Kudos to Frame USA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 01-16-2009, 12:58 PM - Thread Starter
limulus's Avatar
Today, I received 13 frames from Frame USA and I'm absolutely satisfied. I've been sitting on a collection of movie posters for years. The hallway in our basement leading to the HT will now be complete. FYI I purchased the Corporate Wide series. I'll try to post some pics after I get them hung.
Formerly known as J--- H----. Member since 11/2002. My real name was showing up in Google too much!
What we have heah...is a failyah to communicate.
limulus is offline
post #2 of 40 Old 01-16-2009, 01:47 PM
jamis's Avatar
I have the same frames and am also very satisfied.
A few of mine came with damaged plexi, but they were very easy to deal with and sent out replacements very quickly.
I'd definitely buy from them again. The one downside is the 7-10 day lead time. You can order stock frames from one of their sister sites, but they are a bit more expensive per frame.
jamis is offline
post #3 of 40 Old 01-16-2009, 01:49 PM
skid_68's Avatar
Is that offer on measuring the frame size still good? I would greatly appreciate it, thanks limulus.
skid_68 is offline
post #4 of 40 Old 01-16-2009, 02:08 PM - Thread Starter
limulus's Avatar
I knew there was something I was supposed to do! Here ya go:
42.5" x 30.5". The frame width is 2" Also, the description refers to them as Eco friendly wood composite. They appear to be MDF.
limulus is offline
post #5 of 40 Old 01-16-2009, 02:10 PM - Thread Starter
limulus's Avatar
It was actually your HT thread that led me to these. Also, my order was placed on Dec 29 and I just got them today. Their order confirmation said Jan 16 and they were right on the money.
Edit:
One other thing: My frames were wrapped in about 100ft of bubble wrap, I'm serious. Also, they had protective plastic film over both sides of the plexi.
limulus is offline
post #6 of 40 Old 01-16-2009, 05:52 PM
skid_68's Avatar
Awesome, thanks limulus.
skid_68 is offline
post #7 of 40 Old 01-16-2009, 09:17 PM - Thread Starter
limulus's Avatar
...and a photo:
limulus is offline
post #8 of 40 Old 01-27-2009, 04:10 PM
Tim_in_NC's Avatar
How well are these frames put together at the joints? Fit and Finish ... They look nice in the photos.
I have about 15 or so autographed 8x10's that I'd like to mat and frame with the Corporate Series 11x14 frames ...
Tim_in_NC is offline
post #9 of 40 Old 01-27-2009, 05:07 PM - Thread Starter
limulus's Avatar
They were very nice. The mitered corners were very tight. There is a sawtooth hanger that you have to install on the back. Be careful when you hammer those on and make sure there is something solid under the frame but also a layer of some fabric so you don't scratch the frame. If you nail them on while the frame is on carpet, you can cause the frame to twist and that will pull the joints apart.
limulus is offline
post #10 of 40 Old 01-28-2009, 01:47 PM
Tim_in_NC's Avatar
Thanks Limulus ... I'll more than likely put an order in with them ...
post #11 of 40 Old 01-28-2009, 02:27 PM - Thread Starter
limulus's Avatar
A few more pics of the smaller frames I bought:
limulus is offline
post #12 of 40 Old 01-31-2009, 06:34 AM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
I use them as well. Good stuff and reasonably priced.
Bud
chinadog is offline
post #13 of 40 Old 02-03-2009, 09:13 AM
Tim_in_NC's Avatar
Thanks for these pics ...
The smaller frames really look good for the $ ... Are they the Corporate Wide Series as well? They look to be so ...
thanks,
TIM
post #14 of 40 Old 02-03-2009, 10:09 AM
Tim_in_NC's Avatar
thanks,
TIM
Also, how do the backs attached on the smaller frames? I want to have enough room for my custom double matting, a 8x10 photo, and then some sort of card stock between the 8x10 and the backing plate ...
Is there any way you could snap a picture of the back of these smaller frames?
TIM
post #15 of 40 Old 02-03-2009, 10:20 AM - Thread Starter
limulus's Avatar
They are all Corp Wide. The smallest are 11x17. The 50' Woman is another size I can't recall and the four large posters are standard movie posters.
Little metal tabs bend to hold the back on. They come with little sawtooth hangers that you have to install or you can install eye screws and picture wire but that isn't supplied.
limulus is offline
post #16 of 40 Old 02-03-2009, 11:05 AM
Tim_in_NC's Avatar
thanks,
TIM
Thanks ... Do you think there is enough room for my double matting?
post #17 of 40 Old 03-02-2009, 04:24 PM
JBUNGIE's Avatar
Love the retro movie poster look..nice job! Do have a link for where the posters were purchased?
JBUNGIE is offline
post #18 of 40 Old 03-02-2009, 04:56 PM - Thread Starter
limulus's Avatar
I got my retro posters at allposters.com Also movieposter.com has them.
limulus is offline
post #19 of 40 Old 03-02-2009, 06:39 PM
mspguy's Avatar
i went to Frame USA and didn't see that size listed as an option. So I entered the measurements for a custom frame and it responded by saying that the max length is 36". How did you find this size?
Good find, thanks for the lead!
mspguy is offline
post #20 of 40 Old 03-02-2009, 07:53 PM - Thread Starter
limulus's Avatar
The measurements I provided earlier were the actual exterior measurements of the frame. The size you order is the actual poster size which I've pasted below with the part number:
10627
Corporate Wide
Color : Black Satin
limulus is offline
post #21 of 40 Old 03-02-2009, 09:43 PM
mspguy's Avatar
Thanks! I'm searching for posters online, any suggestions on good places to find inexpensive ($8-$15) posters? For instance, I'm looking for a nice Dark Night poster but when I finally find one for the 27x40 measurements the price jumps considerably. While other titles can be had for as low as $8 on some sites.
I like this one:
http://www.movieposter.com/poster/MP...rk_Knight.html
But am not about to pay $175 for a poster.
mspguy is offline
post #22 of 40 Old 03-03-2009, 06:09 AM
JBUNGIE's Avatar
I like this one:
27*39 for 9 bucks..
http://cgi.ebay.com/THE-DARK-KNIGHT-...QQcmdZViewItem
JBUNGIE is offline
post #23 of 40 Old 03-03-2009, 08:25 AM
Schloob1's Avatar
limilus, the frames look great and just checking when I go on the framesusa website the price for the corporate wide said something like $12 for the 11x17which is a decent price and when I go to the order the price went down like in half Wow to say the least, so is there additional items for the frame you needed to purchase or does that price include basically everything needed except for matting it appears for that size? Let me know because I have about 15 of those 11x17 masterprints I have been sitting on but could not afford to get frames due to the frame I liked jumping from about $9 to almost double that. Let me know, thanks.
Schloob1 is offline
post #24 of 40 Old 03-03-2009, 08:38 AM
jpniner's Avatar
original print posters of some movies are valuable, thats why that Dark Knight cost that much. Reprints are not.
I got a Double sided Dark Knight off ebay for $30 bucks awhile back, on hopes it goes up in value.
Bad pic with flash but its this one:
I got this cool 300 poster from Allposters.com and had to get it foam mounted:
(again bad flash)
jpniner is offline
post #25 of 40 Old 03-03-2009, 08:42 AM
jpniner's Avatar
My favorite is my Godfather posters next to the screen I built.
Sorry, got bad glare in all these pics, looks better in person.
I need to paint walls a darker color but don't feel like it yet.
jpniner is offline
post #26 of 40 Old 03-03-2009, 08:58 AM - Thread Starter
limulus's Avatar
When I bought my small frames, they were also discounted. Keep in mind they have a thin plexi or acrylic and not glass. But that doesn't bother me at all. They really do look great and I've had lots of compliments from everyone who has seen them. Each frame will come with a sawtooth mount. I believe I posted about that in this thread. Just be careful with you nail that on. Here is my order:
Product Qty Price Options
10529
Corporate Wide
Color : Black Satin
8 $6.05
10613
Corporate Wide
Color : Black Satin
1 $25.10
10627
Corporate Wide
Color : Black Satin
4 $29.75
Order Total
Merchandise Total: $192.50
Shipping: $40.90
Shipments Total: $233.40
Grand Total: $233.40
limulus is offline
post #27 of 40 Old 03-03-2009, 09:48 AM - Thread Starter
limulus's Avatar
Hey Guys,
I received an email coupon from allposters.com It's worth 20% off everything on the site with no minimum. I don't know if it can be used once or by multiple people but here it is:
USE CODE: WMN2
limulus is offline
post #28 of 40 Old 03-04-2009, 08:05 AM
Schloob1's Avatar
Thx for the offer on the coupon, either someone already used it and did not mention it but did not work for me but no worries. I saved plenty in just the fact that I found your thread and my 11x17's are going to look nice in these frames. Now because of the great deal though I just need to eventually get 4 more posters as I bought 4 extra to avoid the $15 charge. Might as well buy the extra ones since the extra charge alone was basically getting 2.5 of the frames. Easy decision there for sure
Schloob1 is offline
post #29 of 40 Old 06-02-2010, 10:12 PM
kcrossley2's Avatar
Does anyone have any coupon codes for Frame USA?
kcrossley2 is offline
post #30 of 40 Old 06-07-2010, 09:37 PM - Thread Starter
limulus's Avatar
Wow, I haven't posted or logged in in several months. A couple of days ago, I logged in just to look around and now all my old subscriptions are hitting me with new posts.
From time to time I get sale emails from Frame USA. I got something not so long ago, but it has been deleted. Next time I will post it.
limulus is offline
Reply Theater Room Items & Accessories
