My setup...help !! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2014, 03:07 PM - Thread Starter
garbhead's Avatar
My setup...help !!
I have used AV front mount projectors for several (10+) years and still think its the best bang for your buck especially since bulbs are getting cheaper...now using a NEC 281-X that is absolutely stunning. Have Denon AVR-391 rec, Uverse box, Roku box and Sony NSZ-GT1 bluray/Google TV all running with HDMI. My newest mystery is I had to replace the 40ft HDMI cable running from Rec to Projector because I screwed up one end of the HDMI. anyway everything works as before except the Sony bluray box..it will not work as it did before but it will work when I change monitor from projector to a regular LCD tv, it will also work when bypassing the AV receiver and going directly to projector....What am I missing? about to pull my hair out(what's left of it) I have tried swapping inputs on the receiver and it won't work in any position, but the uverse and Roku will work in any position...H E L P
garbhead is offline
post #2 of 4 Old 08-22-2014, 07:23 PM
kevon27's Avatar
Quoted: 163 Post(s)
Liked: 189
You need Monster Cables..
kevon27 is offline
post #3 of 4 Old 08-23-2014, 07:51 PM
darthray's Avatar
Quoted: 1163 Post(s)
Liked: 1063
Forget Monster.
Other company offer just as good cable for less.
The OP should look at offering from company like
http://www.bluejeanscable.com/
or
and there is lots of other choice
He also sould not buy the cheapest one, a mid level or their high level.
For the distance he should contact their web site and ask for their recomandation.
Best regards
Ray
darthray is offline
post #4 of 4 Old 08-24-2014, 07:05 AM
darthray's Avatar
Liked: 1063
Check and double check all your setting!
Maybe the PS3 is no longer set on HDMI, or it could be from the receiver.
I own none of your equipment, so I am going from the basics.
Normaly a HDMI cable work or don't, but it could be one piece of equipment is more fanacky than the other but I could be way off on the left field on this one
If you replace the HDMI cable for such a distance.
I would look at the offering from the 2 links I posted before and contact there custumer service, but it could be as simple, as something change in your setting.
Good luck and let us know how it turned out.
Ray
darthray is offline
