PopCorn Recipe Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-08-2012, 01:41 AM - Thread Starter
burts's Avatar
Im ordering ingredients from amazon to make theater popcorn so far i have in my cart
Paragon coconut oil & Corn
Flavacol Gourmet Popcorn Flavoring
Wabash Stovetop Popper
I notice there is flavacol flavoring or seasoning(salt) do you use both or just the flavoring?
Anyone try this recipe? Is it like the theater popcorn and also Whats the procedure to make it?
burts is offline
post #2 of 13 Old 04-08-2012, 03:27 AM
rede8's Avatar
I want popcorn
rede8 is offline
post #3 of 13 Old 04-08-2012, 03:28 AM
pokekevin's Avatar
Liked: 102
I just use the seasoning one as salt. Try getting the stir crazy maker. Worth it
pokekevin is offline
post #4 of 13 Old 04-08-2012, 11:15 AM
iGuitar93's Avatar
The flavacol is a salt seasoning. Use flavacol with the coconut oil in the kettle. Your popcorn will be sufficiently salty.
That recipe is great! I have a 4oz popper and i use 2tblsp coconut oil, 1/2 cup corn, and 1/2tsp flavacol.
iGuitar93 is offline
post #5 of 13 Old 04-09-2012, 04:43 PM
swarm87's Avatar
Quoted: 111 Post(s)
Liked: 87
if you are getting the whirleypop(wabash stovetop machine) id get it directly from them at popcornpopper.com there's a few gift sets that come with premeasured portion packs specifically designed for the machine, i got mine form BBB and really wish i got it from there as i spent ~40 on portion packs, seasonings and salt(oil will be with my next order as im fine using peanut oil).
as for the recipe with that machine i usually sue 8TBSP if seeds 1ts of flavacol and 1.5ts of the movie theater seasoning(from that site) with about 2.5TBSP of peanut oil(they sell coconut oil too, but peanut oil is less messy and tastes almost the same IMO)
pcm=potato
bitstream=patato
swarm87 is offline
post #6 of 13 Old 04-09-2012, 11:07 PM
stockmonkey2000's Avatar
stockmonkey2000 is offline
post #7 of 13 Old 04-09-2012, 11:10 PM
T
Oops not sure how to edit a post from a phone. I use the paragon oil and corn and the flavacol also. I use 3Tbs oil and 1/2 cup corn. It tastes great.
post #8 of 13 Old 04-10-2012, 12:07 AM - Thread Starter
burts's Avatar
Im in hawaii so amazon free shipping is a must, im bummed out because the darn cocount oil is out of stock now.
Whats the difference between the flavacol seasoning and flavoring? Right now im going for the flavoring..
burts is offline
post #9 of 13 Old 04-10-2012, 06:45 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
You can't find coconut oil in Hawaii? Do you have Walmart? At least in the 48 Walmart stocks LuAna Coconut oil.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #10 of 13 Old 04-12-2012, 05:22 PM
swarm87's Avatar
Quoted: 111 Post(s)
Liked: 87
cant find it in rhode island either(will check agian)
pcm=potato
bitstream=patato
swarm87 is offline
post #11 of 13 Old 04-13-2012, 07:31 AM
nebrunner's Avatar
Quoted: 52 Post(s)
Liked: 53
Wow I can't believe you use just 1/2 tsp flavocol. Probably a lot better for your health...I load that stuff on.
nebrunner is offline
post #12 of 13 Old 04-13-2012, 04:12 PM
iGuitar93's Avatar
Well that's what the box said to use. I used to eat a lot of salt but i've been keeping better track of my health. It's really surprising how little salt we are supposed to eat. And if you gradually start using less salt it is easier to wean yourself off of it.
post #13 of 13 Old 04-20-2012, 12:59 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
Take a look on Google for Concession Supplies. There are several in HI depending on which island you are on.
http://www.scspopcorn.com/popcorn/
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
Reply Theater Room Items & Accessories
