI's Avatar
Liked: 27
I'd love to hear your opinion between the 303 and 601s
BVLDARI is offline
post #477 of 821 Old 05-16-2013, 06:04 AM - Thread Starter
thrang's Avatar
Liked: 1635
Well, the most I can do is compare the 802/303 vs the 800/601 as the swap will be simultaneous...
post #478 of 821 Old 05-16-2013, 06:57 AM
BVLDARI's Avatar
Liked: 27
I just noticed that you have a D100 and a mac mini which is something I am considering. How would you compare the D100 to the Marantz or I am guessing that the Marantz did not have asynchronous USB inputs? Also, how is the D100 vs. the MX151. Finally, if you had to do it again, would you go this route or something different.
BVLDARI is offline
post #479 of 821 Old 05-16-2013, 07:25 AM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
The MC601's would make quite the leap from the MC302/MC303 in my opinion so this change alone will be quite the difference.
I noticed a positive difference when going from MC205 -> MC452 -> and finally MC601. The added headroom makes all the difference. I could just raise the volume much more on each subsequent upgrade without hearing the speaker or my ears strain!
See Profile
scanido is offline
post #480 of 821 Old 05-16-2013, 07:28 AM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
The amp upgrade would make almost as much of the difference as this speaker change. When I got the MC601's my 802Di's started to open up fully. Low volume was even more pronounced and detailed, I dont have to raise volume to hear the same details.
The 800Di's will soak up every little bit of power from those MC601s for sure. Should be a decent match.
See Profile
scanido is offline
anthem avm 60 , B W , jbl 708 , jbl m2 , Jl Audio Fathom F113 Gloss 13 5 Inch Powered Subwoofer , Mcintosh Labs , Med1000x3d Hd 3d Multimedia Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Sony Vpl Vw1000es Projector , sony vpl-vw5000
