My 7.2 HT room, 5.1 HT room, & 6.1 ET room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 03-15-2012, 03:36 PM - Thread Starter
Rippyman's Avatar
Marantz SR7005
Klipsch RF 7 II's mains
Klipsch RC 64 II center
Klipsch RC 62 surrounds
Klipsch 5650 C rear surrounds
Klipsch SW 112 subs
Rippyman is offline
post #2 of 48 Old 03-15-2012, 03:41 PM - Thread Starter
Rippyman's Avatar
A Marantz receiver, LG Plasma, Shaw Gateway, Wii, Klipsch SW110 sub, & a Boston Acoustics HSI In-Wall/Ceiling 5.1 system.
, and my main floor/entertainment room with 6 In-Ceiling Boston Acoustics HSI 8" series, a Klipsch SW112 sub, run by HAI's HiFi II System. The pics only show 4, the other two are between the dining room & tech center.
Rippyman is offline
post #3 of 48 Old 03-15-2012, 03:46 PM
tmaschm's Avatar
First!!
Epic setups!!
tmaschm is offline
post #4 of 48 Old 03-15-2012, 03:48 PM
jproy13's Avatar
Liked: 26
that's it? only 3 setups? Seriously, very very nice. I bet you you haven't step inside a movie theater for a while now. Also, nice house.
cheers
jproy13 is offline
post #5 of 48 Old 03-15-2012, 03:51 PM
Miketr75's Avatar
Wow nice, very nice HTs, your house looks like a model house. How do you like your Marantz's receivers ? I never owned a Marantz receiver but used to have a AV8003.
Miketr75 is offline
post #6 of 48 Old 03-15-2012, 03:54 PM
joepannone's Avatar
Looks really nice. Really like the color scheme.
What's the brand of the entertainment stand in the second set-up?
joepannone is offline
post #7 of 48 Old 03-15-2012, 03:58 PM - Thread Starter
Rippyman's Avatar
They are great, the only complaint I have is the crappy remotes.
Rippyman is offline
post #8 of 48 Old 03-15-2012, 03:59 PM - Thread Starter
Rippyman's Avatar
The 5.1 room? Ikea LOL
Rippyman is offline
post #9 of 48 Old 03-15-2012, 04:00 PM
joepannone's Avatar
Could you happen to link me, I'd really appreciate it.
post #10 of 48 Old 03-15-2012, 04:04 PM - Thread Starter
Rippyman's Avatar
To the Ikea ET stand?
http://www.ikea.com/ca/en/catalog/products/80133930/
Rippyman is offline
post #11 of 48 Old 03-15-2012, 04:17 PM
cat-222ASR's Avatar
Wow like room in the basement nice and clean and simple. Like those Klipsch they look flashy. Do you like the bi-radial horns on them for clear focusing of directional sounds?
cat-222ASR is offline
post #12 of 48 Old 03-15-2012, 04:28 PM - Thread Starter
Rippyman's Avatar
I demoed a lot of different brands before going with Klipsch.
Paradigm, Focal, B&W, Polk, Boston the list goes on.
The Klipsch absolutely floored me with their effortless sound/clarity. For movies I will boldly say there isn't another brand on the market that can compare.
For music they are awesome, doesn't matter how much you turn that dial up they continue to produce flawless sound. I'm still in the build process for my 7.2 system, next is a London 12 kit by Primacoustics.
Rippyman is offline
post #13 of 48 Old 03-15-2012, 04:41 PM
cat-222ASR's Avatar
Well everything has limit don’t get too overconfident and blow them up. Do you use an SPL db metre? And remember the safety of your hearing you don’t want tinnitus it can result in many unpleasant days and nights and I suffer from it on and off most days that seem endless until it clears away.
You only need to pass a certain level on your hearing threshold level and wham bingo you’ll be member of American Tinnitus Association. I’ve got a little bit tonight and I’ve mostly been playing a film for short while today at under 80dbc.
Horns give a nice smoothness over the front but they tend to be a bit hissy when you notice it that is when nothing is playing. The range on my Control 12SR are somewhere around 109db and there is no way I’d have them anywhere over 90dbA it would bust the ears up.
post #14 of 48 Old 03-15-2012, 04:47 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
Awesome. Everything looks so clean and simple. That's how I like it.
I love that kitchen!
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #15 of 48 Old 03-15-2012, 04:47 PM - Thread Starter
Rippyman's Avatar
Well everything has limit don't get too overconfident and blow them up. Do you use an SPL db metre? And remember the safety of your hearing you don't want tinnitus it can result in many unpleasant days and nights and I suffer from it on and off most days that seem endless until it clears away.
You only need to pass a certain level on your hearing threshold level and wham bingo you'll be member of American Tinnitus Association. I've got a little bit tonight and I've mostly been playing a film for short while today at under 80dbc.
Horns give a nice smoothness over the front but they tend to be a bit hissy when you notice it that is when nothing is playing. The range on my Control 12SR are somewhere around 109db and there is no way I'd have them anywhere over 90dbA it would bust the ears up.
I have a cheap Db meter that has displayed 98db when I turn it up to -5 haha
My RF's are only efficient to 102db's
Rippyman is offline
post #16 of 48 Old 03-15-2012, 04:48 PM - Thread Starter
Rippyman's Avatar
Thanks! My wife designed the kitchen.
Rippyman is offline
post #17 of 48 Old 03-15-2012, 05:09 PM
cat-222ASR's Avatar
Your going to do your ears in its okay on lows but play 60Hz size wave its not nice listening to after 5mins. It reminds me traveling on the buses and the engine humming purring rumbling vibrating away does my ears in for 15min trip.
Well at least you have good efficient Klipsch they only need a small about power if your room is free from traffic sounds and neighbors you should be able to hear softer sounds at natural levels and louder ones at pleasant levels.
Last time I played a film silly loud was few years ago at near 126dbc never again I prefer 85dba to 105dbc or a few +db higher in dbc range but not constant.
Some films have nice mix on dialogue mix like The Bourne Ultimatum, I can feel the voices on most parts. Car chases and weaponry gun fire is almost near to turn it down a notch but its likable overall film mix. Cool part demo is where Borne goes running headfirst of balcony smashing in the glass door and its wooden frame WHAM! And the jolt makes me rock back with alarming WTF! That's gone hurt!
post #18 of 48 Old 03-15-2012, 08:32 PM - Thread Starter
Rippyman's Avatar
I love listening to movies at levels where its just you and the movie, so you feel it, haha.
Rippyman is offline
post #19 of 48 Old 03-15-2012, 08:59 PM
generalpride66's Avatar
ok, where did you get that couch from the first picture? i love it?
i love all of it!
generalpride66 is offline
post #20 of 48 Old 03-15-2012, 09:04 PM
cat-222ASR's Avatar
Well like too also but it can only go so far, it can’t do the real thing like explosions. A close fabricated approximation and that is about, but it gives the film a good creditable effect that gets a lot of people talking about.
What I else I like in movies is good use of Foley footsteps seem real like in STAR TREK II when, Kirk walks down a corridor and down a few steps has nice oomph on the footsteps. Door opens with Spock on opposite side. When Kirk leaves cool use of sound effects with Shhhh, shhhh to front left.
i love all of it!
From looking at, at the back its in sections otherwise you'd have to remove the door and most of brick work to get it in. ITS BIG!
Only thing I like about the kitchen and it is nicely designed for cleanness, its the fridge! Its got one of those ice things, my fridge has, sod all! I seen one of those around a friends and it was cool at making ice especially after jogging down the road.
post #21 of 48 Old 03-15-2012, 09:48 PM
Miketr75's Avatar
Thanks for your feedback. Very nice pictures as well, which camera did you use ?
Miketr75 is offline
post #22 of 48 Old 03-15-2012, 09:51 PM - Thread Starter
Rippyman's Avatar
i love all of it!
www.italsofa.com
Model Bridge.
It's three pieces, that fasten together. It's 12' wide, haha.
Rippyman is offline
post #23 of 48 Old 03-15-2012, 09:53 PM - Thread Starter
Rippyman's Avatar
It's a Canon 50D with a 2.8 17-55mm lens
Rippyman is offline
post #24 of 48 Old 03-15-2012, 10:34 PM
Bunga99's Avatar
Liked: 39
Very Nice and Very clean setups!
Also like your camera skills!
Bunga99 is online now
post #25 of 48 Old 03-15-2012, 11:04 PM - Thread Starter
Rippyman's Avatar
I have a website if you like photography.
www.bradstaylor.com
Rippyman is offline
post #26 of 48 Old 03-16-2012, 05:05 AM
Rodrigues_Brazil's Avatar
Quoted: 269 Post(s)
Liked: 18043
Very nice clean setups!
post #27 of 48 Old 03-16-2012, 12:19 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
Beautiful setup.
amarshonarbangla is offline
post #28 of 48 Old 03-18-2012, 11:29 AM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
Hey I like your website. The photos are very well done. I didn't know Calgary had that large a downtown. It's impressive.
As for your equipment, it's always nice to welcome another Klipsch owner to the boards. You have very good style and your photos are quite impressive. Thanks for showing us.
pcweber111 is offline
post #29 of 48 Old 03-18-2012, 03:01 PM
Spurrier Sucks's Avatar
Quoted: 642 Post(s)
Liked: 465
Very nice!
Spurrier Sucks is offline
post #30 of 48 Old 03-18-2012, 07:39 PM
Miketr75's Avatar
Thanks, I figured it has to be a SLR camera. Is it USM lens ?
Miketr75 is offline
Marantz Sr7005 Audio Video Receiver Black , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rc62 Black 2 Way Center Channel Speaker , Klipsch R 5650 W In Wall System Rc 62ii Center , Klipsch Sw 112 Reference Series Powered Subwoofer Black
