Thrang's Home Theater (for now...) - Page 24 - AVS | Home Theater Discussions And Reviews
post #691 of 705 Old 04-25-2015, 06:16 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
Updated the first post in this thread with the new ceiling upgrade...I'll post a little more detail and a few build out photos a little later
Listening: Constantinople from "Modern Cool" by Patricia Barber (Rating 8/10) • Watching: "Captain America: The First Avenger" (Blu Ray ISO) (Rating 9/10)
Thrang's Theater: Sony VPLVW-1100 - Bowers & Willkins 800/802/803/HTM2D D2 Diamond - JL Audio Fathom 113 - Lumagen 2143 - McIntosh MX-151 - Parasound Halo JC1/A51 - Oppo 103 - Dune Smart B1/Synology 20TB NAS - DirecTV Genie - TiVo Roamio - Apple TV - PS4 • Audio: Sennheiser HD800 - Oppo HA1 - Kef LS50 - iTunes/Pure Music - iMac 5k
thrang is online now
post #692 of 705 Old 04-25-2015, 06:33 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
For a few different reasons, I decided to install a drop ceiling in my theater, beneath the existing sheetrock ceiling. Since the ceiling was a little over 9 feet high, I could afford a 6-7" drop without any feeling of being cramped.
Especially, I was hoping to:
1) mitigate sound transfer to my daughter's bedroom above
2) improve sound in the room
3) eliminate the white reflective ceiling and improve screen image quality
4) provide an easy chase to pre-wire for in ceiling elevation speakers
I went with CertainTeed's Theater Black 2x2 tiles, a semi-rigid spun fiberglass tile with a flat black fabric surface, in 5/8". I then backed all tiles with cut Owens Corning 703 foil faced board, 2" thick. Installation was a combination of myself, my son, a friend, and a professional.
I also added 8 Auralex T'fusor diffusion tiles in the ceiling to scatter some sound, but just absorb. They come white, but I painted them flat black, which I also did for my AC air diffusers.
It begins
My son installed the hangers, screwed through the drywall and resilient channel layer into the laminate beams above
Using an old in-walll speaker location to chase ceiling speaker wires up from the basement rack location
This was a bitch job...
post #693 of 705 Old 04-25-2015, 06:43 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
For the AC air diffuser, the drop was too short, nor could I find any obvious adapter to connect to the 8 x 8 box, which was finished flush with the existing sheetrock -
so we improvised, screwing the diffuser into a sandwhich of finished tile/OC703 board (to anchors, shown below on the backside), and then making 8x8 (inside dimension) collars from the OC board (so open on top and bottom) taped with aluminum duct tape. The height was measured to be a snug fit between the sheetrock and the inside of the OC board. We then simply slid the collar between the ceiling and the diffuser/panel "sandwich"', and the snug fit lets the air fall right through from the sheet metal box above through the diffuser in the tile.
markrubin likes this.
post #694 of 705 Old 04-26-2015, 07:17 AM
CIH USER
Franin's Avatar
Quoted: 808 Post(s)
Liked: 510
That's a good idea Thrang you've got me thinking!!
Frank
_________________________
Frank
Franin is offline
post #695 of 705 Old 04-26-2015, 08:42 AM
G-Rex's Avatar
Quoted: 39 Post(s)
Thrang, what ceiling speakers are you going to use? How many...and describe placement in relation to your one row of theater chairs? Thanks.
G-Rex is offline
post #696 of 705 Old 04-26-2015, 08:52 AM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
I will likely use the KEF CI200RR-THX, which apparently have a dispersion that exceeds the spec...I will post more about positioning in the next few days
post #697 of 705 Old 04-26-2015, 09:29 AM
miliotov's Avatar
Quoted: 21 Post(s)
Hi Thrang,
Since you have expercience with Mcintosh and Parasound and B&W I think I should ask you this question.
I bought B&W CT8.4 frontspeakers (3) and I'm hesitating between 2 amps: McIntosh mc207 and a Parasound A51+A31.
Is there a big difference in SQ between these amps?
Any advise is welcome.....
miliotov is offline
post #698 of 705 Old 04-26-2015, 12:11 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
Originally Posted by miliotov View Post
Hi Thrang,
I started with a McIntosh 7 channel amp, then went to two channel and finally the 601 monoblocks...
I am running the Parasound monoblocks for the front, and the A51 for surrounds...I do prefer the Parasound sound and would not revert.
post #699 of 705 Old 04-27-2015, 08:54 AM
Rod#S's Avatar
Quoted: 126 Post(s)
Liked: 35
Seeing all that work going on around your speakers makes me cringe. I see a guy getting way to close for comfort in one of your pics. No way would I have had the speakers in there during the renno, you are very trusting of the workers
Rod#S is offline
post #700 of 705 Old 04-27-2015, 09:13 AM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
I know, but really no option to remove them easily and on the short timeline, and the room is sunken so they'd have to be carried out up a few steps...I hovered around speakers as work approached them, and used some blankets at times...
post #701 of 705 Old 05-04-2015, 07:46 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
Ten star field tiles should be delivered early next week...five wide, two deep over the seating area...
post #702 of 705 Old 05-05-2015, 05:43 AM
G-Rex's Avatar
Quoted: 39 Post(s)
That will be a nice touch. Thought about having my ceiling painted with glow in the dark stars. Haven't done it yet.
G-Rex is offline
post #703 of 705 Old Yesterday, 01:03 PM
RichB's Avatar
Quoted: 424 Post(s)
Liked: 302
That is a stellar system. I am sure it sounds fantastic.
Enjoy !
- Rich
Oppo Beta Group
Oppo BDP-105D | Oppo HA-1 | Oppo PM-1 | Parasound A21 + A21 + A51 | Revel Salon, Voice, Studio | Velodyne HGS-15
RichB is online now
post #704 of 705 Unread Today, 12:47 PM
Quoted: 37 Post(s)
Liked: 3
Ultimate setup if it has Black diamond screen
w1000i is offline
post #705 of 705 Unread Today, 03:55 PM - Thread Starter
thrang's Avatar
Quoted: 396 Post(s)
Liked: 351
I never explored much because they don't make a screen large enough, or at least they didn't...
Mcintosh Labs , B W , Jl Audio Fathom F113 Gloss 13 5 Inch Powered Subwoofer , Sony Vpl Vw1000es Projector , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Med1000x3d Hd 3d Multimedia Player
