Palliser Atomic vs. Lane Matinee - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-07-2012, 09:56 AM - Thread Starter
arkiedan's Avatar
I just discovered this particular forum and could use some advice. I'm considering the following:
Palliser 41945 Atomic 3-seat curved, in brown top-grain leather/match with motor recline and removable trays. About $1,950.
Lane 103 Matinee 3-seat curved, in brown premium leather/match with motor recline and removeable trays. About $1,750.
I've been told the Lane Matinee is identical to the Berkline Reno and, in fact, they do appear to be the same. It seems that Berkline liquidated, Lane took over their factory, and is producing roughly the same products.
And, I've been told the Palliser Atomic is, in fact, the Pacifico model with the accessory trays.
My assumption is that the top-grain leathers will be essentially identical but what are the preferences between the two manufacturers, quality-wise. Comparing the two the Lane prices out about $150 - $200 less than the Palliser.
A very confusing market and could use advice from owners and etailers.
arkiedan is offline
post #2 of 4 Old 04-07-2012, 08:17 PM
domingos38's Avatar
Quoted: 26 Post(s)
Liked: 38
amazing nobody helps out
domingos38 is offline
post #3 of 4 Old 04-08-2012, 04:24 AM - Thread Starter
arkiedan's Avatar
Amazing indeed. Gotta be plenty of Palliser owners around here.
domingos38, thanks for bumping it back up. I did get an IM from one of the etailers that posts here. Hope some actual owners will pipe in.
arkiedan is offline
post #4 of 4 Old 04-09-2012, 07:25 AM
TheaterSeatStore's Avatar
When you compare the Atomic to the Lane 103 Matinee you will have the following:
1 - better quality leather on the Atomic - it uses their Glove leather which is considered a "specialty" leather. It will be a bit softer and has nice undertones to it.
2 - The 103's are good seats but the Atomic is, in my opinion, a better built seat. It uses a higher density foam and a smoother recline mechanism.
Overall both very nice seats - but if money is not the only deciding factor, I would suggest the Atomic over the 103's.
Martin
TheaterSeatStore.com
TheaterSeatStore is offline
Reply Theater Room Items & Accessories
