My spare bedroom setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-23-2011, 07:41 PM - Thread Starter
rmclain73's Avatar
This is for anyone else out there that wants to do a small theater in a spare room, but not sure if you can pull off, you can.
My room is 12'x9'6", with the back part of the room 11" wide and 9' ceilings. The room offers excellent immersion, and being that it is so small it did not break the bank. I have excellent light control and airflow is not an issue. The projector is throwing from about 10', and seating is 8.5'. Screen size is a custom 82.5" and is the perfect distance for my wife and I. A lot of content we watch is 2.35:1 so that cuts the size down a little more, but we like to sit close in the theater so why not in our own home. The only downside to a smaller theater is it can only really hold 2-3 people.
Epson 8350 projector
Carada 82.5" custom cinema white screen
Pioneer 1020k receiver
Energy Take Classics 5.1
Panasonic DMP85k Blu Ray
Row of 2 Eros Home Theater seats
rmclain73 is offline
post #2 of 15 Old 08-23-2011, 08:52 PM
wizzack's Avatar
Quoted: 106 Post(s)
Liked: 251
This is so cool. What a great use of space! Thumbs up.
The above post is 100% medically accurate
31 Days of Horror: 2014 2013 2012 2011 2010 2009 2008
wizzack is offline
post #3 of 15 Old 08-23-2011, 09:31 PM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
+1
Having a small room myself, I can say I really like what you did with the limited space!
Also welcome to the WYSC family!
Bunga99 is offline
post #4 of 15 Old 08-24-2011, 06:54 PM - Thread Starter
rmclain73's Avatar
Thanks guys!! Only a week into having it setup and my wife and I really love it. I was a little worried about that screen size, but 83" is perfect for that room. The immersion is way more greater than I ever thought it would be. The only thing I have left to do is create masking for scope.
Bunga99, what does WYSC represent? Sorry if I should know it.
post #5 of 15 Old 08-24-2011, 07:58 PM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
WYSC = What's Your System Configuration
Bunga99 is offline
post #6 of 15 Old 08-24-2011, 09:01 PM - Thread Starter
rmclain73's Avatar
post #7 of 15 Old 08-24-2011, 09:01 PM
lildimsum7's Avatar
nice, this gives me some inspiration. those DIYers in the dedicated construction thread discouraged me a bit, but it looks like this small room setup works well for you!
lildimsum7 is offline
post #8 of 15 Old 08-24-2011, 10:51 PM
victor-eyd's Avatar
Great room! Excellent use of the horizontal shift on the epson but doe it affect the quality of the image?
Victor
btw more small theaters on my sig. Please add yourself to the collective when you find the time :-)
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #9 of 15 Old 08-25-2011, 04:12 AM - Thread Starter
rmclain73's Avatar
Victor
No, the image does not seem to be effected at all. My projector seems to be about .5-1 pixel off on the red, but that seems to be the standard on the 8350. Maybe that pixel is from the lens shift, but its not enough to effect or really notice when watching content. The only issue I did have was proper alignment of the projector as the wall the screen is on was not exactly level. When hanging the screen I had to hang it by what looked straight and comfortable to the eye, not the level. In doing this the projected image was skewed and irregular. To offset this I had to skew the projector in the opposite direction. Using the built in focus and alignment pattern in the projector made this is easy.
post #10 of 15 Old 08-25-2011, 04:05 PM
JulienLN's Avatar
Nice setup despite small room size. Definitely want to know what's the system config here.
JulienLN is offline
post #11 of 15 Old 08-25-2011, 04:33 PM
Latinoheat's Avatar
Quoted: 1155 Post(s)
Liked: 954
Excellent use of space. I like the 80's movie genre posters.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is online now
post #12 of 15 Old 08-26-2011, 06:04 AM - Thread Starter
rmclain73's Avatar
Comcast cable
The Energy Take Classics are the perfect system for that size room. The shag carpet, and four acoustic panels really help with treating the sound. I do also have a quad core mac G5 that I use for video editing (FCP) which runs through the projector as well. Makes for great client output monitoring. I can also use the mac for pre show trailers and what not, and have plans to use it for HD file playback. I really want to attack creating a masking system for the screen asap. I plan on going with the 1/2" insolation foam covered in blackout felt method. Using velcro I can just place it on top of the screen as needed, and adjust for all aspect ratios.
The AC vent in this room is directly above my equipment rack. Keeps everything nice and cool. However, if the bedroom door is closed after a couple of hours it can get a little warm in there. By just leaving the bedroom door cracked open a little it seems to vent the warm air out.
post #13 of 15 Old 09-02-2011, 07:58 PM - Thread Starter
rmclain73's Avatar
I have just completed creating scope masks for my screen and all I can say is WOW!! What a difference it makes. I went with the method mentioned in this thread:
http://www.avsforum.com/avs-vb/showt...0#post13396880
but instead of cutting the foam to just fit on the inside, I attached velcro to the velvet on the screen border. By doing it this way I can raise or lower the mask for 2.20, 2.35, 2.40 films. Cheap and effective way to mask a 1.85 screen to scope.
Without mask 1.85:1 screen
With mask on 2.35:1 screen
Screen shot masking 2.20:1 (adjusted mask to fit this ratio)
post #14 of 15 Old 11-13-2011, 12:43 AM
Amber Ale's Avatar
Very nice, great inspiration for those of us with small spaces!
Amber Ale is offline
post #15 of 15 Old 11-19-2011, 09:58 AM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
What is the exact size of your screen? Length and width.
Thank you.
Sonyad is online now
