Starting to look at seats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-20-2012, 08:52 AM - Thread Starter
jrm1504's Avatar
So this weekend we were in the Seattle area looking at lutron shades for the house. The store had some nice theatre seating as well and it sort of planted the bug.
They had cinematech, and they were pretty comfy...but it would be a bit irrelevant because to afford them I wouldn't have any arms or legs left.
Then across the street there was a magnolia. Theirs weren't as comfy. The acoustic innovations were pretty good, but squeaked.
Things we liked were the arm rests not being sky high. Good padding. And the ability to REALLY recline back...nearly flat.
Any advice on where to start? What brands/models would be worthy?
jrm1504 is offline
post #2 of 6 Old 03-20-2012, 08:57 AM
hslansky's Avatar
I am in the same situation. I think I have settled on the Palliser HiFi seats. Very comfortable and nice look and quality. Anyone have additional thoughts on these?
hslansky is offline
post #3 of 6 Old 03-20-2012, 09:08 AM - Thread Starter
jrm1504's Avatar
Were you able to test sit them? My problem is where I live there is nothing to test sit in. Seattle is as close as it gets and that is nearly three hours away.
jrm1504 is offline
post #4 of 6 Old 03-20-2012, 09:17 AM
KenLerch's Avatar
There are many brands out there to select from now. I would start by looking at Palliser. They are an excellent company with many models and options (hundreds of fabrics and leathers, power, tray tables, iPad Holders, etc.) from which to choose.
RowOne has also been making very good chairs. Take a look at their import and domestic models.
Roman (rsh on the forum) also has his own line of import chairs with some nice features.
Lane has some nice options as well.
The Palliser HiFi is the new model name for the Sequelle/Hiland. It is a great looking chair, IMHO and features a taller, foam back for more support and more detail.
Ken Lerch
StargateCinema.com
Home Theater Seating and Decor
HTSeating.com
KenLerch is offline
post #5 of 6 Old 03-20-2012, 09:29 AM
hslansky's Avatar
I was lucky enough to find a local furniture dealer that had the Palliser HiFi on the floor and I was able to try them on for size. I am very picky when it comes to seating so I would never purchase a seat without being able to try it first. I found this particular seat to be to my liking.
hslansky is offline
post #6 of 6 Old 03-20-2012, 10:56 AM
cat-222ASR's Avatar
By that you mean these cost and arm and leg.
Why not get second hand cinema seats rockers are cool and they don't take up as much space you can fit more of them in they're easy to fit they look the part look around for them on eBay they're bound to have plenty going for around each $100.00 or less if your lucky.
I use x6 Irwin rockers and too bad the company has sold them off as I was thinking of buying x3 more for £80.00 a seat with free postal.
I'd look around otherwise you'd be busted after spending close to $6 or more grand.
I got mine though http://www.ebay.co.uk/sch/mycinemauk...&_trksid=p3686
Some of the seats listed a few years ago was a bit over my budget and they had very few rocker seats going. I pleased when I saw rockers going for £79.50 each. I've gotten so used to them with the rocking motion, just like being in the cinema.
This site is located in the US but the prices, burnt my eyes. You should look for second hand often they are in good condition. Try eBay-USA
http://www.theaterseatstore.com/bass-forum
cat-222ASR is offline
Reply Theater Room Items & Accessories
