Wall plate for sub... RG-6 to RCA adapter? - AVS Forum | Home Theater Discussions And Reviews
Old 01-19-2012, 04:58 PM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
I'm planning to move my equipment to a new spot in my room next week - so I am ordering the connectors from Monoprice right now. The "rack" will be some built in shelves that are closed on the back - but I will have access to that area from my utility room.
I plan to use this plate at the "rack":
One of these at the "rack" for my HDMI cable going out to the TV and also for the incoming RG-6 for the cable box:
I will be using RG-6 for the subwoofer connection to the back of that plate, and going to the sub location - but I am having a hard time finding another wall plate that has a RCA to "F" connection on it. Anyone have any sources they recommend?
I plan to put the front left/center/right speaker "outlet" kind of central and low on the front wall - I could add a RCA to "F" jack to that plate for the sub if I could find one...
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is offline
Old 01-19-2012, 05:01 PM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
Alright... looking at the picture I just posted I think I already have a solution - I can just take the "Sub 2" RCA to F connector off that plate and add it to another plate at the front of the room...
I'm still open to other sources though
-Aaron
PTAaron is offline
Old 01-19-2012, 06:48 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
I used several of these...
Jeff
jautor is online now
Old 01-19-2012, 07:22 PM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
I'm not sure how I didn't find that... thank you!!
I was looking in the audio section and wall plate section, would have made more sense to look in video!
-Aaron
PTAaron is offline
Old 01-24-2012, 10:06 PM
dsumike's Avatar
Not that these little adapters are so expensive that they break the bank, but I recently picked up a couple of these from Amazon:
http://www.amazon.com/RiteAV-Male-F-.../dp/B000V1JUKY
They are "more expensive" but with free shipping they ended up coming out less expensive than the Monoprice ones. Used two of them in a recent build, very satisfied.
dsumike is offline
Old 01-24-2012, 11:50 PM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
Thanks for the link!
-Aaron
PTAaron is offline
Old 01-27-2012, 08:23 PM
ace7m's Avatar
Not sure if you are still looking for a solution but i used a F to RCA Hex hole insert. This is http://www.amazon.com/Icarus-Jack-Fe...7720670&sr=8-1 one that was similar to the one I used.
ace7m is offline
Old 01-27-2012, 11:33 PM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
Oh nice! Thanks!
Right now I've got the adapter someone suggested earlier and a regular RCA keystone, but that one will eliminate the need for an extra connection/adapter.
-Aaron
PTAaron is offline
Old 01-28-2012, 11:09 AM - Thread Starter
PTAaron's Avatar
Quoted: 241 Post(s)
Liked: 255
Turn out Lowes carries the keystone pieces too... I always forget to check Lowes since home depot is half a mile closer
They are $7 from Lowes, which is kind of a rip off - but they will look nice so it's ok.
-Aaron
PTAaron is offline
