Top 10 Things You Need to Know About Speaker Configuration and Placement - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #61 of 70 Old 11-30-2016, 05:24 PM
Pudzley's Avatar
Liked: 0
Very helpful, thanks!
Pudzley is offline
post #62 of 70 Old 06-21-2017, 01:56 PM
ToonMasterTim's Avatar
Quoted: 118 Post(s)
Liked: 81
I admit I am a bit of an audio noob. I have only recently gotten into surround sound, and at that I am only dealing with a Vizio 5.1 sound bar (yeah, I know, but the room, the wiring, the wife factor...gotta do whatcha gotta do). And I have struggled with my rear speakers because they are often barely audible. If I feed PCM, they are louder, fuller, noticeable. But, if I bitstream, I need to crank the surround volume (rear speaker volume) up to max to get a reasonable volume out of them.
As for placement, I had them behind the couch and slightly out to the side, but facing towards the middle of the couch. But just recently, I put them off to the side of the couch by a couple of feet, sitting slightly behind the ear/head position and angled at head position, not pointed at the center of the couch. It has made a big difference. I don't know if it's correct, and I will probably move them again, but they sound good so far.
ToonMasterTim is offline
post #63 of 70 Old 07-10-2017, 05:07 AM
Liked: 0
Very interesting and educative. Thank you for this.
Inos is offline
post #64 of 70 Old 07-12-2017, 12:35 PM
mithrilG60's Avatar
Quoted: 52 Post(s)
Liked: 56
Something tells me the second half of the work day is going to drag very sloooooooowly today
Samsung PN64F8500
Marantz SR5010
Def Tech BP9040, CS9060, SR9040
AppleTV 4th gen, Popcorn Hour A-200, Plex
2x Debian NAS/Media Servers - 32.6TB (formatted) & growing
mithrilG60 is offline
post #65 of 70 Old 07-25-2017, 12:46 AM
Liked: 0
Thank you very much
dinofreedo is offline
post #66 of 70 Old 08-07-2017, 09:19 AM
Liked: 0
Upgrading from 5.1
I have a Martin Logan 5.1 speaker configuration. Theater is 24 x 13. Summit's front ESL rear and two Definitive Technology 15s subwoofers placed on the sides. I am considering an upgrade but am confused by 7.1, Dolby Atmos and DTS surround configurations. Welcome the opinion and suggestions of others as to what would be the next best step.
pnb2506 is offline
post #67 of 70 Old 08-07-2017, 09:36 AM
Newbie789's Avatar
Quoted: 238 Post(s)
Liked: 72
I went from 5.1 to 5.1.4 atmos and it was a huge upgrade. If you have the room why not 7.24?
Newbie789 is offline
post #68 of 70 Old 08-08-2017, 07:21 AM
Liked: 0
Thank you your sharing.
johnsherdy10 is offline
post #69 of 70 Old 08-08-2017, 06:14 PM
Liked: 0
Thanks for the reply. Can you please share further details or a link where I could learn more about the speaker placement.
pnb2506 is offline
post #70 of 70 Old 08-08-2017, 09:31 PM
Newbie789's Avatar
Quoted: 238 Post(s)
Liked: 72
https://www.dolby.com/us/en/technolo...guidelines.pdf
Around page 19 is where the guide shows you how to place the speakers. If you're wanting to learn, read the whole thing. It's very detailed.
Also, an easy rule of thumb for 45 degree angles is that the two legs are the same length, so if your ceiling is 7ft from your head, then the speaker will need to be 7ft away to achieve a 45 degree angle.
There are great iphone apps of you don't remember geometry and want help on the angles / distance.
I have my 4 channel atmos speakers basically 1ft behind me and about 20 degrees in front of me and it still sounds great.
Make sure to get a speaker with a wide dispersion...I chose the B&W CM683 but that might have been overkill. I ran the ceiling speakers as my mains to test them and I was impressed with no back boxes, but I get lots of sound upstairs.
Reply AVS Forum® Articles
frontpage , speakers , Surround Sound , surround sound and speaker placement
