Help blacking out a room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-30-2011, 01:23 PM - Thread Starter
David H.'s Avatar
I need to blackout the room my projector is in and I'd like to know the best way to do it for a low price. There is one window, and one door with glass panels in it.
Are blackout shades typically better than curtains? I found this thread and some people were saying they use both together: http://www.avsforum.com/avs-vb/showthread.php?t=1205141
One poster said, "I use foam rubber covered in black felt behind my black out shades. The foam rubber is cut to 1 inch extra around all sides and comforms and covers the entire window with a snug fit. Complete coverage for zero light leakage."
That sounds like a pretty good idea.
Here's another thread http://www.avsforum.com/avs-vb/showthread.php?t=853881
I think what I'll have to do is get a shade for the window and a curtain for the door.
Maybe Walmart for the curtain http://www.walmart.com/ip/Eclipse-Sa...Panel/15734048 and this shade from JC Penney seems pretty cheap: http://www.jcpenney.com/jcp/X6.aspx?...ItemId=13cab4b
If you have better suggestions let me know, thanks!
David H. is offline
post #2 of 10 Old 03-30-2011, 07:00 PM
Fabricator's Avatar
Quoted: 26 Post(s)
i use card board for my windows. kills 99.9% of the light.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is online now
post #3 of 10 Old 03-30-2011, 07:10 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Why is this so hard? Isn't at least 50% of the solution is based on your personal aesthetic/preference?
MrBobb is offline
post #4 of 10 Old 10-04-2013, 10:43 AM
taxman48's Avatar
Quoted: 301 Post(s)
Liked: 297
I have 1 window which I covered with black plastic.. Between the bar area and the viewing area I am hanging blackout curtains bought from Amazon.
http://www.amazon.com/Eclipse-Thermaback-42-Inch-84-Inch-Blackout/dp/B002L6I2EC/ref=sr_1_2?s=home-garden&ie=UTF8&qid=1380904855&sr=1-2&keywords=Eclipse+Suede+Thermaback+Blackout+Panel
I will shorten them about 10"..I have to order a few more panels and hang some rods. distance between posts is 90".. Hope this helps
taxman48 is offline
post #5 of 10 Old 10-04-2013, 12:14 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Once you figure out what you want on your windows you should seriously think about ceiling and wall color within 5' of the screen if they are anything but a dark flat color now.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #6 of 10 Old 10-11-2013, 08:26 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
I used a roll down style blackout shade from Depot that was $60. I wouldn't describe the effect as blackout but more like room darkening. On it's own it is not enough.
The $10/panel walmart blackout curtains do work better. Together they are quite dark, but there is still a ring of light that gets through behind the curtain as it stands off the wall about 3" and you might get some light where the 2 panels meet.
If you want all of that light gone, use both of the above, and then you can get some black sheets, roll them up and hang them around the back side of the curtain.
nograveconcern is offline
post #7 of 10 Old 10-24-2013, 01:00 PM
b1tch1n's Avatar
I purchased an 8m role of the black colour below.
http://www.ebay.co.uk/itm/Blackout-Faux-Suede-Curtain-Lining-Fabric-13-colours-/160918792220
It lets no light through whatsoever. The fabric is easy to work with and you could easily fashion some curtains or something behind the curtains from it.
b1tch1n is offline
post #8 of 10 Old 11-07-2013, 09:32 AM
pcdoctor's Avatar
I used window blinds from Home Depot and blackout fabric safety pinned behind curtains.
pcdoctor is offline
post #9 of 10 Old 11-11-2013, 10:04 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
If you really want full darkness with the ability to open the shades, I would look into making roman blind style shades using the warm window product. This places a sheet of insulation and mylar between two layers of fabric. The roman blind is a gathering type that bunches up when retracted. If you really want it to seal, place rubber magnetic material on the edges and have a metallic strip to have it stick to.
http://www.blinds.com/control/subCategory/categoryID,18
http://www.warmcompany.com/wwpage.html
jayn_j is offline
post #10 of 10 Old 11-11-2013, 04:11 PM
Jive Turkey's Avatar
Quoted: 216 Post(s)
Liked: 136
There may be something in this thread that might help.
http://www.avsforum.com/t/1157684/blackout-valance/0_50
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is online now
Reply Theater Room Items & Accessories
