Popcorn machine recommendations - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #511 of 793 Old 12-17-2014, 07:25 PM
maxxthedog's Avatar
Originally Posted by Halloween View Post
Paragon Cineplex antique copper machine and cart now set up. Really like how it matches the rubbed oil bronze door hardware as well as the travertine pavers in the floor. I don't think the yellow or red options would have worked as well out here. Now just waiting on some supplies to stock the cart. We do have the one Country Harvest kit that came with the machine, so will start with that this weekend.
Very happy with how fast the Cineplex popcorn machine and cart arrived and both in perfect shape via Fedex.
Anyone have experience making popcorn using jalapenos to spice it up? I used to work in a fighter squadron in the Air Force, and the pilots/mission planners used to make some really wicked jalapeno popcorn that brought tears to my eyes every time I worked in their section. But the taste was worth the short irritation. I really never watched close enough to what they were doing to learn. So if anyone has a technique, please let me know.
Hi Halloween,
How do you like your machine. I wanted to go with 6 oz but really like the looks of this one.
Did you ever try the 6 oz packs in yours? How many are you cooking for? We are 5 with an occasional movie night of 8 to 10.
maxxthedog is offline
post #512 of 793 Old 12-18-2014, 04:35 PM
Liked: 0
We love our paragon popper. couldn't be more happier!
jonathan987 is offline
post #513 of 793 Old 12-21-2014, 03:39 PM
Liked: 0
Great Deal-Cineplex 4oz
Been watching this thread for awhile, and really helped me decide on choosing a quality machine. Purchased a Cineplex 4oz and have been very happy. Thank you all!
Thought I would Share, seller "e-Chef" via Ebay is offering the Cineplex on special right now for $222 shipped, lowest I have ever seen for this model. Wish I had waited a few weeks. I can't post a link since I am a newbie, but feel free to search by seller. "Best Offer" also available, so may even do a little better.
XBeatzX is offline
post #514 of 793 Old 12-23-2014, 11:52 AM
maxxthedog's Avatar
xBeatz,
What are you using for popcorn and oil? Mine is showing up tomorrow and I want to have something to try for the weekend.
post #515 of 793 Old 12-24-2014, 06:46 PM
Mark Booth's Avatar
Quoted: 77 Post(s)
Liked: 68
Originally Posted by Mark Booth View Post
Quote:Originally Posted by Mark Booth
Update on our 12 oz. Great Northern machine….
Last weekend, after making two 12 oz. batches of popcorn before the 1st movie, I went to make a third (and forth) batch for second feature. The kettle in our machine heated the coconut oil but then lost all heat and wouldn't pop the corn! DAMN!!
There were a few reports of this problem (Amazon reviews) when I purchased the machine, but I was willing to take the risk because I really needed a machine with a large bin capacity.
I contacted Great Northern and they have a repair program. The kettle is only warrantied for 30 days! (I knew that going in.) For $24.95 prepaid (plus one-way shipping), they'll repair the kettle (regardless of problem). I got an RMA number but I am concerned about turnaround time. I need the machine every two weeks for the next several months. So, being pretty competent with things electrical, I decided to disassemble the kettle to see if I could figure out the problem.
Turns out there is a thermal fuse built into the circuit inside the two halves of the kettle. It's not much bigger than a 1/2-watt resistor and is connected to the wiring via crimp connectors. I isolated the fuse from the rest of the circuit and used my trusty ohm meter to test it. Yep… open circuit. The fuse had blown. Thankfully, the brand and model number were clearly visible on the thermal fuse. It's an SEFUSE brand, 10 amp, designed to blow at 240º C (464º F).
In addition to the fuse, there's a circuit breaker arrangement mounted to the bottom of the upper half of the kettle. There's a bit of spring metal that, when heated to a certain temperature, changes position and opens the circuit (allowing the kettle to cool). The mounting nut holding this circuit breaker to the bottom of the kettle was somewhat loose. The way it mounts, I suspect that it being loose could affect how well the spring metal reacts to heat.
I tightened the nut on the circuit breaker and replaced the SEFUSE with the exact same brand/model (easily sourced on the web). I reassembled the kettle, plugged it in, and sure enough it's heating again!!
I didn't pop any batches of corn so, at this point, I do not know if my fix is going to last. The problem MAY lie with the spring metal in the circuit breaker not working correctly. If it doesn't respond at the right time, the kettle could become too hot and, pop, there goes the thermal fuse again.
I will add this…. When I went to make that third batch of popcorn right before I figured out the kettle wasn't getting hot anymore, I put in the coconut oil first to let it heat for a bit. Then I FORGOT to add the popcorn within a few minutes. I got distracted by one of our guests and got involved in a conversation. It was about 10 minutes before I realized the popcorn wasn't popping. Oops… I never poured the corn into the kettle! So, the kettle sat there heating (stirring rod NOT turning) with oil in it for about 10 minutes. If the little circuit breaker is designed to open the contacts before 464º F, then the fuse should not have blown. But I'm reasonably convinced that, had I added the corn in a timely fashion and turned on the stirring rod, I wouldn't have needed to replace that fuse. The corn would have absorbed some of the heat and helped keep the temp below 464º F.
I'll be more careful going forward. The machine will get used again this next weekend. We'll see how it goes.
Mark
Update #2: I've now made three batches of popcorn using the repaired kettle. Works like new!
I'll definitely be more careful about letting the kettle heat without popcorn kernels in it to absorb some of the heat!
Mark
Update #3 : It's been more than a year since I repaired my Great Northern's 12 oz kettle. I've continued to make about 6-8 batches of popcorn per month, so easily 90+ batches since I replaced the kettle's thermal fuse. The popper is still going strong.
Mark
kkc likes this.
Mark Booth is offline
post #516 of 793 Old 12-27-2014, 08:07 AM
ajistheman's Avatar
Quoted: 13 Post(s)
Hi everyone,
I'm looking at buying a popcorn maker, and I have tried one of my friend's makers and my concern is how long it took his (i'll assume it was 4 oz) to cook popcorn.
I currently have a Stir Crazy popper, which made the popcorn taste as good as his (maybe a different popper or different oil would make it taste better than the Stir Crazy), but my Stir Crazy seemed to make roughly 4 times as much popcorn in the amount of time his made one batch.
Not to sound picky, but I can eat a whole bowl from the Stir Crazy myself, so I'm looking for a popcorn maker that can make a big amount at once so I'm not waiting too long for the popcorn to begin my movie
Does anyone that has used a popcorn maker AND a stir crazy be able to help me compare the two?
Or just some suggestions for a quick popcorn maker
(the only reason to upgrade from the stir crazy is to get the "look" of the popcorn maker for my theater/bar.
thanks
ajistheman is offline
post #517 of 793 Old 01-02-2015, 08:22 AM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 75
Originally Posted by ajistheman View Post
Hi everyone,
thanks
I haven't used a Stir Crazy before, but I have a Theater Pop 6oz popper that makes a batch in about 3-5 minutes after a initial warm up of about 2 minutes. So you're looking at 5-7 minutes for the first batch and another 3-5 minutes for the second batch. One batch fills a standard popcorn box about 4.5 times. (as pictured)
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #518 of 793 Old 01-02-2015, 01:08 PM
maxxthedog's Avatar
4 OZ Machine
My Paragon machine showed up today. It looks great and went together easily.
I made the two batches that came with it and am eating as I type this.
A few comments:
The 4 oz machine is small. I can barely get a scoop in there and the container to load.
The first two batches did smoke quite a bit. I'm not sure if this is normal because of the oil or the kettle just burning off from the first uses.
It came with 2-6oz packages that popped without an issue.
If I can get my wife used to it I will probably try to step up to an 8 oz down the road.
Maxx
post #519 of 793 Old 01-06-2015, 09:31 PM
jaymerkramer's Avatar
Decent alternative for limited space
I found this decent sized popcorn machine in the clearance isle at Wally World.
http://www.walmart.com/ip/Hamilton-B...r-Red/38814099
Makes up to 8oz at a time and the kettle is easy to load and clean up. Great option for a person like myself who wants the real theater taste but does not have the room in my small theater. Seems to be built pretty well much better than my Stir Crazy. Thought I might share for anyone in a similar situation.
ID:	464505   Click image for larger version
ID:	464513   Click image for larger version
jaymerkramer is offline
post #520 of 793 Old 01-12-2015, 12:32 PM
nebrunner's Avatar
Quoted: 62 Post(s)
Liked: 55
I have the same exact machine as you. It smokes quite a bit, I put in a range hood over my bar area and vented it outside and I am very glad I did that. I like the machine and it looks great but I wish I had gone to a larger kettle size.
A few comments:
Maxx
nebrunner is offline
post #521 of 793 Old 01-12-2015, 12:37 PM
maxxthedog's Avatar
Still too small.....
I can deal with the smoking, it dissipates pretty quickly in my kitchen where I have it. It is just the small kettle size. I end up making 3 batches usually.
Looks like I might try to sell it and step up to a 6 or 8.
I will say that the kids (and everyone else) loves the popper and the popcorn that comes out of it.
It is interesting; now every time I'm at a gas station, school gym or any concession stand with a popper, I'm always looking to see that brand it is and what the size is.
post #522 of 793 Old 01-16-2015, 10:27 PM
Nate Miller's Avatar
Quoted: 45 Post(s)
I have the great northern machine. It works pretty well but I don't think I'm getting the right oil: corn: salt ratio. Its not bad but its not up to movie theater quality.
What ratio are you guys using?
Nate Miller is offline
post #523 of 793 Old 01-17-2015, 01:26 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I use the portion packs with my GN 8 oz.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #524 of 793 Old 01-17-2015, 01:36 PM
cgaffman's Avatar
Liked: 29
I been using my Great Northern popper for about three years now with no problems. Once it's ben popped I use a variety of shake on flavorings such as white cheddar and ranch.
cgaffman is offline
post #525 of 793 Old 01-17-2015, 05:55 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
How about for 4 K contents and integration with control 4
zoro is offline
post #526 of 793 Old 01-17-2015, 08:33 PM
Quoted: 45 Post(s)
Herm... I lied. I have a paramount machine. They are so similar and I looked at so many I must have forgotten. I have the 6oz machine. I haven't tried the packs yet but I am going to.
post #527 of 793 Old 01-17-2015, 08:42 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I use the gold medal mega pop.
bluer101 is offline
post #528 of 793 Old 01-20-2015, 06:38 AM
bobgilbert's Avatar
Amazon currently has the "Great Northern Popcorn Black Bar Style Lincoln 8 Ounce Antique Popcorn Machine (Bar Style)" for sale for $143.99
http://www.amazon.com/Great-Northern...1cbe500c5fd090
bobgilbert is offline
post #529 of 793 Old 01-21-2015, 04:33 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
I've been using the GN packs in my 8oz GN machine. But I just ordered season salt/coconut oil & white kernels to give my own content mixing a try.
the_abbot is offline
post #530 of 793 Old 01-21-2015, 04:43 PM
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
i have http://smile.amazon.com/gp/product/B...?ie=UTF8&psc=1
it comes with the 3 scoops presized for kernels, oil, and salt.
and i love it. Buy some of the flavacol salt, and some coconut oil.
I just use these: http://www.amazon.com/Great-Northern..._bxgy_k_text_y
but i also like to add a 1/4-1/2 scoop of the coconut oil
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
and a 1/2 tsp salt (this stuff is like salt on steroids, use sparingly)
http://www.amazon.com/Gold-Medal-Pro...sin=B004W8LT10 in addition.
roccoleach is offline
post #531 of 793 Old 01-24-2015, 11:20 PM
Ken Rivera's Avatar
Thanks for your post... This seems like a much more reasonable solution for real movie theater popcorn at home... I've been looking at the full-size machines, but just don't have the space... This one is much simpler and I like that the stuff that gets dirty can be removed and washed easily...
Cheers!
Ken Rivera is offline
post #532 of 793 Old 01-28-2015, 07:36 AM
Liked: 5
my wife really wants a popcorn machine in our HT but since it's in the basement I'm concerned about the overwhelming popcorn smell. I may have to install a exhaust vent in the basement just for the popcorn machine. lol
lotus1 is offline
post #533 of 793 Old 01-28-2015, 09:20 AM
Big Worms's Avatar
Popcorn smell? Where is the problem with that? To me that is the best thing about having a popcorn machine.
Johnla, crunchyfrogs and lotus1 like this.
.: Ernie :.
Big Worms is offline
post #534 of 793 Old 01-28-2015, 10:00 AM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
The smell does not hang around for days, just the guests.
bluer101 is offline
post #535 of 793 Old 02-01-2015, 07:18 PM
Ken Rivera's Avatar
Cheers!
I received the Hamilton Beach machine today from Amazon - I also purchased the Great Northern 6oz. packets of popcorn/oil/salt... Ran the first batch - waited for several minutes and popping hadn't begun... Went back to the owner's manual and realized that I placed the kettle insert backwards... Switched it around and popping started just a few seconds later... Everything came out ok, but lots of unpopped kernals... I blame myself for that - having the kettle reversed left the kernals cooking without enough heat to pop... Can't wait to try it again...
Clean-up was a snap. Soaked the removable kettle in hot soapy water for a few minutes and cleaned right up. Wiped out just a little bit the top half...
Highly recommended unit... A great bargain at $60...
post #536 of 793 Old 02-05-2015, 11:47 AM
crunchyfrogs's Avatar
Plus the smell will not linger whatsoever. When people walk in and smell it being made....5 stars
crunchyfrogs is offline
post #537 of 793 Old 02-23-2015, 12:32 PM
Rockstead's Avatar
Quoted: 16 Post(s)
Guys, I'm looking at purchasing one of these Chinese made 8oz with cart from a local Canadian company popcornmachine.ca, it looks very similar to the Great Northern, they are probably all made at the same factory.
My question is about those all in one mixes, is there a general consensus or all they the same.
Second, what are you doing to get the same warm butter topping like in a theater? Are you using a consumer brand butter warmer and pump? If so, which one as I only see the commercial ones that cost as much as a Chinese machine.
Or are people putting coconut oil as the topping? Is that what theaters use that say topping instead of butter? And same question, how are you applying it?
Rockstead is online now
post #538 of 793 Old 02-23-2015, 12:45 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
I have a great northern 8oz and love it. I tried their own pre portion packs and was ok. I prefer mega pop/gold medal pre packs.
As for topping we do not use it as it tastes fine by itself. Sometimes I will add a little more of the Orange butter salt though.
bluer101 is offline
post #539 of 793 Old 02-23-2015, 12:59 PM
Rockstead's Avatar
Quoted: 16 Post(s)
So without topping it tastes like the theater without topping or is something included in those mixes to give it a topping taste? I just find it too dry without topping.
post #540 of 793 Old 02-23-2015, 02:18 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
The pre portion packs have the right coconut oil, corn, and flavacol Orange salt. This orange salt is what give theater, theme park, etc that iconic taste.
I just sprinkle a little more (bought extra flavacol) orange salt to my liking.
bluer101 is offline
Reply Theater Room Items & Accessories
