Berkline Leather Squeak - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-13-2010, 07:03 PM - Thread Starter
dlp3719's Avatar
Just got my brand new Berklines and the leather squeaks and rubs as they recline. It's a bit distracting. Anyone else experienced this? I'm thinking just a bit of leather conditioner would fix it?
dlp3719 is offline
post #2 of 11 Old 03-13-2010, 07:25 PM
KenLerch's Avatar
The squeak will decrease over time, but in the mean time try putting a little bit of baby powder between the seat and the arm. You will not need much and it will make it go way.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #3 of 11 Old 03-13-2010, 07:43 PM
Quoted: 3266 Post(s)
Liked: 2751
+1, put a little in the palm of your hand then reach down between the seat cushion and the arm and rub it around. I have 4 year old chairs and every once and awhile one starts squeaking. I have the baby powder on the shelf next to the case of microwave popcorn.
post #4 of 11 Old 03-13-2010, 11:09 PM
Fabricator's Avatar
Quoted: 31 Post(s)
i tried baby powder. put a bunch on, didn't work well at all. and made a mess.
you need ArmorAll/etc. just put it on a rag, rub the rag into the seat joints.
the noises will be completely gone for a long time.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #5 of 11 Old 03-13-2010, 11:10 PM
Fabricator's Avatar
Quoted: 31 Post(s)
oh. the seat will operate smoother.
post #6 of 11 Old 03-14-2010, 04:25 PM
Liked: 2751
Dry Lube versus Wet Lube. Maybe this could be the next semi-annual argument I'm tired of all the ones we re-visit:
Do I need a permit?
Are Powered seats worth it?
Must I put sand in my stage?
Does my ceiling have to be painted black?
White or Gray screen?
DLP or ______?
post #7 of 11 Old 03-14-2010, 07:50 PM - Thread Starter
dlp3719's Avatar
Thanks guys. Problem solved with ArmorAll because I had that on hand and didnt have any baby powder. Squeak-free for now.
dlp3719 is offline
post #8 of 11 Old 03-14-2010, 09:14 PM
Fabricator's Avatar
Quoted: 31 Post(s)
good deal
i did mine a good while ago. still dead quiet.
post #9 of 11 Old 03-21-2010, 07:49 PM
Drew_V's Avatar
Anyone use leather conditioner or mink oil on their chairs? I wonder if that would be better than baby powder.
--Drew
My basement theater build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1243820
Started: 2/20/10
Completed: 10/10/10
Drew_V is offline
post #10 of 11 Old 03-23-2010, 11:18 AM
mccabekyle's Avatar
I find that a good leather conditioner works perfectly. Conditioning your leather is something that you should consider doing at least once a year, depending on the humidity where you live. Best of luck to you!
Kyle McCabe
Carolina Interiors Home Decor
Theater Seating Specialist
mccabekyle is offline
post #11 of 11 Old 03-27-2010, 03:04 PM
Drew_V's Avatar
Thanks for the response. Although my chairs probably won't get daily use, it would be nice to keep them maintained like new if possible.
--Drew
Started: 2/20/10
Completed: 10/10/10
Drew_V is offline
Reply Theater Room Items & Accessories
