A shelf to go under the tv? - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2012, 10:12 AM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
I'm looking for a shelf similar to this one:
http://www.amazon.com/Cambre-DW1B-BB...98179&sr=1-133
$150 seems a bit ridiculous for a simple shelf. Anyone know of one similar to that? I need it to be about the same size as that one, around 3 feet wide and 16 inches deep. The cheap shelves I've seen at Home Depot would be fine, but they are not deep enough.
bassage is offline
Old 02-17-2012, 10:18 AM
jjaymz's Avatar
Holy rip-off, Batman. That's pricy. Thgere must be plaenty more of this type on Amazon, but do Google searches on home theater or audio wall-mount shelves. There are thousands of them out there.
Even Wal-Mart has them (online, not necessarily in the stores),
Jim
jjaymz is offline
Old 02-17-2012, 12:56 PM
pasha's Avatar
check monoprice.
pasha is offline
Old 02-17-2012, 01:04 PM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
I've checked monoprice and amazon and other places, but I just can't find any cheaper ones that match the size I want. Most wider shelves are not deep enough to hold AV gear, or they are the single shelves that will only let you put one item on it. I have seen several stacked shelves and things like that, but I want only one shelf 3 foot wide. Might have to make my own or something.
bassage is offline
