projector mount suggestions - AVS Forum | Home Theater Discussions And Reviews
Old 02-04-2012, 10:27 PM - Thread Starter
dabuddha's Avatar
So I finally got around to finishing my basement and got permission to purchase a projector. The one I decided on is the epson 3010e. From what I read, the lens has to be within .1 " of the top of my screen so given that, that means it'll have to be about 20" from the ceiling. The thing is, I only have an 8' ceiling so I'd like a mount that I can push back up when I'm done with the projector. Some sort of scissoring mechanism (manual since I'd imagine something electric would be expensive) Any suggestions (my budget for the mount is going to be about $200ish unfortunately)
TIA!
dabuddha is offline
Old 02-12-2012, 11:21 PM
saiku's Avatar
sorry i'm no expert...i searched for "Projector Lift" and this seemed to be the cheapest : http://www.amazon.com/Draper-Inc-300.../dp/B000SCB0MM
HTH
Hail to the King, Baby!
saiku is offline
Old 02-13-2012, 06:43 AM - Thread Starter
dabuddha's Avatar
ty for looking
I'm coming close to the conclusion that I might just have to make something myself :/
dabuddha is offline
Old 02-14-2012, 11:27 AM
pyro383's Avatar
You could also take the stanchion, cut it, put a hinge on it and mount a magnet on the ceiling to hold it up when not in use.
all fired up
pyro383 is offline
