Blackout sound proof curtains - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 04-29-2008, 07:45 AM - Thread Starter
fernalfer's Avatar
Quoted: 12 Post(s)
Does anyone know where i can find blackout sound proof curtains? my room has a rear, side and front wall, but the right side is open to where the kids play area is.
I wanted to run a curtain from the front wall to the back wall on the right side to close the room off. but also wanted it to be blackout and as sound proof as can be.
Does anyone know where i can get such an item?
fernalfer is offline
post #2 of 31 Old 04-29-2008, 08:17 AM
Quoted: 3078 Post(s)
Liked: 2582
If you want something that will actually make a dent on the sound you will probably need some curtains intended for industrial use.
http://www.goffscurtainwalls.com/noi...fdom=ppcgoogle
post #3 of 31 Old 05-20-2008, 12:02 PM
arango1's Avatar
Just purchased Eclipse Curtains at Walmart at 10.83 per panel. They Are complete blackout curtains.
arango1 is offline
post #4 of 31 Old 05-20-2008, 03:21 PM
McCall's Avatar
Perhaps but you can be darn sure they are NOT sound proof.
Try industrial which are still not soundproof but better than nothing.
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
post #5 of 31 Old 05-21-2008, 06:42 AM
arango1's Avatar
True,
Next stop, Lowes for some pre-mixed mortar
arango1 is offline
post #6 of 31 Old 05-21-2008, 11:23 AM
Weasel9992's Avatar
True...sound attenuating, yes...sound proof, absolutely not. They'll do a credible job in the vocal band if they're heavy enough. I've seen 18-22oz 50% fullness velour used in some kinds of installs to cut down on vocal chatter in crowded spaces.
Frank
Frank Oesterheld
Weasel9992 is offline
post #7 of 31 Old 10-31-2008, 06:32 AM
JBLsound4645's Avatar
Get some MDF and timber along with lots and lots of screws and place the MDF made up in several layers and stuff the hole up that is called the window you don’t need the window you’ve got plenty of windows in the home!
Now you have effectively reduced cut down on the traffic airplane and other noise from the window and it’s a damn sight more cost effective over curtains because some fabric is damn costly!!!
JBLsound4645 is offline
post #8 of 31 Old 10-31-2008, 06:57 AM
suffolk112000's Avatar
Well, if your intentions are to simply divide the room visually, then curtains will work.
But if you are looking for sound control, there is no replacement for a wall and enclosed room.
Depending on your expectations, when it is all said and done, I am betting that you will be disappointed with the end results of your efforts and money spent.
It has been said many times on this site that when it comes to sound containment, your space is much like a fish aquarium. If there is one leak, sound, like water, will find that leak and enter un-wanted area's. I don't know exactly what curtain set-ups you are currently looking at, but I can't imagine there is a curtain out there that is going to contain sound like you are probably expecting.
Domino's donÂt fall all at once, they fall one at a time...
suffolk112000 is offline
post #9 of 31 Old 11-01-2008, 07:08 AM
If light can get though the gap therefore sound can also pass though it!
post #10 of 31 Old 10-03-2011, 04:57 AM
Liked: 2582
Originally Posted by Pramada View Post
Soundproof curtains are made especially for absorbing sounds and have been tested in laboratories with great success of reducing sounds close to 20 decibels.
They rarely report the results at the lower frequencies which are a real problem in Home theaters. Anyone planning on using curtains as a sound proofing measure needs to be realistic in their expectations.
Note: Pramada's post was deleted by the mods because he had a marketing link in his signature.
post #11 of 31 Old 02-06-2012, 02:11 AM
BarbaraDortch's Avatar
I have been looking for blackout/soundproof curtains myself because I don't sleep that well with the street noise in the morning.
I did quite a bit of research and I found some Amazon links to blackout curtains here soundproofcurtains.net/soundproofing_curtains_noise_proof_curtains_media_room_curta ins.html Now as far as soundproof, I read the customer reviews on Amazon that these readily available blackout curtains only absorb about 40% of the sound.
As some other commentators point out, the higher frequencies are better absorbed than the lower frequencies.
If kids noises are the problem, maybe their frequencies are not that low after all?
There is some other advice about the size of the curtains on the page I referred you to also. Hope that helps.
BarbaraDortch is offline
post #12 of 31 Old 01-15-2014, 06:40 PM
taxman48's Avatar
Quoted: 290 Post(s)
Liked: 292
I just finished buying the last of my Eclipse blackout panels. I didn't need them to be soundproof, just make the viewing area nice and dark. When not in use, the mrs. bought nice black tie backs. you can purchase them on Amazon or Target or Walmart..Hope this helps..
taxman48 is offline
post #13 of 31 Old 01-16-2014, 03:44 PM
stevedawg85's Avatar
Quoted: 21 Post(s)
I have an open doorway/entryway to my theatre and looking to cover it. I'm more interested in blacking out the room then soundproofing, but soundproof would be a nice bonus.
Taxman, are those the same from WM? would they block most sunlight getting in?
Parallux, nice website, I may look into it and possibly combine it w/ the curtains/drapes. Do ou have experience w/ it and does it seem like it would work w/ a doorway?
stevedawg85 is offline
post #14 of 31 Old 07-18-2014, 08:07 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
There is no such thing as a soundproof curtain. There are some that provide some degree of sound attenuation, maybe 10 dB or so. The ones I use are marketed as Eclipse, and I bought them primarily for light blocking. That they do well. Sound, just a bit.
jayn_j is offline
post #15 of 31 Old 07-29-2014, 11:53 AM
amallano's Avatar
"Double Sided" Blackout curtains
I am looking for double sided blackout curtains. I have about a 6ft wide entry way to my theater and want a velvet curtain, but it needs to look nice on both sides. Most lined/blackout curtains I can find have a white liner on the one side. Only place I found where you can configure the curtain for double sided is by Saaria. I am a bit uneasy as their website and sister site have various grammar and spelling issues (they are in India & US). Anyone have any other suggestions? And no, I am not putting up a wall ;o)
amallano is offline
post #16 of 31 Old 07-30-2014, 01:22 PM
LeChuck's Avatar
I'm in the same situation and will need a double sided blackout (nice and heavy, and decent looking) curtain (if there is a measure of sound attenuation, even better) for the entrance to my room. I have a 6 ft by 4 ft corner that is all open to the hallway and the way up the stairs, and needs to be closed off, and I cannot build a wall there as it would leave a much too narrow hallway.
I'm now thinking that perhaps a double curtain could work, back to back. But it's a bit tricky because it's a corner, and that leaves a lot more rods to install, and not enough space for that.
How about dual curtains on same rod....(I plan to make custom rods using copper pipes).
LeChuck is offline
post #17 of 31 Old 07-30-2014, 04:30 PM
LeChuck's Avatar
I found these curtains, which are not velvet, but they apparently use a different weave which means they do not have to use an extra lining, and are the same on both sides:
http://www.amazon.com/dp/B001A63XTS/...MW5UF7KJ&psc=1
The price seems good since they are sold in sets of 2 panels for 104 inches total width.
I ordered the burgandy color for myself. Since they are not going to go directly in front of a window, the amount of light blocking should be just fine.
LeChuck is offline
post #18 of 31 Old 11-06-2014, 07:52 AM
Liked: 0
Hi How the curtains work?? I was thinking to buy them to block a bit the noise from the street and also for the black out. Is it worthy??
Many thanks
Best Regards
diego nombela is offline
post #19 of 31 Old 11-06-2014, 10:00 AM
LeChuck's Avatar
They work great for me but my needs are not the same. I am using them to close off the room, not in front of a window with direct light. I imagine they would work pretty well, but if you are not going to see both sides of the curtains then maybe a regular one with a blackout liner might work better.
In my case they help muffle the sound coming from inside the room, as opposed to having nothing there, but I couldn't say if it would add any sound insulation at all in front of a window.
Sorry to not be very helpful.
LeChuck is offline
post #20 of 31 Old 12-30-2014, 07:23 PM
a4pat's Avatar
can they be used in a ceiling mounted track application? i would like to separate the stairwell off with one set and put another on the opposite side of the room for aesthetics to match
and what would be a good ceiling mount track? hmmm...maybe some 8ft metal conduit and elbows bolted to ceiling and shower curtain sliders....
Patrick
a4pat is offline
post #21 of 31 Old 12-31-2014, 01:58 PM
HTmarket's Avatar
Quoted: 179 Post(s)
Liked: 40
curtain rods
you might be able to pull that off but you could also look at btx which is a motorized big bucks or kirsch rods. we have on our site but they sold other places to
regards
Alan
HTmarket.com
HTmarket is offline
post #22 of 31 Old 12-31-2014, 03:10 PM
Super Moderator
teachsac's Avatar
Quoted: 595 Post(s)
Liked: 810
Anyone try acousticurtain?
http://residential-acoustics.com/sho...cousticurtain/
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Samsung UBD-K8500, Panasonic DMP-UB900 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #23 of 31 Old 12-31-2014, 10:35 PM
a4pat's Avatar
regards
Alan
HTmarket.com
are the kirsch rods available in black? i looked over your site...you can pm me a link if you cant post one.
Patrick
a4pat is offline
post #24 of 31 Old 01-01-2015, 08:04 AM
HTmarket's Avatar
Quoted: 179 Post(s)
Liked: 40
black rods
probably but our site only shows white, I have to check with our vendor Monday as I am out rest of week.
Regards
Alan Hutchinson
HTmarket.com
HTmarket is offline
post #25 of 31 Old 01-03-2015, 09:28 PM
a4pat's Avatar
Regards
Alan Hutchinson
HTmarket.com
thanks Alan.
i saw a track at JC Penney made by bali. $45 and didnt seem to bad in a satin nickel finish.
amazon sells the kirsch/levolor track in black and white.
Patrick
a4pat is offline
post #26 of 31 Old 01-05-2015, 01:41 PM
HTmarket's Avatar
Quoted: 179 Post(s)
Liked: 40
we can get the black kirsch rods that amazon sells. pm me if interested.
alan
HTmarket is offline
post #27 of 31 Old 01-05-2015, 07:39 PM
a4pat's Avatar
alan
email on the way. thank you.
Patrick
a4pat is offline
post #28 of 31 Old 01-25-2015, 04:25 PM
Tornado Red's Avatar
Quoted: 252 Post(s)
Liked: 194
Floating through some of these threads, I have a similar dilemma with a 7' wide opening into my 12'x19' HT room. I am more interested in capturing the sound escaping than the light coming in. Don't want anything permanent, nor do I want a curtain with any type of rod/rail arrangement. I've been thinking more of a room divider, foldable, portable (total opening to seal off 7'x7') in perhaps 3 padded panels on wheels. When not doing any serious movie watching or music listening it can wheel away to a side room I'm not using. I've seen a few companies that can provide something similar, but prices are prohibitive. I'm thinking I could build something in the $150 range, just looking to see what other folks have done. This thread has convinced me to pretty much rule out using curtains for sound blockage. I wish the OP luck in his search...
Tornado Red is offline
post #29 of 31 Old 02-08-2015, 08:33 PM
a4pat's Avatar
I am getting close to being finished with basement. I bought the curtains from amazon.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
very happy with them so much so I bought more longer sets to complete the theatre look. the shorter set covers the stairway opening and completely blocks the light from the led strip which follows the handrail and the av shelves under the stairs . now you can see to get up the stairs when watching a movie. the wall is the screen sprayed with SF.
i ended up using 3/4 in metal conduit for my curtain rod. sprayed matte black. cut to size. wall mounted the one on left with conduit straps and 1x2 wood block spacers painted same as wall. the one on right was cut to size to fit between wall and column and hung on a standard closet rod flange which i also sprayed matte black.
ended up costing about $15 for both DIY curtain rods and hardware.
Patrick
a4pat is offline
post #30 of 31 Old 12-10-2016, 12:21 PM
Liked: 0
I have searched for long for Sound Proofing products.
Ego16 is online now
Reply Theater Room Items & Accessories
