NezFF's Media Room - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #301 of 329 Old 12-16-2013, 12:47 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
92 inch bedsheet temp setup. 16.5-17 feet away. Sorry for pic quality, took them real quick with iPhone 5.
nezff is online now
post #302 of 329 Old 12-16-2013, 05:52 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Ive been absent for a while Nez, sorry.
A couple opinions based on personal experience:
- Black out that window, Permanently. I actually used aluminum foil and HVAC tape(ghetto). Any light introduced in a projection setup is contamination IMO even in a dark room.
- An acoustically transparent screen with the dialogue coming from the center was the most drastic change i ever made. The db or two loss in the last upper octave is easily corrected with EQ and not audibe besides in my experience. AT material may run a bit more but IMO for the ultimate experience its the way to go.
- Also dont constrain yourself to commercially available AT screen materials especially if budget is a concern. Ive seen impressive testing results here on the forum from "DIY" materials like spandex which perform equally as well acoustically and very close visually to materials like Seymour XD etc.
- It wont matter much which direction you face the subs they radiate mostly omni. I actually prefer to face subs away from the listening position or fire them at acoustic absorption to absorb out of band harmonics and junk which is localizable if fired at the listener.
FWIW i used seymour xd material on a DIY frame and have been totally satisfied.
nezff likes this.
NicksHitachi is offline
post #303 of 329 Old 12-16-2013, 06:34 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
If I build a false wall, I plan on blacking out the window for sure.
An AT screen from Jamestown is on my list of wants. Can get more for the money, plus place my center behind it.
The subs facing into the corners about 6-12 inches are mainly just to get them out of the way. They only take up 22 inches compared to 34-36 facing towards the listener. Also on the flipside of that, is that they put out a lot of bass facing into the corners after some testing I did a year or so back.
My current thinking is:
build a false wall.
turn the subs into the corners giving me more room
move the front speakers out in front of the false wall closer to the side walls.
keep the tv stand removing doors etc.. and using black fabric frames that will also cover the rest of the false wall.
all my equipment can stay there and the remotes still work through the fabric
place the center on top of the tv stand bringing it UP and out of the stand giving me more dynamics. The screen will come down almost touching the tv stand and the center will hide behind the screen.
the fronts will be out next to the wall like in this pic
Subs facing in like in this picture
nezff is online now
post #304 of 329 Old 12-17-2013, 01:12 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
been working on other things around the house:
boring office space:
bottom cabinets
top cabinets
bottom cabinets dry fitted
painting
Crown and false panels to hide wires is all that's left.
top installed
bottoms installed
nezff is online now
post #305 of 329 Old 12-17-2013, 08:01 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
The issue with turning the subs and getting a screen bigger than 92 will be that I wont ever be able to turn them back the way they are now because the screen would cover the speakers. I have about 84 inches in between speakers for a screen. I plan on building a false wall and turning the subs like in this pic.
By turning the subs I can move the front speakers out more giving me room for a screen larger than 92 inches. More like 100-106 or so. I plan on trying to keep my components in the tv stand behind the false wall covered in fabric. I would move my center channel up on top of the tv stand either behind the screen or covered by a fabric panel. Im assuming it wont be covered up by the screen unless I hung it very low. I test fitted a 110 screen today and it didn't even hang down to the tv stand.
I would rather keep the center below the screen because the frame of the screen might block it. Unless I raise the center up enough to fire through the AT screen. The tv stand would hold all my componets (bluray, Marantz, xpa5, xbox one, ps4).
Still trying to understand how to build a false wall and fabric panels. Ive seen so many screen walls but not many like my room. Im thinking Im going to have to strip out the whole side walls, and ceiling with 1x4s for panels to attach to?
nezff is online now
post #306 of 329 Old 12-25-2013, 06:48 AM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
Merry Christmas brother
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #307 of 329 Old 02-04-2014, 02:25 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
I am absolutely thrilled I stumbled across this thread via your signature link!
AWESOME setup bro!
I just hit sub and looking forward to your PJ and screen!
You every think about doing a retractable screen and leaving speakers behind it?
great use of your space and the office with custom cabinets and counter top is very sweet.
keep up the good work!
Jester435 is offline
post #308 of 329 Old 02-04-2014, 02:57 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
AWESOME setup bro!
I have some house projects that need finishing before I tackle the pj and screen. I did purchase a used Seymour Xd 125 inch screen which I can cut down to fit my space.
nezff is online now
post #309 of 329 Old 02-10-2014, 03:49 PM
devotech's Avatar
Quoted: 26 Post(s)
Liked: 27
I've never commented on your thread before but I always find myself revisiting to be in awe of your setup.
devotech is offline
post #310 of 329 Old 02-10-2014, 04:21 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
thank you sir
nezff is online now
post #311 of 329 Old 02-11-2014, 12:39 PM
wt61443's Avatar
Hello Nezff. I like your thread and set up because it will be similar to mine in regards to room size and configuration. I hope to start building my house next month (dedicated HT room over garage). My room will be 27x18 with 9ft ceiling in the middle (sloped ceilings just like yours). I hope the knee wall will start about 4 or 5 ft (wish it were higher, but). I am researching quite a bit of topics on the forum, including room treatments. I saved the website where you purchased. I read where your room echoed quite a bit. I assume the treatments (including bass traps) helped out the sound overall? I have never experienced "before and after" with room treatments. I realize every room is different (material, size, a/v gear etc.). Thanks.
wt61443 is offline
post #312 of 329 Old 02-12-2014, 10:29 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Hey bud, thanks.
I basically started thinking about the panels because of the echo in the room. When I got them, I planned on putting them up a certain way, but then decided to put them up in a aesthetically appealing way. smile.gif They still did their job. I ordered bass traps for the front and rear corners because I was told that you can never have enough bass traps in a residential setting.
nezff is online now
post #313 of 329 Old 03-19-2014, 01:29 PM
orangepower's Avatar
Originally Posted by nezff View Post
Hey bud, thanks.
I'm glad bigmouthinDC linked this thread fir me. My room will be very similar only 16' x 11'. Did you get the projector and screen up yet?
orangepower is offline
post #314 of 329 Old 03-19-2014, 02:09 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Not yet. I purchased a Seymour AT screen from a member. It is 125 inches which would probably not fit. I am going to make a frame, then wrap and cut the excess off.
nezff is online now
post #315 of 329 Old 04-27-2014, 06:52 AM
femi's Avatar
Quoted: 67 Post(s)
Liked: 51
any new update?
femi is online now
post #316 of 329 Old 04-28-2014, 06:02 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Originally Posted by femi View Post
any new update?
Sorry guys. Between detailing vehicles and firefighting, it's been put on the back burner.
I actually thought it would be too much work and hassle at one point to try and fish all the cabling in the ceiling, cut a hole on the wall for the equipment, run new cabling, and build a false wall. I was going to sell the pj and screen but might hold off.
nezff is online now
post #317 of 329 Old 06-19-2014, 08:32 AM
Quoted: 182 Post(s)
Liked: 189
No more projector????
post #318 of 329 Old 06-19-2014, 08:36 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Don't have the time right now.
nezff is online now
post #319 of 329 Old 03-28-2015, 06:57 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Update: sold the PJ. Moved some stuff around but basically the same setup.
markrubin likes this.
nezff is online now
post #320 of 329 Old 12-13-2015, 07:57 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Sony 75" X850c.
nezff is online now
post #321 of 329 Old 01-20-2016, 11:55 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
nezff is online now
post #322 of 329 Old 03-25-2016, 09:42 PM
DragonSarc's Avatar
Hi Nezff, nice to see another A7-450 enthusiast I wonder how many of us have ordered this sub, how is the sub still performing at best? Nice setup I wish I have the same room space, mines about less than 1/3 of your space (bass head hehe), so why did you ditch the projection? is it because of the bulb life? I ditched mine because of the lamp bulb, I already replaced it 3x and never did get half of the life span that it was suppose to live, I think its the sub vibration makin the life super short, i was just lookin at the Sony 75 850c last week at bestbuy to replace my Pioneer, how do you like it?
DragonSarc is offline
post #323 of 329 Old 03-26-2016, 05:32 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Mainly ditched the projector because of the work involved in getting it actually installed. I should had ran hdmi, electrical etc...when building my home.
As far as right now, I love the Sony. I have actually only sat down and watched one movie. The picture is beautiful. Having a smart tv is something of a cool thing for me. I like the android os, considering I have a android phone.
My next step is to hang the tv up hovering over my tv stand. I'll be installing some 1x4s behind tv painted black. The center channel will be moving up to top of stand. Leaving room in bottom for blu ray player, ps4, Xbox one etc.
nezff is online now
post #324 of 329 Old 11-06-2016, 05:23 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
hung the Sony 75 inch set. Rewiring everything as we speak. Moved my center channel up onto the tv stand which IMHO will sound better. I have more room now where the center channel speaker was. This will house video game systems.
thxman likes this.
nezff is online now
post #325 of 329 Old 11-14-2016, 08:59 PM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
Added a XBOX One S to the mix. Going to run Audyssey hopefully soon.
nezff is online now
post #326 of 329 Old 01-10-2017, 08:54 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
hung the tv, painted the tv stand, ran audyssey. Everything sounds better.
ID:	1886505   Click image for larger version
ID:	1886593   Click image for larger version
ID:	1886601   Click image for larger version
ID:	1886609   Click image for larger version
nezff is online now
post #327 of 329 Old Yesterday, 11:30 AM
Terence's Avatar
Awesome thread from beginning to present! My HT is also a bonus room over the garage but man I wish I had your measurements, last fantastic job on your HT sir!
Tee
"Enjoy Movies & Music"
My Home Theater
Terence is offline
post #328 of 329 Old Today, 09:13 AM
Nosferatu's Avatar
Quoted: 146 Post(s)
Liked: 94
Spend a few dollars and go to JoAnn Fabrics and buy some black out material. Cut it out to match that window and then use 3M tape on the window. Put a nice curtain over it (or keep the blinds).
See what I've done...my full rig is in my signature but this is what I mean...
Thread to Build:Theater Build
Theater: Monitor Audio Platinum PL200/PL350C, Seaton Submerssive, 150" 3D Elite Screens +more
Living Room: Aperion Grand Verus, Outlaw LFM-1 EX, 70" Sharp Aquos +more
Stage 1 - Enthusiasm, Stage 2 - Realism
Stage 3 - Obsession, Stage 4 - Acceptance
...Which stage are you on?
Nosferatu is offline
post #329 of 329 Old Today, 10:29 AM - Thread Starter
nezff's Avatar
Quoted: 143 Post(s)
Liked: 65
yeah, I plan on doing something with that window sooner or later.
thanks.
nezff is online now
Ed C 12 , Elemental Designs , Elemental Designs A7s 450 , Emotiva , Emotiva Xpa 5 5 Channel Power Amplifier , Marantz Av8801 , Mitsubishi Wd 73738 73 Inch 3d Dlp Hdtv , Sony Bdp S580 Blu Ray Disc Player Black , sony xbr75x850c
