Help with making room darker. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-15-2010, 03:20 PM - Thread Starter
Izkimar's Avatar
What blinds or shades would be the best to buy for a HT room to make it dark during the day?
Izkimar is offline
post #2 of 9 Old 09-15-2010, 07:02 PM
pcdoctor's Avatar
I use blinds from Home Depot and black out fabric behind curtains from Target.
pcdoctor is offline
post #3 of 9 Old 09-16-2010, 01:33 PM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Might want to consider a Roman Shade with strips of magnetic rubber along the edges. They mate with magnetic rubber on the window frame and give a tight seal. Most Roman shades have insulating material inside that provide a good light block.
Most conventional solutions need to have some tolerance for movement and thus have some significant light leakage around the edges.
jayn_j is offline
post #4 of 9 Old 09-16-2010, 02:48 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Room Darkening roller shades inside the window frame with blackout curtains..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #5 of 9 Old 09-19-2010, 08:33 PM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
What color paint are folks using on the walls (besides BLACK)? Thanks. SJ
SJHT is offline
post #6 of 9 Old 09-20-2010, 05:06 AM
pcdoctor's Avatar
Use a dark color that accents your seats and other furniture.
Navy Blue, Brown, etc if you can't use black.
pcdoctor is offline
post #7 of 9 Old 09-22-2010, 07:20 AM
newtheaterguy's Avatar
Very dark red (maroon) on the walls with brown trim and ceiling
newtheaterguy is offline
post #8 of 9 Old 09-23-2010, 10:03 PM - Thread Starter
Izkimar's Avatar
Thanks guys all good tips
Izkimar is offline
post #9 of 9 Old 09-24-2010, 04:19 AM
Colton's Avatar
Deep burgundy on walls with a black carpet wainscoting half-way up the wall to help absorb sound. Burgundy carpet.
Colton is offline
Reply Theater Room Items & Accessories
