Frohlich's Marantz/Paradigm/Panasonic Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-06-2010, 02:22 PM - Thread Starter
Frohlich's Avatar
Quoted: 1164 Post(s)
Liked: 1112
I recently bought a few upgrades so I thought I would post some pictures.
Equipment:
TV:Panasonic 65vt25 3d tv
Front Speakers: Paradigm Studio 20 V5
Center Speaker: Paradigm Studio cc590 v5
3 surrounds: Definitive Technoloby BPX
Subwoofer: Paradigm SUB 15
Pre/Pro: Marantz av7005 with HDMI 1.4
Amplifier: Marantz mm8003 8 channel amp
XBOX 360
Blu Ray: Panasonic 35
Bello TV stand
Here are some pictures (though I stink at taking good pictures):
Frohlich is online now
post #2 of 17 Old 11-06-2010, 03:54 PM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
Nice system Frohlich. Lets get those front speakers higher up or at least angle them up to the LP. Where's the sub 15?
Oh I see it there in the corner.
Hometheatergeek
aka AL
My Current System
hometheatergeek is online now
post #3 of 17 Old 11-06-2010, 06:56 PM - Thread Starter
Frohlich's Avatar
Liked: 1112
Though I am very happy with my system, I do have a wife and two kids and there have to be some compromises with the spousal unit. That includes not having tower speakers, running all the wires so they are not showing underneath the HT room and hiding the sub next to the chair and other things to integrate the HT into the family decor.
post #4 of 17 Old 11-07-2010, 06:27 AM
bencorn's Avatar
Nice gear, I looked at that set of speakers but couldn't find a place to listen to them locally. I too have to consider the wife approval factor in most of what I do which sometimes dampers things. I don't know how much she would mind but would it be possible to move the L and R front speakers into the corners? Moving them out to the corners of the room will give a much wider front stage and should give you more sense of movement and space. If those speakers could be wallmounted it might be a way to overcome the objection that kept you from getting towers.
bencorn is offline
post #5 of 17 Old 11-07-2010, 08:02 AM - Thread Starter
Frohlich's Avatar
Liked: 1112
I have thought about moving the L and R speaker further out but the problem is that this is an addition on the back of the house and the floor is concrete for the first few feet and must have been a rear deck at some point. I currently run the wires underneath the addition and they pop out behind the TV via an existing heating vent opening. To run them further out would mean drilling holes in 3 inch thick cement...in other words, it is not going to happen
post #6 of 17 Old 11-07-2010, 08:32 AM
bencorn's Avatar
Yea I didn't think of the concrete walls. Only way to hide the speaker wire then would be to go up through the door frames or go under the carpet and that might be a bigger fight than it's worth.
bencorn is offline
post #7 of 17 Old 11-07-2010, 04:28 PM
519audiofan's Avatar
Quoted: 29 Post(s)
Liked: 36
That Sub 15 is a beast !!
519audiofan is offline
post #8 of 17 Old 11-11-2010, 03:56 PM - Thread Starter
Frohlich's Avatar
Liked: 1112
I know nobody cares but me but I received my 8 XLR cables today to cover all channels and hooked them up between my AV7005 and MM8003. Why...because I can
post #9 of 17 Old 11-12-2010, 06:18 AM
bezz's Avatar
If you ever feel motivated...
bezz is offline
post #10 of 17 Old 11-12-2010, 08:10 AM - Thread Starter
Frohlich's Avatar
Liked: 1112
To date, I have not had enough motivation to go there
post #11 of 17 Old 12-03-2010, 06:17 AM
BigMike66's Avatar
I know nobody cares...
man, that's not true!
What difference did you notice? If it was positive, what cable type did you use?
BTW, those 3 frames above your tv, are empty...?
Mike
BigMike66 is offline
post #12 of 17 Old 12-03-2010, 06:23 AM
BigMike66's Avatar
In a previous life I drilled quite a bit of concrete. Drilling the holes would be the easiest part. Feeding and protecting the cables would be the hardest.
IMO.
Mike
post #13 of 17 Old 12-03-2010, 08:10 AM - Thread Starter
Frohlich's Avatar
Liked: 1112
Mike
Didn't really notice any difference between XLR and RCA to be honest...and the connection is secure since it snaps into place...but they look "purdy" when you look at all the wires behind my equipment
Those 3 frames are decoration from my wife...when she reads your response she is going to be pissed and kick your a$$
post #14 of 17 Old 12-03-2010, 09:32 AM
BigMike66's Avatar
Now I see it, she was framing the wall.
Don't need to piss-off anyones's SO!
post #15 of 17 Old 12-11-2010, 11:10 AM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1444
Frohlich,
It is good to see I'm not the only one with Def Tech speakers on their ceiling. I have two white BP2x's on my ceiling as my room is open on one side. No the best location but it sounds fine.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #16 of 17 Old 12-11-2010, 02:10 PM
hugo_2_9's Avatar
nice setup
hugo_2_9 is offline
post #17 of 17 Old 12-11-2010, 03:31 PM - Thread Starter
Frohlich's Avatar
Liked: 1112
Originally Posted by Bill Mac View Post
Frohlich,
Bill
I have that design patented so you probably owe me a few bucks royalty It was the only solution I could come up with. I had the speakers before I had the room.
