My new Fusion - Lagoon chairs from Roman - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
Old 05-03-2014, 01:47 PM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
Is there anyone in the Milwaukee/Chicago area (Madison wouldn't be too far....Hint..Hint) that has Elites that I could try? I just looked at a bunch of Palliser chairs and realized I would like to sit in a chair before I buy it.
Out of the chairs I tried, I liked the Palliser Equalizer and Mendoza chairs. They were a good size for me and had just the right balance of softness and support. Both of these are about $1000 more than the Elites for a set of 4. I would prefer to buy the Elites but I sure would like to try them before I write that check.
TedO is offline
Old 05-06-2014, 10:48 AM
80sarcade's Avatar
So I just ordered 4 Escapes black in bonded and cannot wait for their delivery! I do have one question, I know these are pre-setup for Buttkickers, does anyone know if Aura AST-2B-4 Pro Bass Shakers will mount or fit to the pre-installed brackets? I am over budget on the chairs and trying to save a little money on the "added extras" ie the shakers.
Also I know the Buttkickers are very nice but the Aura's are half the price. Am I going to be let down with these and wished i spent the extra $?
Anyway thanks to everyone on these treads, It was a leap of faith buying these sit (site) unseen, but with all the positive feedback and the great communication from Roman, I hope to really like these seats!
Paul (80sArcade)
80sarcade is offline
Old 05-06-2014, 11:21 AM
falafala's Avatar
Quoted: 23 Post(s)
Paul (80sArcade)
My buttkicker bottoms out so much so that i turned it off now. Tried different settings but no luck. Would like to know if anyone had better experience as i want to put this option to good use!
falafala is offline
Old 05-06-2014, 01:54 PM
Shan's Avatar
What are you using to drive the buttkickers? If you are using a BK-1000NA, my guess is you have the gain too high. You may also be trying to push the frequency too high. ideally, you BKs do you replace your subwoofer, but handle the low frequencies that Subs cannot play as efficiently and back the subs up on the higher frequencies. I have high pass filter set to about 50hz and the lowpass off.
To tune it, I suggest you find a really bassy scene (I use the Cave Troll attack scene in LOTR: Fellowship) to tune your BK. Set it pretty low and play the scene. If it is fine, adjust it up quite a bit and play again. If it bottoms out, reduce by half of the change and run again. Each time you replay it reduce or increase by 1/2 change. Once you get them tuned in, you will be happy as pie. People tend to try and push them too hard. If you cannot get it tuned it, talk to Roman as it may be defective.
Again, think of the BK as you do your surrounds. Don't increase the gain so much that they are obvious. When set up correctly, folks you invite over should thing you just have really great subwoofers. If it is obvious that the shaking is coming from the chairs, you may either have it tuned wrong or your subwoofer is not sufficient for your room. The only time I would have the BKs be obvious is if you are watching something late at night so you want the subs down in order to not bother anyone. Otherwise, they are just there to reinforce your existing bass.
Shan
Shan is offline
Old 05-06-2014, 02:05 PM
falafala's Avatar
Quoted: 23 Post(s)
Shan
Thanks Shan let me give this a shot. I wish this is in some manual smile.gif
Another issue i observed is there is a delay between butkicker and my subwoofer. This ruins the experience, i tried adding delay to my subwoofer and it doesn't seem to do any good.
falafala is offline
Old 05-06-2014, 02:15 PM
Shan's Avatar
It would be helpful to know how you are driving it. If you are y-splitting off the same output so your sub and your BK and driven on the same timing, I cannot imaging delays being an issue unless your subs are a really long ways away. If you are using an old receiver to drive your BK, you need to ensure you are not adding any additional delay there.
The perceived timing issues could also be that you are trying to use the BKs to play to high a frequency. Once you get them to where they are not bottoming out, you might pick a scene were you have noticed this issue and try turning the high pass filter on the BK down to about 25 then increasing (using the same method above) until your BK integrates well with your sub.
Shan
Shan is offline
Old 05-08-2014, 02:36 PM
Elvis Is Alive's Avatar
Quoted: 26 Post(s)
Liked: 43
I just ordered a set of 3 Escapes from Roman in black leather/vinyl combo. I will be waiting patiently for a couple of months until the advanced buttkickers get back in stock. These are replacing an aging set of Berkline 13174's purchased from Roman back in 2008 or so.
I went with leather over the bonded due to my Berkline's bonded leather tearing. To be fair, first bubble occurred after almost four years of daily use. Tears came soon after. With the price of the Escapes, I wanted a little more peace of mind. Got the 5 year warranty as well.
Elvis Is Alive is offline
Old 05-09-2014, 11:44 AM
80sarcade's Avatar
I just received my four black bonded leather escapes. |0|0|0|0| First impressions, they smell great, are comfortable, and appear to be built pretty well. Love the adjustable headrest!! This was the thing that pushed me over budget, but so glad I did.
A couple things not really mentioned on the website, they do come with USB port in the storage areas, they have the Buttkicker plate, feet and screws included (now need to find the $ for the amp and kickers)!
The tray is all aluminum and not like the plastic wood grain ones I have seen. They are just like the tilting table, but they are not as thick and do not in tilt nor do they have the magnets in them. I really like them over the plastic wood grain versions. Only complaint is they are hard to get in the storage area and they show finger prints.
Overall very happy with my purchase and looking forward to spending a lot of time watching movies, TV and sports in them. One other note, I sent in the check last Wednesday and the delivery was the following Thursday. So just over a week to Ohio total turn around was better and faster than I expected.
Paul (80sarcade)
Old 05-09-2014, 04:24 PM
Bullitt5094's Avatar
I've had my 8 Escapes for just over two years now. I have zero complaints and I've had zero problems with them. They look and work like new. They get a LOT of use. Typically I have all 8 of them filled at some point each weekend with friends and family and typically the wife and I watch a movie and/or TV show a couple of times a week plus some Audio time pretty often on top of that. They don't collect dust, that's for sure. I'm extremely satisfied with my purchase.
Bullitt5094 is offline
Old 05-12-2014, 11:57 AM
ClemsonJeeper's Avatar
Quoted: 228 Post(s)
Liked: 139
Anyone sit in Palliser HiFi before and and comment on how firm the Escape is compared to that? I'm reluctant to spend 5k+ on a set of furniture I've never seen let alone sat on before.
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
Old 05-17-2014, 01:33 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
It does not look like anyone is sharing their experience, so I will since I have sat in both.
The Palliser overall makes very good quality recliners. The Hi-Fi is one for the several models that I would probably recommend in terms of comfort and looks.
On the other hand, it is not fair comparison of this chair and Escape-1019, which regardless of comfort and looks, which are both very subjective, has way more features including powered headrest, arm storage compartment and aluminum tray, Buttkicker ready feature, USB port., integrated power cup holder.
I'd say that comfort wise they may be similar with the Palliser being slightly firmer, but in terms of head support, and many other listed above features there is no comparison...
Roman
rtheaters.com
Fusion Collection Seating
Ultimate Home Entertainment
rsh is online now
Old 05-21-2014, 07:45 PM
ultra 150 pilot's Avatar
Quoted: 84 Post(s)
Liked: 43
What can I use on my escapes bonded leather to keep them from squeaking when they open and close?
ultra 150 pilot is offline
Old 05-21-2014, 08:41 PM - Thread Starter
alittletank's Avatar
Liked: 26
Talcum powder
alittletank is offline
Old 05-25-2014, 07:32 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
You can also try Armor All
Roman
rtheaters.com
rsh is online now
Old 06-14-2014, 09:12 AM
scotsman8's Avatar
Quoted: 12 Post(s)
I'm looking to buy some chairs for my room but the room is only 10' wide. Was planning on going with the Jives... Would love to get 4 seats with the |o|oo|o| option if possible, but this comes out to 109" width. I do have to pass the couch to get into the seating thus leaving only 11" to pass on 1 side if I have one side all the way close to the wall. Do you think this would be a problem and I would just be better going with 3 seats?
scotsman8 is offline
Old 06-14-2014, 09:29 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
scotsman8,
If you need to pass the chairs you do not have enough space for the IOIOOIOI set because the isle should be at least 24" wide.
Your options are:
1. go with a set of 3
2. go with the 4 seat couch IOOOOI - 97.25" wide, which will leave you with 22.75" isle (a bit smaller than needed, but workable) and use modular armrests: http://www.rtheaters.com/FusionColle...C-MOD-ARM.html
Roman
rtheaters.com
rsh is online now
Old 06-14-2014, 09:40 AM
scotsman8's Avatar
Quoted: 12 Post(s)
Originally Posted by rsh View Post
scotsman8,
Your options are:
How are the comfort of the modular armrests compared to the regular? Maybe I should just go with the 3 regular seats.
Old 06-14-2014, 10:06 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
No problems with the comfort whatsoever...
Roman
rtheaters.com
rsh is online now
Old 06-14-2014, 10:27 AM
scotsman8's Avatar
Quoted: 12 Post(s)
Ugh decisions decisions.
Old 06-14-2014, 01:37 PM
scotsman8's Avatar
Quoted: 12 Post(s)
well I went to a store today and they had a |o|oo|o| seat and when sitting in the middle i reclined and didn't like how the seat next to you was so close and not reclined. Going to go with a curved 3 I think.
Old 06-17-2014, 05:49 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Well, you can always use a re removable armrests on the loveseat.
It is ultimately comes down how many seats you actually need.
Roman
rtheaters.com
rsh is online now
Old 06-19-2014, 06:53 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Can the removeable armrests be purchase seperately? If so, what is the cost?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
Old 06-19-2014, 08:58 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Yes, It can.
Please contact me off line for pricing.
Roman
rtheaters.com
rsh is online now
Old 07-06-2014, 03:19 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Folks,
I will be out of the country for next week or so, but will be checking my emails regularly. So please email me if you need anything. I will not have access to the phone.
Roman
rtheaters.com
rsh is online now
Old 07-07-2014, 08:10 AM
Air Supply's Avatar
I'm selling my (3) Fusion Tributes if anyone is interested. These are some of the best seats on the market.
We're re-doing our basement, so these need to go. They are 10 months old I believe and come with a 5 year extended warranty.
They are located in Wildwood, Missouri.
Selling for $1,750.
Add your favorite bass-heavy movies here; http://lfemovies.pbworks.com/
Air Supply is offline
Old 07-16-2014, 06:57 AM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
Folks,
Just wanted to let you know, that I am back, and will be answering the phone...
Roman
rtheaters.com
rsh is online now
Old 07-16-2014, 03:34 PM
falafala's Avatar
Quoted: 23 Post(s)
how is the warranty service
Did anyone get a chance to use the warraty service?
For two of my Escapes the metal rings on the armrest (that you can insert the tray into) have become loose and fell off. They are very hard to screw back in as there is not much thread exposed. I may have to call on the warranty and hope to get them fixed.
thanks for sharing your inputs.
falafala is offline
Old 07-16-2014, 04:14 PM
rsh
rsh's Avatar
Quoted: 81 Post(s)
Liked: 40
It is actually a relatively easy fix.
If you put the chair on the side and reach inside the arm, you will find a nut that holds the spindle in place. Just Loosen the nut, and screw the spindle cap back on. Tighten the nut then, and you will be all set.
I hope this helps...
Roman
rtheaters.com
rsh is online now
Old 07-16-2014, 04:33 PM
falafala's Avatar
Quoted: 23 Post(s)
wow thanks for the quick reply! Will try it out.
falafala is offline
Old 07-18-2014, 11:52 AM
ScAndal's Avatar
Liked: 27
I had to do the same thing on two of my chairs. easy fix.
ScAndal is offline
