Looking for Inexpensive theater sconce lighting and wall moulding ideas. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-13-2012, 08:57 AM - Thread Starter
fastgt79's Avatar
I have the drywall up in my basement theater room and looking for relatively inexpensive ($50 or so) sconce light for the walls and wall moulding ideas/pictures (chair rail, fake columns, decorative squares, etc). I need 6 total sconce lights that why I don't want to spend more then $50 each. Any help or pictures will be appreicated. Also, the color scheme is going to be grey and darker grey walls will black theater seats and pewter carpeting.
fastgt79 is offline
post #2 of 9 Old 02-14-2012, 05:46 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
These came in at just under $40 each.....
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 9 Old 02-20-2012, 06:24 PM
robby69's Avatar
$33 at HD
I put 4 of these in my 11x19 dedicated theater room. Look great, and I the 100-Watt bulb gives me alot of dimming options. They also come in opaque, but I am sure you will take a hit on the amount of light they generate.
http://www.homedepot.com/h_d1/N-5yc1...kuId=202573214
I got a great look using a chair rail all round the 3 walls.
Baseboard & Trim 2124-20 Trout Gray
Chair Rail itself 2120-10 Jet Black
Below Chair Rail 2119-20 BlackBerry
Above Chair Rail 2119-50 Nickel
All Benjamin Moore Paints
Everyone that sees it loves it, including myself !
Here is my blog that I haven't finished, but will someday.
http://myhometheaterbuild.blog.com/page/2/
robby69 is offline
post #4 of 9 Old 02-23-2012, 11:40 AM
inyouratmosphere's Avatar
These look really cool! Though, I wonder if maybe they're hung a bit too low?
inyouratmosphere is offline
post #5 of 9 Old 02-23-2012, 01:15 PM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
If you are referring to my pic, no, they're not. The picture is a little deceiving. You can check out my thread to see the rest of them.
The ceiling is on the low side (7'2" I think) and that rail is on top of the 48 inch tall panel attached to the wall.
Tom Logan
post #6 of 9 Old 02-23-2012, 04:50 PM
dcg58's Avatar
I picked up some at HD for $20 each. They were clearing them out at the store up here (Canada) but they may have some in the US.
They were their own brand of lights , Hampton Bay, but I don't remember what the model was.
I did some wainscotting around the room with panel trim inside. All MDF except the trim pieces in gold.
I don't know what your budget is for trim so maybe you want something simpler.
I was going for an old theatre / opera house kind of look.
My Vintage style Home Theatre Build thread:
http://www.avsforum.com/t/1400234/vintage-look-diy-theatre-build
dcg58 is offline
post #7 of 9 Old 02-23-2012, 05:04 PM
dcg58's Avatar
Sorry for the lousy pictures. I didn't get time to adjust the colors in them. The walls are burgundy not purple and the room isn't finished yet but you will get the idea.
dcg58 is offline
post #8 of 9 Old 02-24-2012, 09:12 PM
porsche951's Avatar
Very nice.
porsche951 is offline
post #9 of 9 Old 08-13-2013, 09:33 AM
Tech Newbie's Avatar
Dcg, excellent job ! Thanks for sharing.
Tech Newbie is offline
Reply Theater Room Items & Accessories
