DIY Snack Tray for Berkline HT Seats - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-07-2012, 03:10 PM - Thread Starter
bultala's Avatar
I wanted to share my DIY snack tray project for Berkline HT seats with fellow HT enthusiasts.
You need:
1. 3 inch PVC pipe cut to your need I cut 3.5" length
http://www.instructables.com/image/F...a-Heat-Gun.jpg
2. PVC inside Fit Closet Flange without Test Cap, 3-Inch
http://ecx.images-amazon.com/images/...500_AA300_.jpg
3. Your favorite tray, I used Dexas Watermelon cutting board
http://images.bedbathandbeyond.com/a...418708949P.JPG
4. Cup Holder for HT1 poker Tables; only if you want to add cup holder; Drill the cutting board in the same location as the HT seat cup holder. Drop in the Poker Table cup holder, should fit perfectly.
http://www.pokerchiplounge.com/stuff...ts/4885564.jpg
5. Appropriate set of nut, bolt, washer and screws; Choose correct size screws when connecting the PVC Flange to the cutting board, so you do not penetrate the visible side.
Now all you have to do is put them together. The 3" PVC fits perfectly in Berkline seat's cup holder and allows easy turning of the tray. To add the cup holder, drill a 3 1/4" hole to press in the Cup Holder for HT1 poker Tables.
bultala is offline
post #2 of 2 Old 04-08-2012, 04:35 AM
arkiedan's Avatar
Clever fellow! Getting ready to order and think I'll forgo the model with the trays and do this. Plenty of options for trays out there.
arkiedan is offline
Reply Theater Room Items & Accessories
