Wall-Mounted LCD TV Power Plug Installed with extension cord? - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2012, 02:08 PM - Thread Starter
joshua2415's Avatar
In 2008, I had a local home theater dealer/installer mount an LCD on the wall of my living room. In 2011, I moved from that house and took the TV with me. Upon removing it from the wall, I discovered power was supplied to it via a kind of extension cord from the closet, where all my components were, to the tv on the wall. From researching things, i found that extension cords cannot be used in walls, but I guess, technically since both ends of the cord were outside the wall, it's ok. I am right in this assumption? The cord itsself was an inwall rated cord, and the ends were heavy duty, so it wasn't a light weight lamp cord. If anyone out there has some guidance on this, I'd be much appreciative. Thanks
joshua2415 is offline
Old 03-21-2012, 02:50 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
This is what many folks use if they do not want to install a dedicated circuit for a wall mounted TV. The wire that runs between the 2 receptacles is Romex and the extension cord connects the bottom receptacle with the prongs to an existing wall receptacle..
http://www.monoprice.com/products/pr...seq=1&format=4
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
